Old 04-06-2009, 08:33 AM   #1
darknightohio
Member#: 50523
2010 GTI
Default 2010 Ford Shelby GT500 Follow-Up Test and Video
Quicker, Smarter, Nicer — Yet Still a Bad Boy
By Chris Walton, Chief Road Test Editor Email | Blog
Date posted: 04-05-2009
STORY TOOLS Digg this!
del.icio.us
It's something like trying to drive the 2010 Ford Shelby GT500 on a roller-coaster, only there are no steel tracks to keep you from slithering off the pavement and ending up in a flaming heap of 540-horsepower Mustang.
You can't even see where you're going, really. Hard on it, the GT500's rear tires begin spinning just as you can see nothing but sky in the windshield. You're on top of the hump at the entrance to Infineon Raceway's Turn 6, and as your stomach and both right-side tires go weightless, you start a long, long dive to the left, sliding sideways all the way down the hill and around the 180-degree corner.
The Shelby GT500 is so torqued up with the cornering force from the low-profile 19-inch tires and the drive from the supercharged V8 that you can practically hear the welds popping in the chassis. But something is different this time — palms are not slick with sweat, tires are not threatening to let go at the most inopportune moment and steering left in order to go right is a joy and not a reflex of self-preservation.
The 2010 Ford Shelby GT500 gets 2 mpg more on the EPA highway cycle this year. The Ford engineers are really proud of this. But every time we make another lap and slide down Turn 6, we have our doubts that fuel economy is what this car is about.
Serving Our Inner Adolescent
We're behaving like adults as the Ford engineers tell us all about the 2010 Ford Shelby GT500, even as we hear a couple of the cars making shake-down runs on the quarter-mile strip at Infineon Raceway a few hundred feet away. And in many ways, the GT500 itself is trying to act more like an adult, casting aside the muscle-bound character of the 2007 Ford Shelby GT500.
As the Ford people tell us, they started with the limited-production 2008 Ford Shelby GT500KR, the exclusive (1,700 examples built) and revenue-enhancing (MSRP $79,995) Mustang produced last year. And aside from a few fewer Shelby badges (the KR had many to spare), the GT500 is like the KR in almost every way, except it's built at the Mustang plant in Flat Rock, Michigan, rather than at the Shelby facility in Las Vegas.
You can tell as soon as you open the new GT500's hood, complete with hot-air extractors. The supercharged and intercooled DOHC 5.4-liter V8 with its truck-style iron block is still in place, but now it carries a conical air filter in its own sealed cold-air box behind the left-side headlight, an innovation that increases airflow while resisting power-sapping heat soak. For the GT500, this new cold-air intake required the migration of the iconic Cobra badge on the grille from the left side to the right side.
With premium fuel and more aggressive ignition timing plus a less restrictive exhaust, the result is 540 hp at 6,200 rpm, an 8 percent increase. Torque output goes up fractionally to 510 pound-feet at 4,500 rpm. Thankfully, the telltale supercharger whine has been significantly diminished with clever intake plumbing, while the idle burble and bad-boy tailpipe blat have been accentuated by the 4-inch exhaust system.
Totally Awesome
It's not a lot of extra power, but your inner adolescent can put it to good use because the final-drive ratio is 3.55:1, 7 percent shorter than the former 3.31:1 rear-end gears. This means a useful increase in twist at the new, 19-inch forged-aluminum rear wheels, and the result is a blast to 60 mph from a standstill in a blistering 4.3 seconds (4.0 seconds with 1 foot of rollout, like on a drag strip). In comparison, the 2007 Ford Shelby GT500 made the run in 4.6 seconds, while the 2010 Chevrolet Camaro SS did the deed in 5.0 seconds (4.7 seconds with rollout) and the 2009 Dodge Challenger R/T recorded 5.5 seconds (5.3 seconds with rollout).
Quarter-mile performance is totally awesome as well, as the GT500 makes its best pass in 12.4 seconds at 114.7 mph. That's not only a useful margin over the '07 car with its 500-hp powertrain, which did the deed in 12.8 seconds at 112.6 mph, but it also makes the Chevrolet Camaro and Dodge Challenger look like weak-ass sissies. The Camaro turned the quarter in 13.0 seconds at 110.9 mph and the Challenger did 13.9 seconds at 103.2 mph. We might have gone even quicker and faster in the Shelby GT, except for the 14-mph headwind we faced at this track close to San Francisco Bay.
