Old 04-04-2009, 09:24 PM   #1
WRX_scott
Member#: 51458
2003 WRB WRX 04 Conv
2.5L/Hydra/6spd/FMIC
Default Building EJ257 debating running AVCS
I am in the process of building an ej257 with ej255 heads for DD duties. I am debating on running AVCS or non-AVCS. I am looking at different cams to use. I am looking at Cosworth, JUN, Crower and BC. Would the JUN cams work in the ej255 in a non functional AVCS enviroment? What cam profiles would you run on a setup like this? I am looking at running either the FP Red or the ATP GT3076R both setup for EWG.
To get the ej257 and ej255 heads to work properly mechanically what is going do I need to do? This build is going into a 03 WRX but I am going to be running Hydra.
What cam buckets should I go with or how do I know which ones to go with? Would EJ20 aftermarket valve springs like JUN work on the ej255 heads?
WRX_scott is offline   Reply With Quote
Old 04-04-2009, 11:16 PM   #2
gold rush
Member#: 90110
2004 wrx wagon
The pick-ups on the ej255/257 cams are different than ej205/207.
gold rush is offline   Reply With Quote
Old 04-04-2009, 11:18 PM   #3
WRX_scott
Member#: 51458
Pickups are for? AVCS? I am not sure what you are talking about.
Old 04-04-2009, 11:52 PM   #4
sense of nature
Member#: 112759
2002 STi Mikey Tuned
SexyRP
Cam position sensor pick ups.
sense of nature is offline   Reply With Quote
Old 04-06-2009, 09:25 AM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
however, you can get a normal cam sensor location on the 257 heads...so a relatively minor deal.
all the valvetrain components are interchangable...however I will say to stick with a cam that was designed for the EJ25 and not the EJ20 for that bottom end.
Build EJ257 muths66 Built Motor Discussion 25 01-02-2009 05:37 PM
Running EJ257 heads non-avcs MS WRX Built Motor Discussion 3 07-01-2008 11:38 AM
running avcs with link ecu??? scooby Engine Management & Tuning 8 12-19-2004 11:56 PM
What exactly Do I need to run AVCS? Javier Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-14-2004 08:18 AM
Running AVCS heads without AVCS? Rizzo314 Subaru Conversions 5 06-01-2004 05:46 PM
