Old 04-06-2009, 07:09 PM   #1
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
Default apexi pfc for ej20g ?
is there any base map setup to just put the ecu in the car and run it but not mess with any of the settings?
or do i need to just take my car to get tuned and let them install and mess with the settings?
just wondering if it is safe to just plug into the car and will the car run normal without messing with any of the settings?
-Andrew
gc8awdsti is offline   Reply With Quote
Old 04-06-2009, 07:21 PM   #2
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
The base setting is pretty safe - it's even easy to correct for injector changes with it too, but you will need a proper map done for it.
It will also flash your check engine light if it picks up any knock and you can easily pull some timing out of it if you do get any detonation at all.......
I have one in my GT-R and it's a very good system.
rockcrete is offline   Reply With Quote
Old 04-06-2009, 07:43 PM   #3
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
is there a way to get to the base map? i just tried to plug it in the car, but it will idle rough and then die each time. what would be the factory setting for the ej20g?
Old 04-06-2009, 07:44 PM   #4
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i wish there was a reset button^.haha
Old 04-06-2009, 07:56 PM   #5
rockcrete
Member#: 196721
1993 GF8 WRX Wagon
You need to do the idle learn with it..........
read this -> http://paulr33.skylinesaustralia.com...owerfc-faq.htm
Old 04-06-2009, 08:30 PM   #6
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
thank you^ all i need now.
Old 04-06-2009, 09:45 PM   #7
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
um there is a reset button ...
but no i wouldn't drive it with out a tune .. the ej20k base map was way off
Jaxx is online now   Reply With Quote
Old 04-06-2009, 09:52 PM   #8
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
i took it out till i can get a tune. im hoping to get with topspeed in ATL. im located in SC so that isnt too far away.
Old 04-07-2009, 12:36 AM   #9
elislider
Member#: 133923
03 Legacy GT wagon
I love goooollllllllddddd
from what i understand they are set with a base map from the factory that should run the car as stock, but they are made to use a Apexi boost controller. with a stock boost controller it might not work properly. would obviously be the best idea to just get it tuned straight away
elislider is offline   Reply With Quote
Old 04-07-2009, 01:10 AM   #10
gc8awdsti
Member#: 192848
1998 GC8 rsti
BDP
tune is my next step if i dont sell it.
Old 04-07-2009, 04:38 AM   #11
RealDealTarheel
Member#: 142447
Banged Up Blue
The stock boost controller does work with the Power FC.
RealDealTarheel is offline   Reply With Quote
Old 04-07-2009, 09:49 AM   #12
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
run yes .. drive .. not really .
somethings are smoother some are way way rougher
Old 04-07-2009, 09:50 AM   #13
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Old 04-22-2009, 11:22 AM   #14
JDMFLCL
Member#: 180513
Baby Baby C'mon!
Looka Bomba! 99 JDM GM8
mistake post
JDMFLCL is offline   Reply With Quote
Old 04-22-2009, 11:38 AM   #15
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
Dent Black/scratch primer
yes it is...way to rich
How much ya want for it??
Cbgrandtheftauto is offline   Reply With Quote
Old 04-22-2009, 11:48 AM   #16
JDMFLCL
Member#: 180513
Baby Baby C'mon!
too late
since its too rich, i assume that means it is open to increasing boost just like the oem z4 can?
Old 04-22-2009, 12:16 PM   #17
Cbgrandtheftauto
Member#: 184977
99 Impreza RS
Originally Posted by JDMFLCL View Post
too late
no...and it knocks when reved real high..after I tuned mine it doesnt knock and I run the afr around 12's at WOT at 1.3bar...with the stock map it runs 10's at 1.0bar and the more boost it doubles the knock...so to sum it up AFR is to low timing is to high and running it above 1 bar=
FS: Ej20g motor, ECS merged wiring harness, apexi pfc with boost controll kit, td05 slava from goshen 1993 - 2001 Impreza Specific Parts 30 10-28-2008 08:53 PM
FS: Ej20g motor, ECS MERGED wiring harnes, apexi pfc with boost controll kit, td05 slava from goshen MWSOC Private Classifieds 15 10-23-2008 10:58 PM
EJ20G > apexi PFC DrunkenDragon Subaru Conversions 2 07-05-2008 07:02 PM
APEXI IHI RHF5 VF22 - Plug and play for EJ20G almost for EJ22T keirnna 1993 - 2001 Impreza Specific Parts 2 05-07-2008 11:16 AM
Apexi PFC on a EJ22T Farfrumwork Pre-2002 Factory Turbo Powertrain 23 04-18-2008 10:10 PM
Message Board Statistics All times are GMT -4. The time now is 05:14 PM.