While it's as easy as ever to haze the rear tires off the line, the new softer tire compound has improved the bite. If you value bracket-racing consistency over all-out performance, the AdvanceTrac stability control's new Sport mode will do its best to optimize (though somewhat limit) traction for you. You might even select the launch rpm electronically for varying surfaces.
Adulthood Comes to the Shelby GT500
Though the GT500 has that big beat from under the hood that gets your attention, it has the tractable character of the KR, so it's easy to drive.
You can feel it in the controls. Everything operates with an easier, friction-free feel, so you don't feel like you're riding some kind of beast that's trying to spit you off at the first opportunity. The steering shaft is stiffer to deliver crisper response, even though the steering ratio remains at 15.7:1. The effort level for the brakes is scaled to humans, not superheroes. The shift action of the short-throw Tremec six-speed manual is short and sharp, not stiff. Even the clutch is surprisingly easy to modulate thanks to the use of larger, more robust copper/fiberglass plates that engage more progressively.
Compliance and balance are the secrets here, an approach more grown-up than the former Shelby's brawny, stiff-legged tuning. Where the previous GT500 and especially the KR would hop over a lane line if there were a twig at the apex of a corner, the 2010 GT500 acknowledges road irregularities, but those events don't linger and oscillate more than once. Bam, and it's done.
It begins with a compliant suspension tuned to deliver lots more roll control, only it comes from nearly twice as much rebound damping than before rather than simply stiffer springs. More negative camber at the front wheels also helps the steering bite with more effect when you turn into a corner, especially since the revised Goodyear Eagle F1 Supercar tires carry a softer compound.
Balance comes from a revised aerodynamic profile meant to improve high-speed handling and stability. A revised front splitter reduces front-end lift by 31 percent, while the rear wing is trimmed out to actually increase lift. Downforce can be tuned with the small Gurney flap.
Driving in the Real World
This Shelby GT makes you believe you're in an exclusive performance car, not just a Mustang with a decal package.
The seat upholstery is real leather and the inserts are suede. The rim of the steering wheel is suede. The silver trim for the dash is real aluminum, and it has a zippy dimpled finish. Soft-touch plastic is used and the gauges are specific to the GT500. When you fire up the car, the Shelby Cobra logo appears on the navigation screen.
With one hand on the suede rim of the steering wheel and the other on the shift lever's white cueball (manufactured by an actual billiard supply company) that has been inscribed with the racing stripes that are the visual theme of the GT500, you're looking forward to the drive.
We drive along California highway 1 from Stinson Beach to Fort Ross, and then cut inland through the California wine country to Calistoga. The Shelby lets you know that it has a live rear axle, but it doesn't make you slow down for fear of upsetting the car — a real breakthrough. If only it weren't for the seat headrests giving your head a nudge every time the axle kicks.
And this thing gets fuel economy. Although the final-drive ratio is far shorter than before, 5th and 6th gears are much taller. So the result is an EPA-rated 14 mpg city/22 mpg highway.
Coming to a Showroom Soon
We can't think of a more difficult place to drive a 540-hp pony car than Infineon Raceway, but once all the Ford people were gone and we were left on our own with the 2010 Ford Shelby GT500, we did lots of time on this 2.5-mile roller-coaster. And once we flicked off the stability control, the Shelby GT came alive. You could flick the Shelby into corners, and we came down Turn 6 with smoke coming from the rear tires. And the brakes offered good modulation and a crazy amount of capability.
By the end of a day, you can't help but like this car. It's stonking fast (though it doesn't always feel that way), it slides very controllably (especially when you find that special place that's like Turn 6) and it actually looks special (and exclusive) for a change. We'd even order one ourselves (though the stripes would have to go).
You can order one for yourself when it arrives in dealerships in the early summer. The price of the 2010 Ford Shelby GT begins at $48,125, and this includes the now-lower $1,000 gas-guzzler tax (thanks to the GT's 22-mpg highway rating) and $850 destination charge. Loaded with options as our test car was, the price can easily surpass 50 grand, though.
