Old 04-04-2009, 11:20 PM   #1
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Default Let's do some late night engineering
What I attempted to do was build my own smoke machine to look for vacuum and boost leaks. Here's what I did:
Made a fitting for the compressor
Used a T and made a reservoir at the bottom for liquid smoke and inserted a glowplug from the top.
Made a cap to go to the turbo inlet.
Here's what the test setup looks like
And the first test didn't go so well. The glowplug got the setup too hot and ended up melting the nylon tubing on the barb wires.
So I replaced them with rubber ones. But I'm still not getting smoke coming out the tubes. I hear a sound coming from the tube, but not smoke. It kinda sounda like boiling water. So I'm not sure what's going on. It's definatly hot enough to get smoke. I did have some liquid smoke pour out the tube ends. My guess is that it's from the liquid getting heated and expanding.
For the first test I didn't have the compressor hooked up. Maybe it's not getting enough air to make smoke. So the liquid is hot enough to make smoke, but it just needs the air to get pushed though.
what do you guys think? I thought I'd 'run this by you guys before I end up offing myself somehow
Bad Noodle is offline   Reply With Quote
Old 04-04-2009, 11:24 PM   #2
todeswalzer
Member#: 191495
'05 WRB GTX3071R
JDM V8 EJ207 USDM 6MT
interesting idea, i like the way yo think...plus i lold hard at the end
try it with the compressor hooked up
good luck mate
todeswalzer is offline   Reply With Quote
Old 04-04-2009, 11:30 PM   #3
sorrowfulkiller
Member#: 170439
I <3 Lamp
I like it.... great diy!
sorrowfulkiller is offline   Reply With Quote
Old 04-05-2009, 12:17 AM   #4
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
haha interesting , nice writeup!
vik_wrx is offline   Reply With Quote
Old 04-05-2009, 12:48 AM   #5
rubelcon
Member#: 41693
not DOT approved :(
notice he has not posted again? I hope he did not off himself.
rubelcon is offline   Reply With Quote
Old 04-05-2009, 02:03 AM   #6
bcWRX-02
Member#: 181780
2002 WRX Sedan PSM
'01 CBR 600 F4i
haha this is the kind of stuff that ends up winning a Darwin award. Cool idea, hope it works out!
bcWRX-02 is offline   Reply With Quote
Old 04-05-2009, 02:05 AM   #7
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
Indeed....please keep us posted with results.
Team Scream is offline   Reply With Quote
Old 04-05-2009, 03:32 AM   #8
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
meh...dont really need smoke......just a quiet place to listen for leaks and a bottle with soapy water in it
Old 04-05-2009, 03:58 AM   #9
WhiteRabbit1021
Member#: 188930
2003 WRX
Of all the ways to create smoke, this one surprisingly looks to be the most dangerous way I've seen.
Nifty setup, post results if you haven't offed yourself.
WhiteRabbit1021 is offline   Reply With Quote
Old 04-05-2009, 04:31 AM   #10
wingnut01
Member#: 152837
2002 BMW 330Ci
not terribly sure if oxygen is needed entirely for the liquid smoke process but without a negative pressure differential the smoke will only half heartedly roll out or into the tubes, lazy waterfall style, the compressor should fix that problem pretty nice, although, too much pressure and it will disperse the smoke too much(if you have the compresser "pushing" the air) otherwise pull the system down to a vacuum to otherwise draw the smoke in the direction you want. and from what i remember that stuff burns off pretty quick so might need a larger reservoir.
wingnut01 is offline   Reply With Quote
Old 04-05-2009, 01:25 PM   #11
hotrod
Member#: 14141
2002 Impreza WRX
Are you using the "Liquid smoke" used in cooking?
The stuff they use in smoke making machines is a light oil, you can buy it at theatrical supply stores. (or you can just rent a theatrical smoke maker for the day)
Larry
hotrod is offline   Reply With Quote
Old 04-06-2009, 01:32 AM   #12
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Maybe you need to put some weed in it.
