#1 |
Member#: 92852
I have a coolant leak on the passenger side where the crossover pipe connect to the block half. I have replaced the o-rings three times with no luck. on the third time i even put some PERMATEX® ULTRA GREY® Gasket Maker. I have not been able to find any kind of deformations on the mating surfaces. I always titting the bolts in an even x-cross pattern.
-EJ22T short block -EJ257 STI coolant crossover pipe -O RING-33.7x3.5 - (806933010) I purchased from a board member another Coolant crossover pipe in hopes that it will seal better. Does anyone have any words of wisdom. I am really getting tired at removing the intake manifold to replace the o-rings on the crossover pipe.
#2 |
Member#: 134949
VIC
Vehicle:'07 SWP STi Twinscroll ViPec Anti-lag |
Could be a crack somewhere on the crossover pipe.
#3 |
Member#: 92852
no visible crack on the cross pipe or the block for that matter.
#4 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
where does the coolant accumulate?
is it coming from the o-ring area or trickling down the coolant pipe to the o-ring area? |
#5 |
Member#: 172814
Vehicle:02 wrx wagon wrb |
bump for any more suggestions..my car is also having systems of a stuck thermostat and the temp gauge goes in the red then will shoot down then back up, I have replaced o rings and that dint do anything. my heat also doesnt blow hot either any help?? my coolant is pooling by the crossover pipe near the seals.
#6 |
Member#: 214821
RMIC
Vehicle:2005 STi OBP |
Try Permatex The Right Stuff gasket maker. The stuff works great it cures fast and has never leaked on me. As for the heater not working either you have air in there or your thermostat is stuck open not allowing the car to warm up all the way.
#7 | |
Member#: 172814
what a bad 2 weeks. damn subaru such a love hate relationship.. |
#8 |
Member#: 172814
bump anyone have a how to on fixing the stuck thermo stat.?
#9 |
Member#: 180223
Vehicle:1997 Subaru impreza |
#10 |
Member#: 30669
Vehicle:1998 Legacy 2.5GT Silver Sleeper Wagon |
#11 | |
Member#: 30669
#12 |
Member#: 112759
Vehicle:02 Srp STi... R ur Boltz to long???? |
Jack up the front end & run the car w/ the heat on it helps to purge the air out of the heater core
| Thread Tools | |
| Display Modes | |
| FS (PA) Coolant crossover pipe, water pump, ac compressor | Ray@revitup | Engine/Power/Exhaust | 4 | 08-03-2011 02:39 AM |
| coolant leak after new water pump | garinhash | Service & Maintenance | 3 | 12-03-2009 01:03 PM |
| WTB: Water jacket crossover pipe and/or stock headers | Tap | Private 'Wanted' Classifieds | 2 | 05-08-2006 09:34 PM |
| WTB: Water jacket crossover pipe | Tap | Private 'Wanted' Classifieds | 0 | 05-06-2006 01:34 PM |
| Coolant leak, 98 RS, water pump? seal? | SDEWYZ | Service & Maintenance | 4 | 06-16-2003 12:55 PM |