But like the original Shelby GT500, there's a level of sophistication and even luxury sewn into the fabric of this undeniably rapid and capable muscle machine. Sure, it'll throw down consistent 12s in the quarter-mile and slide around corners with glorious plumes of tire smoke, but it'll also tell you what traffic conditions lie ahead, play DVDs and promote marital harmony with dual-zone climate control. Name another 540-hp coupe for $50,000 that can do all that.
Video found here:
http://www.edmunds.com/insideline/do...deoId=20273139
darknightohio is offline   Reply With Quote
Old 04-06-2009, 08:58 AM   #2
FaastLegacy
Member#: 11671
<Insert derogatory Mustang comment here>
FaastLegacy is offline   Reply With Quote
Old 04-06-2009, 09:15 AM   #3
SCRAPPYDO
Member#: 873
2014 GLK/allroad
Datsun 71 240Z & 68 2000
50k for a mustang. Um no, a Vette would eat it and then some
SCRAPPYDO is offline   Reply With Quote
Old 04-06-2009, 11:55 AM   #4
gills
Member#: 11316
1988 E30 M3
S54
When did they plan to run the Baja 1000?
gills is offline   Reply With Quote
Old 04-06-2009, 01:59 PM   #5
Andreas Miko
Member#: 42738
2004 WRX STI
540 HP and 510 Lb Ft Torque running 12.4 @ 114 is pathetic.
This car needs to lose 300-400 pounds and get indepenent suspension.
This car should run 11.8 at 120 MPH
Andreas Miko is offline   Reply With Quote
Old 04-06-2009, 02:08 PM   #6
Mariano
Member#: 56
Chapter/Region: PRSIC
1999 RS-T (Stage V)
2005 LGT LTD
^ What he said...
Mariano is offline   Reply With Quote
Old 04-06-2009, 02:36 PM   #7
Superglue WRX
Member#: 106275
New Chevy SUV
Government Motors White
Originally Posted by Mariano View Post
^ What he said...
X2
lighter > 40 more horsepowers
Superglue WRX is offline   Reply With Quote
Old 04-06-2009, 08:31 PM   #8
imprezaL2345
Member#: 108188
1993 Impreza L 1.8T
Lotus Storm Titanium
oh can it guys. your comments don't/won't matter. everytime you guys says its needs irs, needs less weight, and the corvette is better, like your opinion is going to change something. btw, every 10 lbs equates to 1 hp. that being said 400lbs = 40hp, which is what they did.
imprezaL2345 is offline   Reply With Quote
Old 04-06-2009, 09:06 PM   #9
Remy E. LeBeau
Member#: 4714
I really like the new mustang styling....the revised rear end and front is better....
Remy E. LeBeau is offline   Reply With Quote
Old 04-06-2009, 09:57 PM   #10
Beowulf
Member#: 24465
2012 Regal GS
1990 300ZX TT
I'll take the Camaro SS please..for 20K less
Beowulf is offline   Reply With Quote
Old 04-07-2009, 02:55 PM   #11
elirentz
Member#: 70082
2016 SS, 02 s2k
06 Cayman S, 80cc shifter
Plus better when the road turns.
elirentz is online now   Reply With Quote
Old 04-07-2009, 03:46 PM   #12
Yoo Shin
Member#: 87327
2010 12 parsec Evo X
I still kill threads
I love it but it should/could easily be a solid 12 sec flat. $50k is tuff to swollow also. Take a 370Z, super charge it and still have change left over for a 2nd set of track wheels and tires.
Yoo Shin is offline   Reply With Quote
Old 04-07-2009, 04:40 PM   #13
White out
Member#: 46277
** LP640
Viper GTS
A great car, power, looks, performance.
Everyone who is complaining about it's 1/4 mile, note 19" wheels with low profile tires & 540hp.
Some smaller wheels & more sidewall would solve that issue.
Nick
White out is offline   Reply With Quote
Old 04-07-2009, 07:14 PM   #14
RexDriverNY
Member#: 173371
2010 VW GTI MKVI
Candy white
Somewhere on edmunds they said that they had to deal with a 15mph headwind during the 0-60 and 1/4 mile times, which means it can do better.