Counterfit is online now   Reply With Quote
Old 04-06-2009, 02:17 AM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
Im just hoping that the op d0000d didnt hurt himself or burn down his house with that thing
Old 04-06-2009, 07:16 AM   #14
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
na, just haven't had time to go back and try again. I have the battery charger set at the 2amp trickle charge setting, which I'm hoping is good enough not to blow up the neighborhood in case the leads make contact.
I did try the setup with the hoses off, but didn't get much smoke coming out of the fittings. In fact, I didn't get any smoke at all.
The only smoke I got was from the liquid smoke I spilled onto the contraption and then I switched on the 12amp setting and hoped for the best. At that point, the whole thing got hot and the outside started to smoke, but i never saw anything come out from the inside. So I decided to back off down to 2 amps
either way, I can't figure out why i'm not getting smoke from the inside. It should be smoking like a chimney since it's definitely full.
I'm not sure if I need a different setup or im using this setup incorrectly somehow...
Old 04-06-2009, 09:15 AM   #15
thedoc13
Member#: 184017
I think you need to figure out how much heat is actually necessary to heat up the liquid to create smoke. I also think you might not be getting enough air for it to create smoke.
thedoc13 is offline   Reply With Quote
Old 04-06-2009, 10:47 AM   #16
Uncle Scotty
Member#: 16200
OK buy Nates beans
you need different smoke generating media
Old 04-07-2009, 08:11 PM   #17
hotrod
Member#: 14141
2002 Impreza WRX
You can lead a horse to water --- but
Larry
Old 04-07-2009, 08:22 PM   #18
Cruzin8
Member#: 207894
nice work.
Cruzin8 is offline   Reply With Quote
Old 04-07-2009, 08:26 PM   #19
2:43AM
Member#: 190273
05 WRX evoIII-16G
Mesquite, let's eat!
I think it's a good idea, but the volume of smoke needed for your checks may not be adequate. The small tubing and small air volume will only create "whisps" of smoke...maybe...and not enough to fill intakes, tubing, etc. with nice think-n-rich smoke. Just my thoughts.
2:43AM is offline   Reply With Quote
Old 04-07-2009, 09:17 PM   #20
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
I had some time to mess with it tonight so here's the setup again:
I set the battery charger at 2 amps and put a drop of smoke on the outside of the resivoir, so when it started smoking I knew it was ready. Then I turned the pump on:
Then I hooked it up to the car and wala:
found my boost leak right away. It's funny cus i tried to find this with the regular setup and soap and water and I couldn't find it. This took all of 5 min to do.
I'm a fan
Old 04-07-2009, 11:16 PM   #21
imprezaowner27
Member#: 131299
2006 Impreza
this is pretty neat stuff
imprezaowner27 is offline   Reply With Quote
Old 04-08-2009, 12:16 AM   #22
kcook
Member#: 78074
2005 STi
so you have a crack in the i/c pipe?
kcook is offline   Reply With Quote
Old 04-08-2009, 06:48 AM   #23
Bad Noodle
Member#: 174442
2007 SuperWagon
I don't spell well
Na, you can't see it since it's tough to get a picture, but I had a leak in the coupler. Even though it was cranked down as hard as it would go, the sucker was leaking. I don't know why it didn't make soap bubbles either. But this found it easily
Old 05-19-2009, 08:18 PM   #24
BeBop86
Member#: 147776
'02 Impreza WRX
'85 Toyota Corolla
That's pretty cool, i'll have to try it.
BeBop86 is offline   Reply With Quote
Old 12-04-2013, 11:07 PM   #25
tenchu
Member#: 64147
1993 STi RA V LTD
Green
Can you post up a step by step of your SUCCESSFUL setup? I'd really like to give this a try on both of my turbo subarus.
tenchu is offline   Reply With Quote
Some late night pics of the GC and my new rotas... evoeater8 Member's Car Gallery 24 05-08-2006 04:57 PM
anyone up for some late night halo suby4ub Off-Topic 8 01-20-2006 12:16 AM
some late night photos. racer98 Off-Topic 18 11-05-2005 08:19 AM
Some late night drive-thru WAPCE well_armed Off-Topic 26 06-05-2004 03:38 PM
Wow it's coming down pretty hard... Who wants to go for some late night rallying? inzomniak Vancouver Impreza Club Forum -- VIC 34 12-21-2000 12:05 AM
