Old 04-04-2009, 11:49 PM   #1
benw
Member#: 103320
1998 swapped
Forester L
Default oil smell and consumption only when coming to a stop?
On my built motor I am losing oil approximately 1 qt every 750 miles. There is no oil in the breather lines, no oil in the intake, or intercooler piping. However, when I come to a stop (usually I am engine braking in 3rd gear then I clutch in and brake) I can smell oil as the fumes "catch up" to me at the stop light/sign.
I have never seen any smoke out the exhaust. Cold start, hot start, driving it hard, etc. I have had buddies follow me around while I beat on the car and nothing.
I was thinking about pulling the downpipe in case the turbo's seal is leaking into the turbine housing, but wasn't sure.
benw is offline   Reply With Quote
Old 04-05-2009, 07:12 PM   #2
flycaster
Member#: 60142
2011 WRX
Grey
That's a lot of oil, Ben, even for a built motor. What kind of snail is on there?
flycaster is offline   Reply With Quote
Old 04-05-2009, 07:27 PM   #3
n2oiroc
Member#: 141952
15 legacy 16 wrx
pull the downpipe. i had the same thing for a little while then the oil smoke started pouring out!
n2oiroc is offline   Reply With Quote
Old 04-06-2009, 12:00 AM   #4
benw
Member#: 103320
1998 swapped
Forester L
SZ55 bought from a friend used. could be the turbo I suppose, I had a VF39 one time that went out, but it leaked oil at hot idle, you could see it puffing out.
Old 05-08-2009, 12:39 AM   #5
benw
Member#: 103320
1998 swapped
Forester L
just want to update that this has since stopped, and oil consumption is appx 1/2 qt per 1000 miles. my clearances are pretty loose so I'm OK with this.
Old 05-08-2009, 01:00 AM   #6
flycaster
Member#: 60142
2011 WRX
Grey
Sweet, that's more like it. Boy, I bet you're breathing a little easier, huh?
Old 05-08-2009, 11:57 AM   #7
benw
Member#: 103320
1998 swapped
Forester L
that problem is solved, now I have a new enemy... upgraded piston and valvetrain noise and the stock knock sensor are fighting like two scorned lovers on Jerry Springer! But that's a story for another day.
Old 05-08-2009, 12:30 PM   #8
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
You will see more blowby if you do a lot of engine braking.
Old 08-01-2009, 01:36 AM   #9
06Limited
Member#: 118112
2006 WRX Limited
Running in to the same issue currently (less than 1,000 miles on my new built motor) Hopefully it goes away as yours did
06Limited is offline   Reply With Quote
Old 08-01-2009, 04:08 PM   #10
AdamBOMB_STi
Member#: 103419
04.7 STi
LA Sleeved 2.5,35R,Hydra
My motor used to consume more oil than what I anticipated. It wasn't until I tuned for 25+psi where the motor started to fully break in. I never ran synthetic oil and glad I didn't.
AdamBOMB_STi is offline   Reply With Quote
Old 08-01-2009, 06:53 PM   #11
bearpaws1973
Member#: 145025
1992 Typhoon
06 wrx built to the hilt!
Check that turbo anyway. If you smell the oil then it is there. You want to avoid that oil getting in the combustion chamber and lowering your octane. The built motor may turn into your broke motor when you have enough detonation when your hitting full boost. Don't loose thousands of dollars of work and time for possible leaky seals. Good luck.
bearpaws1973 is offline   Reply With Quote
Sounds like a ball bearing rolling back and forth when coming to a stop. jay25RS Newbies & FAQs 15 02-25-2010 07:10 AM
Low oil pressure light when coming to a stop. pzary3233 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 04-05-2009 12:35 PM
car doesnt want to idle when coming to a stop dukeduster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 36 01-22-2009 04:00 PM
Front end creaking when coming to a stop rdy4flt Brakes, Steering & Suspension 20 06-11-2007 03:24 PM
clunk from the front when coming to a stop kettsupp Brakes, Steering & Suspension 8 06-05-2006 12:43 AM
