Old 04-15-2002, 07:09 PM   #1
PeterJ
Member#: 14727
2002 impreza RS
Default A/F ratio
I'm somewhat confused on this issue. Does my car (as set from the factory) run rich, or lean. My guess is that it is rich, but that doesn't make sense for emissions... Anyway, it seems like people have varying opinions. How about any changes in A/F throughout the rpm range? Does anyone know?
PeterJ is offline   Reply With Quote
Old 04-15-2002, 07:29 PM   #2
Evan J. Kelly
Forever Scooby Newbie
Member#: 11172
2000 GC8 RS Coupe'
FlatBlack&BlueRidge Pearl
Rich, although you need a new ecu to really take advantage.
Evan J. Kelly is offline   Reply With Quote
Old 04-15-2002, 07:29 PM   #3
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Lightbulb A/F ratios
Your car's air fuel ratio fluctuates (goes up and down, back and forth) to rich-lean-rich-lean over and over again. The only time your car should be running rich is during startup and WOT (wide open throttle). During start-up, once your car warms up and reaches it's operating temperature, it should go back and forth between rich and lean constantly.
If it doesn't go back and forth over and over again (Except for WOT and start-ups), then you have a bad O2 sensor. Hope that helps.
Kevin Thomas is offline   Reply With Quote
Old 04-15-2002, 07:40 PM   #4
PeterJ
Member#: 14727
2002 impreza RS
Default thanks
Thanks guys...not to misconstrue the issue, but my questioning regarded this initial issue- At what point in the rpm range would a free flowing intake, or even a ram-air intake help the engine produce power? So I guess the answer is, "at WOT" -any more input on A/F ratio's would be helpful. -Thanks
Old 04-15-2002, 08:40 PM   #5
Evan J. Kelly
Member#: 11172
2000 GC8 RS Coupe'
Default Re: A/F ratios
No it doesn't.
Have you looked at a A/F gauge?
The only time it runs lean is at startup.
Old 04-15-2002, 09:06 PM   #6
Kevin Thomas
Member#: 110
1989 1989 XT6
Default Re: Re: A/F ratios
Originally posted by Evan J. Kelly
No it doesn't.
You are partly correct. The A/F ratio does read lean. Sometimes it doesn't even move during startup. The reason for this is because your oxygen sensor isn't working properly. Your oxygen sensor has to get up to operating temperature (Somewhere north of 600F) before it is operating correctly. During this time, your car runs rich.
Old 04-16-2002, 12:03 AM   #7
PeterJ
Member#: 14727
2002 impreza RS
Default verify
So just to make sure...The two instances my engine runs rich (established so far) are upon start up and at WOT. Correct?
Old 04-16-2002, 01:32 AM   #8
wistful
Member#: 745
2004 STi
Java Black Pearl
I have an autometer a/f meter with its standalone o2 bung and I get some crazee stuff.
when i turn the car on... it starts in rich.. and slowly makes it way to hyper-ultra super jo-mama off the scale lean. (that's when I know its warmed up).
when I run.. 0-45% throttle its lean. when its at idle.. its off the scale on the lean side. IF i'm just slightly on throttle its really in the lean. 45%-85% its stoich. 85%+ it just gets super rich.
any explanations?
Don
wistful is offline   Reply With Quote
Old 04-16-2002, 10:41 AM   #9
PeterJ
Member#: 14727
2002 impreza RS
Default wistful
I think that sounds normal...from an emissions standpoint anyway. To get lower emissions, en engine must usually run lean. During startup/warmup, however some extra fuel helps get it going and at wot it helps make more power. At any other time, the engine runs lean to reduce polution. That's my understanding...
Final Drive ratio & 6th gear ratio? scuzzy Transmission (AT/MT) & Driveline 1 11-09-2013 10:54 AM
Learning Gear Ratio and Final Drive Ratio madwrxing Transmission (AT/MT) & Driveline 0 04-16-2006 10:02 PM
97L gear ratios vs. RS ratios? (MT) Murray Transmission (AT/MT) & Driveline 7 08-12-2003 11:26 AM
Steering rack specs quoted as overall-ratio or rack-ratio? Macabre Brakes, Steering & Suspension 2 07-02-2003 10:54 PM
Gear ratios and differential ratio for 95 legacy and 95 imprezza ciper Transmission (AT/MT) & Driveline 0 06-14-2002 06:58 PM
