Old 04-05-2009, 08:39 PM   #1
sonic03dz
Member#: 144056
03 wrx
sonic yellow stage 2
Question 03 WRX: Turbo upgrade?
Got an 03 WRX for street.
Currently running catless turbo back exhaust, stock TMIC, drop in k&N filter and stock ecu-reflash w/215whp (dynomanics)
Which turbo will produce the most power w/o sacrificing engine reliability?
Turbos Options:
IHI VF 22, 34, 39
Garrett GT30R
Blouch 16g, 18g, 20g
Tomei
APS
thanks for your input
sonic03dz is offline   Reply With Quote
Old 04-05-2009, 08:55 PM   #2
dincolo85
Member#: 99802
2002 Blue WRX/16G
1975 Porsche 914
I am running a FP 16g right now and think its awesome. (well I am building the motor right now, but when the car was running it was fun) I have a friend with a vf22 and its some good racing between the two of us, even though I tend to win them all! haha. You should really decide what your final power goals are and that is going to narrow your selection down a bit. If you dont know what kind of power you want your going to get 500 people telling you why you should go with one over the other and you will be back to square one not know what you want.
oh, and to say you only want a little more power is a lie, you always want more, even if you wallet yells no. (or wife)
dincolo85 is offline   Reply With Quote
Old 04-05-2009, 09:10 PM   #3
coldturbo
Member#: 168900
2002 Impreza WRX
Vf-39 Grp.N luv
Wow, turbo sizes all over the place!
VF series, mitsu or SR56?
All hugely different turbos.
VF series are not rebuildable; of those only the 22 and 34 are the only ones worth anything.
All real Mitsu CHRA 16III/18/20 compressors are fine. TD05/06 housings and 7cm^2 or 8cm^2 turbines mix things up for higher RPMs.
The APS turbo is a 56 lbs wheel and is way too big for a 2.0 litre DD.
coldturbo is offline   Reply With Quote
Old 04-06-2009, 04:47 PM   #4
sonic03dz
Member#: 144056
03 wrx
Default bump......
bump........
Old 04-06-2009, 05:16 PM   #5
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
do some research, search search search!
took me a while to figure out after a year and a half, i finally gota slightly used Blouch 18g 8cm2, can't wait for install+tune!!
blakkboxer is offline   Reply With Quote
Old 04-06-2009, 05:32 PM   #6
dincolo85
Member#: 99802
2002 Blue WRX/16G
1975 Porsche 914
+1
all i can say is find how much power you want to make and there will be a turbo for you.
Old 04-06-2009, 05:58 PM   #7
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
whats your budget and goals
jcbluescooby is offline   Reply With Quote
Old 04-06-2009, 06:18 PM   #8
blakkboxer
Member#: 167244
2k3 WRX MBP
Clean & Simple
oh yeah hey OP research about the EVOIII 16g. u might like it
Old 04-06-2009, 10:24 PM   #9
jmlaser
Member#: 125529
02 WRX 18G EJ205
1/4 mi stock block record
Uggg Me want 30R
jmlaser is offline   Reply With Quote
Old 04-07-2009, 12:28 PM   #10
sonic03dz
Member#: 144056
03 wrx
Default bump
Looks like am deciding between the blouch series g and the IHI VF turbos ...but the size turbo am not sure...probably will do a larger topmount
I want to improve over stock but not have to put to much stress on the enigne
Old 04-07-2009, 12:44 PM   #11
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
what your power goals? budget?
shadowmd is offline   Reply With Quote
Old 04-07-2009, 12:55 PM   #12
Oldfart Racer
Member#: 84064
2002 WRX VF30 Wagon
Here is look at the turbos http://forums.nasioc.com/forums/show....php?t=1084275
I run a VF30 and it works well for me. Just remember your tranny when building power.
Oldfart Racer is offline   Reply With Quote
Old 04-07-2009, 01:00 PM   #13
MS WRX
Member#: 117780
2004 WRX
30r, very minimum a 20g
MS WRX is offline   Reply With Quote
Old 04-07-2009, 01:01 PM   #14
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
on a stock 2.0L?....wouldn't a 30r be a little laggy/big?
Old 04-07-2009, 01:17 PM   #15
MS WRX
Member#: 117780
2004 WRX
Depends on what ya wanna do. For straight line its great. AutoX not so much.
The new 3071r rotated kits can spool early 4000's a i believe. For straight lines thats all you need.
If you want big power at 2000rpm buy a V8
This is just my opinion BTW.
Old 04-07-2009, 02:14 PM   #16
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Turbos Options:
IHI VF 22, 34, 39
Garrett GT30R
Tomei
APS
As power goes up, reliability goes down. Its not linear but more exponential like so your answer is NONE.
Old 04-07-2009, 11:21 PM   #17
sonic03dz
Member#: 144056
03 wrx
Default bump
bump.......
Old 04-08-2009, 12:20 AM   #18
dincolo85
Member#: 99802
2002 Blue WRX/16G
1975 Porsche 914
well i have a blouch 16g, with a pnp iwg. I think its an item created by god him self.. but i am biased
Old 04-08-2009, 09:13 AM   #19
jason miller
Member#: 158313
2003 WRX
Originally Posted by jmlaser View Post
Uggg Me want 30R
Ditto.
To the op, your post is pretty vague, suggesting you haven't done much research. If you want some reliability and more hp, a cheap vf39 sounds like a good option. You should gain at least 50 hp or so and hold the power better towards redline. However, a vf39 won't hold max power quite all the way to redline, so you may be less tempted to run it out to 7 g's all the time, which could also help with reliability. As mentioned, more hp means less reliability. You have to decide for yourself just how far you want to go. I went evo3 16g, and I'm planning on building a short block over the summer just in case...
jason miller is offline   Reply With Quote
Old 04-08-2009, 09:23 AM   #20
jason miller
Member#: 158313
2003 WRX
Ever heard of an sr40? It's quite a nice turbo for our ej205, and guess who made it. APS makes/has made more than just the sr56...
WTB for 03 WRX: 5spd MOMO shift knob, shimless buckets, STi TMIC, turbo inlet coupler toflaherty Private 'Wanted' Classifieds 3 07-10-2009 11:14 PM
03 WRX: Need suggestions for a turbo upgrade? sonic03dz Interior & Exterior Modification 11 04-05-2009 02:46 PM
04 WRX: slightly upgraded shocks? JonM in MN Brakes, Steering & Suspension 10 04-01-2009 09:56 AM
VF 43, 39 Turbo Upgrade 03 WRX DanBelford Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 03-27-2008 02:14 PM
WRX: Speaker Upgrade Question Soon2BturbodRS Car Audio, Video & Security 3 12-20-2003 11:52 PM
