Old 04-05-2009, 02:30 PM   #1
hakeem
Member#: 17426
Default ECU reset gives my STi about 75 more hp for 15 mins...why?
06 STi with ~45k miles on it, always well maintained and serviced. Bone stock all the way down to the air filter. Recently I started to get the feeling that my car was not at full power, or boost was reduced, or something was going on.
The other day I had not driven the car in a few weeks and the battery had died (my fault, unrelated). After charging it, the car felt like it had at least 50-75 more hp for about 15 minutes. After that, it returned to its old ways of having mediocre power. Now everytime I reset the ECU I am given this power burst for a short period of time.
There is no CEL and everything else appears to be normal. I've searched around for this, it sounds like limp mode, but that usually appears to be accompanied by a CEL as do most of the other problems I've found.
Any ideas? What is wrong with my subie!
hakeem is offline   Reply With Quote
Old 04-05-2009, 02:33 PM   #2
MasterKwan
Member#: 98961
2003 WRX
Sounds more like you're using crappy gas and it takes the ECU a while after reset to adjust to the bad gas. If it was me, I'd log it and see what the ECU is thinking.
Old 04-05-2009, 03:05 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
yep.......if the OP added some 100 octane fuel he may see why it is imperative to use the highest octane fuel possible to get the best power and why the stock ecu map sucks
Old 04-05-2009, 03:14 PM   #4
hakeem
Member#: 17426
I am using pump 91...it's not feasible for me to use 100 all the time unfortunately. Can the stock map be modified to still provide decent power using 91 safely?
Old 04-05-2009, 03:21 PM   #5
BlackFighter
Member#: 193940
2004 WRX STI Black
RalliSpec Shortblock
Ya lower boost or not redlining it.**** man i love my sti and use 93 everyday in it. Will NEVER put anything lower, b/c i know that even 93 will be lower octane with all of the mixing.
BlackFighter is offline   Reply With Quote
Old 04-05-2009, 04:21 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
d00000000000000d
the FIRST thing you dhould do with any of these cars is get a tune from a competent tuner even if your car is stock
Old 04-05-2009, 04:29 PM   #7
testify
Member#: 196517
2007 n00b rocket
urban grey metallic
Those are some impressive power losses/gains you seeing on the butt dyno.
testify is offline   Reply With Quote
Old 04-05-2009, 04:52 PM   #8
STIBungy
Member#: 51684
Usually when you reset the ecu, it runs like ass for a bit until the IAM goes up to 1.
STIBungy is offline   Reply With Quote
Old 04-06-2009, 09:43 AM   #9
06mattsti
Member#: 174796
2006 STI
+1. i have to get my dynamics multiplyer to 1 from .5 on the apv2 everytime i reset the ecu, or my car stalls when i slow down everytime.
06mattsti is offline   Reply With Quote
Old 04-06-2009, 09:46 AM   #10
Uncle Scotty
Member#: 16200
OK buy Nates beans
that is a tuning issue that you need to address
Old 04-06-2009, 12:32 PM   #11
flycaster
Member#: 60142
2011 WRX
Grey
For some [good] reason the car is quickly learning to pull timing and richen up, probably both. Frankly, you ought to be glad it's doing that - it is trying to keep your motor alive. As Scotty suggested, get it tuned pronto.
flycaster is offline   Reply With Quote
Old 04-06-2009, 01:07 PM   #12
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
That's a fueling issue, not an IAM issue, I have the same problem. It takes my car about a day to figure out how to idle after an ECU reset, I haven't tracked down the problem yet.
OP - sounds like your car is pulling timing to prevent detonation, probably because of the 91 octane fuel. Switch to a higher octane or get a tune.
Old 04-06-2009, 01:20 PM   #13
hakeem
Member#: 17426
Thanks guys. I actually mixed in 6 gals of 100 octane on Sunday and it's still doing the same thing (although it takes longer to happen). Unfortunately here in cali 91 octane is the best we can get at the pump.
Guess I'll take it in for some tuning and see what happens.
Need to borrow an AP Dongle compatable with 08' STi for 15 mins TK421 Southern California Impreza Club Forum -- SCIC 9 04-20-2009 09:10 PM
Will the us 07 sti turbo produce more hp than the us 04-06 sti turbo? silver07sti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-28-2007 06:52 AM
My NEW STI - (Now with more HP inside!!) runvusofme South East Region Forum 4 04-01-2007 01:34 AM
How do I give my 2002 WRX AT more kick? ....chip? heavy dan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 04-09-2004 02:33 PM
('93-'01) I just realized I need about 200 more hp and 2 more gears WRXwannbe Impreza Forum 4 05-05-2001 06:25 PM
