Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 04-05-2009, 07:50 PM   #1
mtntrekker30
Member#: 158173
Default Car losing power on acceleration
I have a 99 OBS with 135,000 miles, manual transmission, new plugs/wires/airfilter/clutch/timing belt. My car seems to have a loss of power when I'm trying to accelerate (1000-2300 RPM). As I progress through higher (2300 and greater) RPM the power seems to come back.
I just moved from Salt Lake (elevation about 4500 ft) to Pennsylvania (about 1400 feet) a few months ago. I'm wondering if elevation change may have something to do with it or possibly the gas they sell here. I've changed everything I can think of.
Any thoughts are greatly appreciated.
mtntrekker30 is offline   Reply With Quote
Old 04-05-2009, 08:01 PM   #2
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I just downshift if I need to accelerate and I'm in that range.
chazly413 is offline   Reply With Quote
Old 04-05-2009, 08:12 PM   #3
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
have you reset the ecu?
Vizzionz is offline   Reply With Quote
Old 04-05-2009, 08:20 PM   #4
mtntrekker30
Member#: 158173
No I didn't reset the ECU. If disconnecting the battery for 2 hours counts for a reset then yes I have.
Any other thoughts are appreciated. Thank you for yours
Old 04-06-2009, 01:05 AM   #5
Back Road Runner
Member#: 60082
2004 Forester STI
The low range on a stock engine just doesn't have much power there. You just aren't anywhere near your peak torque band till above that. If you want better bottom end, look at grabbing a set of 8mm phenolic spacers from Grimmspeed. It noticeably bumps up low end torque. It technically shouldn't do much of anything from the relatively tiny bump in runner length, but it does. For me, that and an aftermarket exhaust header were the two things that significantly bumped up low rpm response.
Just don't expect massive power down that low unless you do modifications to the car that specifically promote low rpm use.
Old 04-06-2009, 01:10 AM   #6
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
Is your dash lighting up with cels? .... my RS is doing the same thing. I think its the o2 sensor gone bad..... Im gonna change it out tomorrow ill let you know how it goes.
Baja820 is offline   Reply With Quote
Old 04-06-2009, 01:11 AM   #7
Blase
Member#: 54702
2000 impreza 2.5rs
brp
disconnecting your battery for 2 hours should definitely reset your ecu.
Blase is offline   Reply With Quote
Old 04-06-2009, 03:03 AM   #8
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
It shouldn't even take anywhere near that long. My ECU reset in the time it took me to replace my headlight bulbs.
If you're really impatient, step on the brake pedal after you disconnect the battery.
Counterfit is offline   Reply With Quote
Old 04-09-2009, 08:27 PM   #9
mtntrekker30
Member#: 158173
Default thanks everyone for the replies
My thanks to everyone for the responses. Wondering how things went with replaceing the O2 sensor.
If anyone has any other thoughts please let me know.
Thanks again everyone.
Old 04-09-2009, 09:01 PM   #10
Back Road Runner
Member#: 60082
2004 Forester STI
It's not his O2. You know when that's bad, and you will quickly very well understand the difference between open and closed loop operation.
Old 04-09-2009, 10:45 PM   #11
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
the problem is that you're driving below 2K rpm. You should only be near 1K in first gear.
Old 04-11-2009, 08:29 AM   #12
mtntrekker30
Member#: 158173
The problems I'm having are only in 1st and 2nd gear---any higher gears are not a problem. I've been careful to watch at about which RPM I'm shifting. Usually shift from 1st to 2nd at about 3000-3300 RPM which leaves me at about 1900 RPM when I engage the clutch after shifting to 2nd gear. Again after I break the 2300 RPM mark the power seems to come back.
Again thanks to everyone who has replied.
Old 04-11-2009, 12:37 PM   #13
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
have you been driving this way for a while or is this something recent that has popped up? try holding 1st gear up to 3500-4K. You don't have to mash the gas, just hold it longer. Most NA engines don't wake up until higher RPM's. We need flow velocity to make more power, and at low revs, it doesn't happen.
And you should get more power at lower elevations. Try porting your headers just a tad, I've heard that the stock ones aren't that great for smooth flow.
Car loses power Tiller35 Newbies & FAQs 11 04-27-2010 08:03 PM
Car seems to lose power Tiller35 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-26-2010 11:39 PM
car loses COMPLETE power BoXinWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 09-23-2009 11:20 PM
car losing power soobyfan Service & Maintenance 12 12-05-2003 05:13 PM
Car hiccups occasionally on acceleration? Fred Fredburger General Forum Archive 18 01-07-2001 01:40 AM
