Old 04-15-2002, 07:14 PM   #1
PeterJ
Member#: 14727
2002 impreza RS
Default breather hoses
As I understand, there are 3 small hoses that connect the crank case to the airbox... Has anyone disconnected these? Two of them blow air and oil particles out, and one sucks clear air in. I have seen those with turbo kits have a tiny air filter on the "clean air"one... What would happen if you connected them all and made a closed loop? ...it would make custom intakes a lot easier. -Thanks
PeterJ is offline   Reply With Quote
Old 04-17-2002, 12:07 AM   #2
cammy712
Member#: 6576
2001 Impreza 2.5 RST
Default Breathers
I have all three of my breather lines run to smaller individual filters. I know you can get small breather filters from Weapon-R and i have seen cheap ones at pep boys. Doesnt really affect anything except lets the intake use all pure air.
cammy712 is offline   Reply With Quote
Old 04-17-2002, 07:16 AM   #3
Joe Alejandro
Member#: 9004
'94 FF 1.8RS
Rally Blue
Default Re: breather hoses
Making a closed loop would choke your enging by keeping crankcase vapors in. Fresh air needs to be recirculated to allow excessive amounts of blow-by gases to flow back through the crankcase vent tube into the intake to be consumed by normal combustion. Joe
Joe Alejandro is offline   Reply With Quote
Old 04-18-2002, 09:10 AM   #4
Stealthbmbr
Member#: 13823
2009 Legacy 2.5i SE
C A P S CAPS CAPS CAPS
The pcv valve needs to be connected to a vacumm source, like the intake. All three hoses are connected to the black box, which means there is a vacumm on all three of them. I connected all three together with t fittings and ran them to my new intake. So I have one vacumm source drawing on all three lines at once.
Stealthbmbr is offline   Reply With Quote
Old 04-18-2002, 09:18 AM   #5
slater
Member#: 5848
1992 vw corrado vr6
silver w/ schrick/quaife
okay, and if i understand correctly, the PCV valve is on the crankcase breather tube?
would it be REALLY bad if this tube was plugged? if so, what are the side effects?
when i bought my car, the crankcase breather tube was plugged (the tube that runs into the airbox, but not the one that goes in after the throttle body), and that really rubbed me the wrong way. it's not that way anymore, it's running back into the stock airbox.
peter
slater is offline   Reply With Quote
Part numbers for EJ257/ JDM EJ205/207 breather hoses? crazyhorse Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 01-07-2015 05:22 PM
Smoke coming from breather hoses the spacecowboy Normally Aspirated with bolt-on Forced Induction Powertrain 10 01-04-2004 11:31 PM
Strange sludge in valvecover breather hose Turbotegra Normally Aspirated with bolt-on Forced Induction Powertrain 12 11-30-2003 03:11 AM
breather hose??? zacek Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 06-28-2002 01:23 PM
I need a stock breather hose, anybody have one? Boom New England Impreza Club Forum -- NESIC 1 07-14-2000 08:46 AM
