Old 04-05-2009, 06:06 AM   #1
INFMIS
Member#: 174494
Default New built motor, priming oil pump?
Hey i have a new fully built motor, first time doing this so dont want to do anything wrong!
I have an external oil cooler with remote oil cooler.
How to i go about priming the oil pump?
All help will be greatly appreciated!
Thanks
INFMIS is offline   Reply With Quote
Old 04-05-2009, 06:17 AM   #2
alcoolaid
Member#: 134949
'07 SWP STi
Twinscroll ViPec Anti-lag
Remove spark plugs, remove the ignition fuse inside the car, connect some jumper cables to the battery or something and just crank it till you see oil pressure.
alcoolaid is offline   Reply With Quote
Old 04-05-2009, 07:32 AM   #3
jays05
Member#: 78165
05 STI 35r + e85
^ yup. If you are not 10000% sure which one is the IGN fuse, just pull the plugs on the coil packs and the injectors. Only takes a couple minutes.
jays05 is offline   Reply With Quote
Old 04-05-2009, 12:38 PM   #4
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Or remove the connector for the fuel pump relay.
Old 04-05-2009, 09:57 PM   #5
wrxG
Member#: 155087
02 WRX
unplug the brown main plug and keep cranking till oil light goes off
wrxG is offline   Reply With Quote
Old 04-06-2009, 08:46 AM   #6
tekfoc
Member#: 21392
2007 IMPREZA WRX STI
urban gray
A old trick I use to do is take a hand pump fill it with oil remove oil filter, stick the rubber hose in to oil thread fitting and start pumping the oil to the block to remove any air pockets.
when you start it you should have immediate oil pressure .
A little messy but it works , just keep a pan ready .
tekfoc is offline   Reply With Quote
Old 04-07-2009, 05:27 PM   #7
charliew
Member#: 125304
We prelube the motor with a pressurized oil supply through the oil pressure sender port till our aftermarket oil pressure gauge said 40 psi then turned the motor through a few cycles and put the stock sender back on and started it.
charliew is offline   Reply With Quote
Old 04-07-2009, 06:46 PM   #8
sponaugle
Member#: 4498
WRX H6-3.0 Turbo
www.surgelinetuning.com
You know, on newer drive by wire cars, you can just hold the accelerator to the floor while cranking. AT 100% TPS, the car will not fire the injectors. No need to do anything else.
Jeff
sponaugle is offline   Reply With Quote
Old 05-13-2009, 09:15 PM   #9
STI_KLR
Member#: 189660
'02 IAG BUILT 2.5L
Whistles go WOOOP WOOOOP
Ok, so basically just pull the plugs off the coilpacks (or the IGN fuse) along with the fuel pump relay? Is there anything else I should be looking out for? I plan on starting my new hybrid tomorrow..
STI_KLR is offline   Reply With Quote
Old 05-13-2009, 09:20 PM   #10
FunkRider
Member#: 195055
Ideally like said you want to remove the spark plugs so it doesn't build any compression on the rod bearings until oil pressure is made.
FunkRider is offline   Reply With Quote
Old 05-13-2009, 09:28 PM   #11
unclemat
Member#: 114530
2005 LGT 6MT wagon
Fuel pump fuse is not enough. Disconnect injectors (or engine harness, but some engines won't crank with harness disconnected). You don't want any residual gas wash the cylinder walls while you are priming the engine. Very important.
unclemat is offline   Reply With Quote
Old 05-13-2009, 11:46 PM   #12
Team Scream
Member#: 121532
2006 FXT/STi 6MT
01 Aerosim GC8 Coupe
I like charlie's idea that is pretty damn nifty.
Probably have to drain a bit of oil out once you are done firing it the first time but still....that's a great idea...
What kind of pump charlie? hand pump of some kind?
Team Scream is offline   Reply With Quote
Old 05-14-2009, 12:10 AM   #13
colingilchrist
Member#: 138516
2011 Audi A3 2.0 TDI
Lava Gray
I like Jeff's idea of just holding the pedal to the floor and cranking the engine over. How much easier can you get?
colingilchrist is online now   Reply With Quote
Old 05-14-2009, 12:43 AM   #14
flycaster
Member#: 60142
2011 WRX
Grey
No kidding - once again, good info, Jeff.
flycaster is offline   Reply With Quote
Old 05-14-2009, 12:57 PM   #15
Team Scream
Member#: 121532
2006 FXT/STi 6MT
I agree that Jeff's idea is the simplest but you are still rotating the engine with no oil barrier anywhere other than your assembly lube which should be fine in most cases, but Charlie's method ensures there is oil everywhere before you crank it the first time.
Both great ideas really.
Old 05-14-2009, 04:44 PM   #16
Carreragt2e
Member#: 130877
07 STI
Grey
good info: Im about to start my motor this weekend and this never crossed my mind. You may have saved my motor.
-Eric
Carreragt2e is offline   Reply With Quote
Old 05-14-2009, 07:29 PM   #17
STI_KLR
Member#: 189660
'02 IAG BUILT 2.5L
This is what I did today:
Pulled off the fuel pump cover and just un-plugged the harness directly.
Had no coil packs or spark plugs in.
Pulled the crank sensor harness off.
10 second intervals of cranking until the oil light went off.
When I fired her up, she started on the first try. It was actually scary how easily it started.
Old 05-14-2009, 07:53 PM   #18
dunk
Member#: 15359
Another Reason why I love my accusump.
-Duncan
dunk is offline   Reply With Quote
Built motor - drinks oil, blue smoke under boost - help! unclemat Built Motor Discussion 20 04-14-2009 10:03 PM
Built EJ207 ,what oil pump? Sammidavis Built Motor Discussion 13 01-27-2009 06:05 PM
Need to prime oil pump? Mechie3 Factory 2.5L Turbo Powertrain 1 06-25-2008 02:39 PM
Priming Oil Pump? hypoxvi Factory 2.0L Turbo Powertrain 6 06-20-2008 06:30 AM
Priming oil pump John*G Normally Aspirated Powertrain 5 07-03-2004 06:44 PM
Message Board Statistics All times are GMT -4. The time now is 11:09 AM.