RexDriverNY is offline   Reply With Quote
Old 04-07-2009, 07:35 PM   #15
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
it cant handle!
amdmaxx is offline   Reply With Quote
Old 04-07-2009, 07:36 PM   #16
amdmaxx
Member#: 31665
2006 Saab 9-2x Aero
I take a slighty used C6 ZR1.... same price
Old 04-07-2009, 08:01 PM   #17
Skunkers
Member#: 115480
Skunkers is offline   Reply With Quote
Old 04-07-2009, 11:25 PM   #18
FaastLegacy
Member#: 11671
it cant handle!
Neither can your Saabaru for that matter.
Ahh...NO. You completely miss the point of this car. It's not meant to be a corner carver, it's meant to tear it up on the drag strip, hence the solid rear. The car is a few bolt ons away from 11s, anyway. The Cobra should still be pretty competent in the twisties as it is.
Huh? You honestly think you can get a slight used ZR1 for $50k? I can't figure out if you honestly think you'll be able to pull that off or you don't know what you're talking about and you meant to type Z06. In any event, I'd like to see this phantom $50k ZR1.
Finally somebody gets it! This car is a pulley and a set of drag radials away from being a beast. I don't expect a bunch of Subaru fanboys to understand that though.
Old 04-08-2009, 12:30 AM   #19
AKGC8
Member#: 1305
2000 Impreza
Yea, that car would probably be slower in the 1/4 with IRS. The people actually buying these things do not want IRS.
AKGC8 is offline   Reply With Quote
Old 11-27-2009, 07:46 AM   #20
AVANTI R5
Member#: 73805
2016 Cayman GT4
black
Default Ford Mustang Shelby GT500
t might have a Shelby name but the old man isn't really building Mustangs these days. The real engineering heroes behind the facelifted GT500 are the blokes at Fordís SVT (Special Vehicle Team).
The original 2007 car, you might recall, was powered by a supercharged 5.4-litre V8 delivering 500bhp to the rear wheels. It was quick, but hardly sophisticated, overweight and the interior was bad enough to make a Neighbours set designer blush. So whatís new about the Ford Mustang Shelby GT500?
Using 2008ís GT500KR (King of the Road) special edition as a base, Ford has given the standard car the same 540bhp and boosted torque from 480lb ft to 510lb ft. The sprint to 60mph falls slightly to around 4.5sec, the V8 rumble is even better thanks to a cone air filter the size of a jumbo popcorn bucket and the slow gearshift is satisfyingly precise. The final drive is shorter but sixth longer than before to help with fuel economy.
So it feels mighty quick unless youíre in top and you have to think carefully about deploying all 540bhp in the wet. Fortunately thereís a multi-stage traction control system and a lot of throttle pedal travel to help you unleash the right amount of power.
What about those inconvenient bits between the straights?
This time the bits between those straights arenít quite so inconvenient. There are revised spring and damper rates, tweaks to the steering system and a bespoke Goodyear tyre which help improve grip and steering feel. Weíre not talking reference quality feel here, but to anyone whoís ever driven an original Ď60s Mustang, it would be a revelation. Youíre not left totally in the dark about whatís going on, it's well weighted and usefully responsive around the straight ahead.
Sadly the 2010 revisions donít extend to getting rid of that Bronze Age-tech live rear axle which still causes the GT500 to hop about on bumpy B roads and generally ruin the ride. If youíre trading up from a 2.8 Capri though, youíll love it.
So Iíll be a half a car length ahead of the old GT500 in a fight from the lights and half a mile ahead through the twisties, but how will everyone know mineís the new and improved GT500 before Iíve wasted them?
The new GT500 benefits from some of the design tweaks made to the regular ĎStang earlier this year including the segmented tail lights whose bars flash in sequence, just like the original í67 Shelbyís. The wheels are up an inch from 18 to 19-inches and thereís a mildly revised front end incorporating a huge bonnet bulge and a new single bonnet scoop instead of the previous modelís two. Anoraks will also notice that the snake grille badge has swapped sides because that giant air filter now sucks hard from left hand side of the grille.
