#1 |
Member#: 88706
Vehicle:2002 WRX Black |
hey guys,
call me dumb but i've got some questions about the setup im running. so far, i have an 02 wrx hybrid, vf 39, larger tmic, turboback, gutted uppipe, and a k&n drop in filter. all installed with no tune. im working on getting 565cc injectors and a walbro pump, and then a tune. anyway, first off, i did the sti block swap, and i was advised to get a tune right away. well i never did and i drove the car like that for over a year. it ran great. then recently i swapped the vf39, and the larger tmic with a modded perrin ypipe. still no tune. i've been told that i will max out my injectors, which i dont seem to be, and that my car wouldnt run right with the 2.0 litre ecu, but i have not noticed any negative effects. runs smooth and great power gain. so whats up? is everyone tune paranoid? im not bagging on anyone im just confused.
#2 | |
Member#: 163445
Vehicle:l33t ******* 12.07@115.9mph-EJ205 |
Hope your pockets aren't empty yet - you'll be buying a new shortblock here real soon... Just out of curiosity was your 205 modded and untuned when it let go? Don't go blaming poor bearings - bearings fail because of detonation too.. -Jerod |
#3 |
Member#: 186966
Vehicle:2004 WRX Sedan Stg.2 WRB |
In all honesty, I am suprised it hasnt popped yet.
That being said, if the engine going on you in the future isnt a huge concern, just leave it and keep driving it until it dies (or doesnt, who knows.) I however, would get the larger injectors and get it tuned. |
#4 |
Member#: 194804
International
Vehicle:2004 VF43 WRX - sold WRB |
Tune asap
#5 |
Member#: 15652
TXIC
Vehicle:2002 2.5L WRX Wag. 160K club |
When I did my swap I flashed the stock 02 tune in as well to see how it would run. It was my experience that timing was way down and that the car would give loads of fine learning knock correction. After bumping the timing up, it went away. Anything over ~10-12 psi on a TD04 will max the injectors after 5K rpm, but that is at a target AFR of sub 10.
So far, I have been using the 06 WRX map as a reference, which has been really good so far. The biggest thing that helped was removing the CL/OL delay... |
#6 | |||
Member#: 88706
#7 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
Do a compression test before you tune just to humor us ok.
#8 |
Member#: 163445
Look we are not trying to be mean, or at least I'm not, its just sad that you've got so much money into it and let it go like you have.
A tune is 99% of a turbo cars reliability and drive ability whether you want to believe it or not. I mean don't get me wrong it is your car, but don't cheat yourself man. Jerod |
#9 |
Member#: 130063
Vehicle:2003 WRX Silb |
ummmmmm
you should just give me your motor because you obviously don't like it. |
#10 |
Member#: 101491
South East
Vehicle:2002 wrsti wrb |
Your extremely lucky to still have your car running, whether you notice or not the difference the damage is still being done, look at it this way your ecu still thinks its a got a stock 2.0 in it but the reality which your fully aware is that you don't. GET A TUNE ASAP!!!!!!
#11 | |
Member#: 88706
so what terminal factors am i facing? smaller injectors causing ______? |
#12 |
Member#: 163445
Ring/land damage and bearing damage from detonation...
You have a larger bore and a totally different VE plot now with the hybrid setup.. You running your OE timing and fueling will really screw things up... Since your fueling is maf based - only to about 190 g/s and your 2.5 even with the stock turbo will flow that easily your over running your ecu's fueling ability (unless tuned) Your timing for the change in VE/displacement will change- your ecu will compensate to a certain point - but you will see a night/day x100 difference in driveability and way safer power... IF it lasts long enough to get a tune... Think of it this way your 2.0 could take in 200 grams of air - it would fuel to almost that (2.0's will take in more but not much more on the stock turbo) your 2.5 has alot more "space" for that air to fill - however your stock tune does not know that and is only applying fuel till a certian point - anything after that you just run lean - which creates high egt's and a very high knock tendancy.. Knock - heat kill engines in a hurry... Your lucky to have made it this long to be honest with you. I personally wouldn't start the car without a quick safe tune - to drive it to go get tuned... Its a pretty serious thing - as on a turbo motor/any motor a tune can/will determine how long an engine lasts - if its poor at least... -Jerod Your only advantage is your lack of power making your doing with the ****ty tune and small turbo - that is probably the only reason it still runs... |
| Thread Tools | |
| Display Modes | |
| 2002 WRX Hybrid | Pulse382 | Factory 2.5L Turbo Powertrain | 11 | 09-05-2009 07:10 PM |
| Fs/ 2002 Wrx Hybrid | odehboy | Mid West Subaru Owners Club Forum -- MWSOC | 0 | 04-14-2009 01:20 PM |
| **feeler**2002 WRX Hybrid (3rd grear bad) 2k on build | odehboy | Private Vehicle 'For Sale' Classifieds | 0 | 02-25-2009 10:54 AM |
| 2002 WRX Hybrid running in engine. Pre tune config advice. | toecutter | Built Motor Discussion | 3 | 05-01-2008 04:34 PM |
| 2002 wrx rebuild advice | LTXX | Newbies & FAQs | 11 | 04-30-2008 02:18 PM |
