Old 04-06-2009, 03:55 PM   #1
John Drivesabox
Member#: 81610
2005 Legacy GT
Default What do these numbers tell you?
Did another comp test and this time the numbers were way different. First test was done pulling 1 plug at a time.
1. 125
2. 125
3. 146
4. 135
This test was with all plugs out plugging the tester into the hole
1. 180
2. 185
3. 160
4. 170
Sounds high to me, also , this motor is supposedly built with Arias low compression pistons. Do those numbers seem high?
- J
John Drivesabox is offline   Reply With Quote
Old 04-06-2009, 05:26 PM   #2
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
wats the comp ration supposed to be? I know that for a 8.5 compression motor those look good....as far as i know
rivman05 is offline   Reply With Quote
Old 04-06-2009, 06:28 PM   #3
John Drivesabox
Member#: 81610
2005 Legacy GT
I would think closer to the 125's I was getting before. But aside from that, the spread is the only thing that makes me go hmmmmm.
Old 04-06-2009, 08:32 PM   #4
rivman05
Member#: 159986
1994 Acura Integra
Milano Red
not that it helps you any, but my buick was like that. drove me nuts when i first did a comp check....not sure what the numbers are supposed to be on a subaru tho, like i said, i have experience wiht old big blocks..subarus are new to me, so if they are similair then they look good to me
Old 04-07-2009, 01:30 AM   #5
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
I know a 9.7:1 EJ22E engine should be around 185 psi OE.
Not sure how low your compression is supposed to be with your build.
A compression test is supposed to be performed with all spark plugs removed so the engine can move as free as possible. It lends itself to accurate results as you are not fighting the other pistons building compression while you're testing the one. Also makes for an easier task on your starter.
PhilSine is offline   Reply With Quote
What do these plugs tell you? mc2 Service & Maintenance 15 04-03-2009 04:21 PM
Airesearch turbo's? And what do these numbers mean? japslapr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 12-01-2006 06:08 PM
How do these numbers sound? scooby24 Proven Power Bragging 2 02-09-2005 11:22 PM
Lowered my car, then got it aligned- what do these numbers mean? Dirty B Brakes, Steering & Suspension 15 05-14-2003 12:56 PM
Do these numbers make sense? kcwrx02 Proven Power Bragging 8 12-13-2002 01:35 AM
