Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Old 04-05-2009, 11:00 PM   #1
inspectorgadget
Member#: 149448
Default 2004 Impreza TS Wagon CEL Flashing
My Subie is a 2004 Impreza 2.5TS Wagon. All stock, no mods. 64K 5spd
I was driving on the highway today and revved the engine pretty good getting onto the highway, i hit like 4500 RPM in 3rd and 4th gear, then had cruise control at around 3000 RPM in 5th gear. Shortly after that my check engine light came on and started flashing. I am not sure if i was giving it gas at the moment or not but i took the cruise off and slowed down a little bit. The light went off and hasn't been on since. I drove the car home on the highway, about 30 miles and no light. There were no particular symptoms that happened when the light came on. In general my car has been running a little funny lately.
1. There is a very faint tick when i start the car and its idling. It may be there under higher RPMs but i cant hear it unless the car is idling.
2. I changed the air filter like 6 months ago and since then whenever i really push the gas and open the throttle the exhaust has sounded different. Its been a deeper more full sounding exhaust.
3. The mileage has been down slightly over the last 6 months or so, not directly after the air filter change but around that time. I was averaging about 25MPG mixed and now I get more like 22-23 MPG same kinda driving.
I have not had a tune up or major service done. I am going to stop at autozone and see if i can get the code. Should I just change the plugs and coilpacks since im over 60k now? I am wondering if I should just do some of this preventative maintenance now, but I am not sure what is most critical/biggest bang for your buck to do right now.
TIA-more to come
inspectorgadget is offline   Reply With Quote
Old 04-05-2009, 11:39 PM   #2
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
search is your friend. Blinking CEL is a misfire that can cause damage to the cats. First step is to check/replace the plugs. At a couple of dollars each, it's a cheap thing to do and it's normal maintenance. You can check your valve lash to see if it's within spec, it's been known to cause misfire codes. From there, search, there are many different causes for a misfire.
Old 04-06-2009, 08:21 PM   #3
inspectorgadget
Member#: 149448
I stopped at Autzone after work today to get the code read. I have driven approximately 35 miles since the check engine light was flashing. The cruise control was on because i was using it and was a steady light. The code couldn't be read and just said "pass" in the lcd screen. I got a Lucas Fuel Injector bottle and threw that in today with super. I normally run regular but have run 91 octane in the past with no difference. I plan on replacing the plugs and fuel filter very soon as a result of this.
Any other thoughts would be appreciated.
TIA
Old 08-10-2010, 01:13 AM   #4
Bamspa
Member#: 254432
Unhappy about M CEL
My Cel comes on stays on and turns off DAYS later .. i went to Autozone and they gave me a P1512 code ..my Air control solenoid needs replacing BUT they told me to hose the intake with FI cleaner and pull the ACS out and clean that with the FI cleaner and to pull the plug on the battery for an hour? and while im here does my 04 Impreza TS have a PCV valve? and if it does WHERE IN the heck is it ? Thanks all for ANY help you can give Oh and it bucks like a PO'd bull with a spur in its BUTT . can it all be connected?
Bamspa is offline   Reply With Quote
Old 08-10-2010, 07:37 PM   #5
GrundleJuice
Member#: 165749
PCV valve is on the rear of the crankcase near the passenger (right) side cylinder head. Whats is the P1512 code definition?
GrundleJuice is online now   Reply With Quote
Old 08-11-2010, 03:19 AM   #6
Bamspa
Member#: 254432
Default p1215 code
says the idle air solenoid is messed up or reading poor flow and is messing my O2 sensor too. i also remember putting Boshe plugs in roughly a year ago and its been about that long that the car has been acting up! Im thinking of going to my local import parts place and getting some nippon or OTHEr plugs
Old 08-26-2010, 11:50 PM   #7
Bamspa
Member#: 254432
ok i did what the guy @ autozone said pulled the solenoid out cleaned it with carb cleaner hosed the intake down with it and disconected the battery to reset the CEL comp ..STILL bucks but not as bad.. could it be my O2 sensor or is it the boshe platinum plugs i have in it ?
Old 08-27-2010, 01:05 AM   #8
LetItSnow
Member#: 38222
'10 &'12 Foresters
another Miata convert
inspector, please fill out your location. If you're anywhere near me, I know a heap of guys who'd be willing to help you out. You have to use resources like this!
LetItSnow is offline   Reply With Quote
What Doors fit a 2004 Impreza TS Wagon? inspectorgadget Interior & Exterior Modification 5 11-02-2008 11:17 PM
2004 impreza ts VSS wire location inspector Car Audio, Video & Security 1 09-17-2004 12:34 AM
Pics of my 2004 Green TS Wagon (56K beware) robertg Member's Car Gallery 6 08-24-2004 11:26 AM
2004 Impreza TS/RS/WRX/STi headlight bulb sizes Samirr76 STi Forum Archive 19 03-28-2003 04:42 PM
Impreza TS wagon vs Outback Sport wagon vete Newbies & FAQs 8 04-08-2002 01:49 AM