And is the cabin still the sort of petrochemical nightmare that would give a Tata Nano driver cause to recoil in horror?
No, itís much improved, if still a million miles off even a Vauxhall Astraís, never mind a BMW M3ís. Thereís soft touch plastic on the lower dash but itís cunningly treated to look almost the same as the rock hard stuff on the doors. The retro instruments are hard to read and the striped seats, while comfortable, look more in keeping in a Mustang V6 than a 540bhp range topper. Recaro? Who are they?
Itís not all disappointments though. The gearknob is made by a company that makes real billiard balls and feels great, and the retro steering wheel has really benefited by a lashing of suede on the rim.
Where can I get one in the UK?
Not from your Ford dealer, sadly. But there are plenty of companies willing to source you one from across the Atlantic. Trouble is, what costs $47,000 (£28k) in the US ends up as £47,000 in the UK, and often more. And all Mustangs are left hand drive remember.
Verdict
Okay, first the rational verdict. At the £28k the GT500 costs in its home market you could probably forgive the Transit-quality cabin plastics, ordinary seats, paucity of rear headroom and crashy live axle suspension for the fun styling, thumping soundtrack and straightline punch. But at the near £50k importers are asking, youíd be mad to choose it over the faster, more sophisticated and much more capable BMW M3 or Porsche Cayman S.
But if youíre UK based and seriously interested in buying a GT500, thereís not really much point in me banging on about how better a BMW M3 is. Youíve probably already discounted the BMW, Porsche and Nissan GT-R for being too ordinary. If youíve got your heart set on some retro muscle then what matters is that the new Shelby is much improved. But you might want to check out the cheaper (but just as quick) Chevrolet Camaro SS, or consider a regular Mustang GT before you open your wallet.
http://www.carmagazine.co.uk/Drives/...ontent-block=1
Old 11-27-2009, 09:57 AM   #21
Derbagger
Member#: 32113
05 Saabaru
Satin Grey
The faults that are easy to overlook at 28k in the GT become insurmountable at 50k in the GT500.
Derbagger is offline   Reply With Quote
Old 11-27-2009, 02:38 PM   #22
skywaffles
Member#: 82470
I am more humble
than you can understand.
Those wheels are SO good looking.
skywaffles is offline   Reply With Quote
Old 11-27-2009, 02:55 PM   #23
sgilson
Member#: 161746
My father has a 05 or 06 GT Convertible with the 18" rims and 5 speed. It is great fun to drive. It also handles very good. I can see why people want to compare it to the 370Z and Vette, both great cars, but they don't have 4 chairs. I'd drop the 50k if I was in the market for something like this.
sgilson is offline   Reply With Quote
Old 11-27-2009, 03:14 PM   #24
FaastLegacy
Member#: 11671
I kinda disagree. It's not a luxury car nor is it pretending to be - it's a high end pony car. A C6's interior isn't any better at a higher price and it's doubtful the Z28 will be either and should be priced similarly.
Supposedly the '10+ Cobra is a vast improvement over the '07+ in all respects.
Old 11-27-2009, 03:29 PM   #25
under5
Member#: 188980
2005 WRX
PSM For Sale:(
a C6 is much, much better dynamically.
I saw a '10 GT500 yesterday, it was SOOO good looking.
under5 is offline   Reply With Quote
2010 Ford Shelby GT500 vs 2010 Chevrolet Camaro SS Tea cups Non-Subaru News & Rumors 40 07-07-2009 11:05 PM
2010 Ford Shelby GT500 vs. 2010 Hennessey Performance HPE550 Camaro Tea cups Non-Subaru News & Rumors 25 07-01-2009 04:24 PM
Insideline: 2009 Audi Q7 3.0 TDI Follow-Up Test and Video Chuck Jones Non-Subaru News & Rumors 0 11-26-2008 04:24 AM
2007 Ford Shelby GT500 Red Stripe Appearance Package NYCshopper Non-Subaru News & Rumors 35 10-29-2007 08:10 PM
Roush gives the Ford Shelby GT500 605hp AVANTI R5 Non-Subaru News & Rumors 0 10-26-2007 11:16 AM
