Welcome to the North American Subaru Impreza Owners Club Wednesday May 27, 2015
Old 04-04-2009, 06:46 PM   #1
yamahito
Member#: 31908
1999 Impreza RS
Rally Blue
Default Oil in Spark Plug Chamber?
Just went to change my spark plugs, and noticed there is oil all in the chamber...on the outside of the plug. Is it possibly valve cover or head gasket? If so, is this a DIY fix? Help is MUCH appreciated!
-Andrew
'99 Impreza RS
yamahito is offline   Reply With Quote
Old 04-04-2009, 07:04 PM   #2
antho!
Member#: 159057
2004 ts wagon
aspen white
i used a diy from either here or nasioc, i will post when i find it
antho! is offline   Reply With Quote
Old 04-04-2009, 09:12 PM   #3
Blase
Member#: 54702
2000 impreza 2.5rs
brp
valve cover gasket. there are write ups on this on here and rs25.com just search oil in spark plug chamber. Im about to do this, just need to buy the gaskets and seals.
Blase is offline   Reply With Quote
Old 04-04-2009, 09:49 PM   #4
wirolla
Member#: 109725
2001 GM6
SRP
its the spark plug tube seals that cause the oil to leak onto the outside of the plug. Get a valve cover kit, it should come with the V/C Gaskets and tube seals!!
wirolla is offline   Reply With Quote
Old 04-04-2009, 11:50 PM   #5
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I changed my mine (valve cover gaskets) earlier this week because of the same issue. It was very straight forward and would have taken less then an hour and a half if i hadn't messed up lol.
Mike
GrimmSpeed is offline   Reply With Quote
Old 04-05-2009, 06:41 PM   #6
mtntrekker30
Member#: 158173
Default What the above others have said
I took my 99 OBS to my mechanic with the same problems. He told me this is something that I could do on my own. The above places mentioned were helpful.
mtntrekker30 is offline   Reply With Quote
Old 04-05-2009, 08:38 PM   #7
moogoob
Member#: 7101
00RS I want to fill
your mouth with spiders
I've had this for quite a loing time already, and just getting around to fixing it. Didn't seem like a huge concern since i wasnt losing any real amount of oil.
From what i've read, its easy, but the bolts are easy to break. As mentioned, RS25 has a good writeup.
moogoob is offline   Reply With Quote
Old 04-06-2009, 03:19 PM   #8
Ramon_12345
Member#: 72021
1999 JDM GC1 IMPREZA
WHITE
Ramon_12345 is offline   Reply With Quote
Old 04-06-2009, 06:09 PM   #9
antho!
Member#: 159057
2004 ts wagon
aspen white
^ that's the one i used! i fail
oil in spark plug chambers Squirl Normally Aspirated Powertrain 13 01-20-2009 11:56 PM
Oil in spark plug chamber rlpatte Outback Forum 2 01-17-2007 05:56 PM
2.2L Crankshaft Positioning Sensor needed - also, oil in spark plugs question marcus12 New England Impreza Club Forum -- NESIC 10 01-11-2005 02:49 PM
Oil in spark plug hole, 91 2.2??? rallynutdon Legacy Forum 8 10-22-2004 12:08 PM
Oil in spark plug NickSTi South East Region Forum 8 08-27-2002 08:55 PM
