Old 04-06-2009, 06:29 PM   #1
John Drivesabox
Member#: 81610
2005 Legacy GT
Default odd fuel issue after compression test, intake/tmic removal/reinstall
Car: '98 LGT 2.5, T04E turbo w/ sti injectors, EManage Ultimate
Problem: turns over but wont start. This is the first time Ive EVER had this problem.
First thing I did yesterday was remove an old Vortech FMU which I no olnger need since I've been running EMU fr about a month. I simply removed the lines and placed all the vacuum lines back closed to the boost gauge and sealed all the fuel and vacuum lines back together.
Next, I took off my intake and washer bottle to do a compression test, after I was done I put everything back together. Compression test went fine, took the car for a test drive and everything was peachy.
THEN, I took off my intercooler (06 WRX TMIC) and intake to recheck and reseal the entire intake system, I knew I had some boost leaks and think I solved all the issues with those, a few loose spots later and I think I'm good to go. Then I put everything back together and go to fire up the car. Turns over, no joy. What could have possibly happened between taking off the intake and intercooler. Im pretty sure this is a fuel issue, I clamped the fuel line to see if it was flooding and the car fires for a brief moment. Why is the car flooding now?
The batteries been disconnected all night and I could really use some ideas.
John Drivesabox is offline   Reply With Quote
Old 04-07-2009, 01:24 AM   #2
PhilSine
Member#: 130489
02 WRX Wagon (WRB)
98 OBS-T, 91 Legacy SS
You know how it is...
Air + Fuel + Spark = combustion.
Air is sowewhat of a given.
Might have broken the coil wire or the clip came undone. The coil wire does run under the TB and intercooler area. Definately check for spark first. Make sure there is voltage to the coil. Could be the crank position sensor got jarred somehow. Odd stuff can happen but yo ufirst need to determine if its rich as a result of too much fuel or rich due to no spark.
PhilSine is offline   Reply With Quote
Old 04-07-2009, 09:05 AM   #3
John Drivesabox
Member#: 81610
2005 Legacy GT
hanks phil, I hink I may hav found h problm, I jus nd o rassmbl and giv i a sho. B20 was loos (cam/crank angl). Now I jus nd o go g a nw kyboard.
Old 04-07-2009, 09:06 AM   #4
John Drivesabox
Member#: 81610
2005 Legacy GT
and hy man, w nd o hang ou. I wan o s your SS and ouback
Old 04-07-2009, 04:45 PM   #5
John Drivesabox
Member#: 81610
2005 Legacy GT
Got it, my wiring harness has a gremlin causing one of the sensors to click in or out, depending on where the harness is positioned. Fixed and done! Running great now, well, it needs another tune but it's better than before.
- J
re use plugs after compression test? kh15 Newbies & FAQs 3 01-25-2010 01:33 PM
Odd fuel issue after compression test? Won't start John Drivesabox Normally Aspirated Powertrain 4 04-06-2009 07:22 PM
Compression testing the engine removed? scooby-stu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 01-30-2007 08:42 AM
Odd compression test and leakdown test numbers SloRice Built Motor Discussion 10 11-13-2006 10:07 AM
Urgent help: Misfire after compression test homiusang Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 5 09-19-2006 10:45 PM
