Old 04-15-2002, 05:06 PM   #1
WRXThis
Member#: 3960
Default Let's talk flywheels
Trying to find the best possible flywheel for my WRX. I have seen aluminum flywheels that way 9.5lbs and the chrome moly's seem to weigh about 1lb more. I assume the chrome moly will last longer then the aluminum would? What are the important things to look for in a flywheel? It it possible to go "to light"? Finally, what brands would you guys recommend?
I intend to get the new updated WRX clutch replaced under warranty and will slap in the aftermarket flywheel then.
WRXThis is offline   Reply With Quote
Old 04-15-2002, 07:49 PM   #2
nmyeti
Member#: 4980
I am using a BPM flywheel... I think its like 14lbs. Personally i'd not go with anything that was much less than that. There is a point where you can get into a flywheel that is just too puny for our cars. The best thing would be to find someone that has a upgraded flywheel in their car and see if they will let you drive it just a bit. At least that way you won't be shocked when the work is finished.
-Nathan
nmyeti is offline   Reply With Quote
Old 04-15-2002, 08:15 PM   #3
WRXThis
Member#: 3960
Thanks for responding Nathan. Unfortunately, I don't have a car to drive that is aftermarket flywheel equiped so I-Club is my only resource at this time
Why not go lighter then 14lbs? The Findanza's are 9.5 lbs. What negative affects should I expect if I went with a flywheel that was 9.5lbs compared to say the BPM at 14lbs? I can't see 4.5 lbs making that huge of a difference but apparenlty it must. I have heard parking lots speeds are most affect with the aftermarket flywheel. If someone could elaborate a bit on that please? What negative affects will I see?
Old 04-15-2002, 09:57 PM   #4
mturmel
Member#: 2473
World Rally Blue
There:
Read This
Matt
mturmel is offline   Reply With Quote
Old 04-16-2002, 12:51 AM   #5
alfriedesq
Member#: 6788
2005 STI
10.9 @ 130
Next time I will go with stock - the marginal increase in spool up is NOT worth the difficultly starting off in a smooth manner without stalling
alfriedesq is offline   Reply With Quote
Old 04-16-2002, 02:49 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
my car starts fine....i think with the low compression of the EJ20 that anything less the 12 or so would make the car run kinda crappy, but then agian i thought my car wouldn't idle with the 9.6lb fidanza.
Alumnium Pros-
Lighter weight-quicker rev matching, more free horsepower
replaceable friction surface-can be replaced but is usually good for 1-2 cuts
Alumnium Cons-
More parts to break-bolts & screws retaining friction surface
starter ring gear held on by 4 or 6 bolts
Chromoly pros-
Lightweight
Rigid-made of one solid billet piece
Chromoly Cons-
Junk after 1-2 cuts it if can be cut at all
Starter ring gear is not replaceable so if it goes bad you get to buy a new flywheel
good luck in your choice.
jeremy
Old 04-16-2002, 06:13 PM   #7
WRXThis
Member#: 3960
I just ordered me a Findanza aluminum flywheel that weighs 9.5 lbs. Will be curious to see how the car responds to the new flywheel.
Old 04-17-2002, 12:36 AM   #8
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
I use the Exedy chromoly flywheel. It was inexpensive and works fine. 12 or 13 lbs. The stock one was a beast. I swear it must have weighed like 30 lbs or so. It was a porker. I have not noticed any downsides to the ligher flywheel. Revs up much faster. And the turbo spooled up faster too. Atleast till I smoked my motor.. That will be fixe soon though.
Paul...
hayscoob is offline   Reply With Quote
Old 04-17-2002, 02:18 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
stock RS flywheel was just over 25 lbs IIRC.
jeremy
Old 04-17-2002, 02:04 PM   #10
zaxrex
Member#: 9898
Water Injected Blue
Default Help?
I just got a call from my dealer, and they are covering the replacement of the clutch and fly wheel.
These items were so far down the list for me that I havenít been thinking of them. But now that the labor is covered for the change, what would y'all recommend for aftermarket parts?
Once I get my Saab sold, the WRX will be my transportation. I plan on going to a few auto-x's and would like to help realize the fuller potential for performance upgrade. I don't want to go total race/rally car specs, would like to keep it comfy for a three hour trip once a month.
Help?
P.S. would I get flamed for posting this as a new thread? I don't have that much time to search topics that are semi relevant.
zaxrex is offline   Reply With Quote
Let's talk about clutches and flywheels... ('02 WRX) Jard Mid Atlantic Impreza Club -- MAIC 25 08-04-2006 01:34 PM
let's talk flywheels WRteXmeX Transmission (AT/MT) & Driveline 13 08-12-2002 01:38 PM
Let's talk about when to change out the rods. Andrew Normally Aspirated with bolt-on Forced Induction Powertrain 10 03-04-2002 11:44 AM
Let's talk amps.... Teh Legacy Car Audio, Video & Security 15 10-19-2001 02:09 AM
Let's talk about the Rimmer Supercharger rao General Forum Archive 88 09-21-2000 07:56 AM
