Old 04-04-2009, 11:37 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Knocked Cam Plug In To Far. Any Way to Save?
I'm not sure how similar my EJ253's heads are to y'all's fancy-pants DOHC turbo heads, so I'm going to give you guys too much info at the risk of telling you things you already know.
The EJ253 heads stack up like this (top of the list is facing the outside world, bottom of the list is against the headgasket):
Valve rocker cover
In/Ex Valve Rocker Assemblies
Cam Cap (sort of a metal frame that holds the cam against the head)
Camshaft
Head body
The ends of the camshaft protrude out the front and the back of the complete head. On the front, there's a ring-shaped Cam Seal. On the back, there's a disc-shaped Cam Plug that just covers the entire hole the cam pokes out of. According to the factory manual, the Cam Plug and Cam Seal are to be inserted after the Cam Cap and Rocker Assemblies have been torqued into place.
Well, it all went perfectly until I tried to put the Cam Plug into place. I gave it a little too much of a hit with the hammer and drove it in until the center of the Plug hit the cam itself. This means that if I were to start the motor, the cam would be grinding a hole into the Cam Plug.
I need to pull the Cam Plug out about 1/8-3/16 of an inch. There's no way to push on it from the inside. Can any of you think of a way to pull the Cam Plug out without having to totally remove and reinstall the Rocker Assemblies, Cam Cap, and camshaft a second time?
Thanks.
Old 04-05-2009, 12:40 PM   #2
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Dig it out and replace it with a new one. If you were to get it out without killing it you would likely see that it would be deformed. This will lead to a leak. Trust me. Just replace it. They are like $5.
Tony
Closed a Word File without Saving, any way to recover it? jmonusko Off-Topic 11 10-29-2011 12:05 PM
Found a little lizard in my shop. Any way to revive him? Hurley959 Off-Topic 35 10-01-2009 03:05 PM
Did an amazing drift on a license test, wasn't my best time... any way to save??? Absolut Off-Topic 5 04-04-2006 04:38 PM
Is there any way to know if I'll be able to get a car loan in a hurry? linux>windows Off-Topic 6 01-17-2006 12:48 AM
Any way to save a floppy disk? wrxlvr Off-Topic 12 01-22-2004 03:05 PM
Message Board Statistics All times are GMT -4. The time now is 02:17 PM.
