Old 04-06-2009, 07:22 PM   #1
Weiss
Member#: 139753
2000 2.5RS Built
Default BC 280 cams
I hear you need a 1K plus idle, and a pain to drive on normal. Anyone have first hand experience? Im stuck between 272 and 280 cams.
Weiss is offline   Reply With Quote
Old 04-06-2009, 08:40 PM   #2
moorebl
Member#: 59238
i wonder this too as the BC's are too cheap to pass up compared to others
moorebl is offline   Reply With Quote
Old 04-06-2009, 10:17 PM   #3
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
ive got some 280's goin in my car. waiting to get the tranny back from andrewtech though. knuck up how bad can it be? if youve got the power to go along with it youve already got a hard stiff clutch which will probably be the hardest part.
i dont really see why it would be a pain? yeah its going to be a rough idle but thats about it. personally i cant wait for the shaky lopey idle, its what im looking foward to most.
godforbid67 is offline   Reply With Quote
Old 04-07-2009, 03:05 PM   #4
Weiss
Member#: 139753
2000 2.5RS Built
Anyone with them in there car with drivine experiance?
Old 04-07-2009, 06:21 PM   #5
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
I don't have BC 280's but I have Cosworth 275's in my car and can tell you big cams don't like it down low in the RPM band. Its not really that bad and may be exaggerated by my light weight flywheel but if I were to add a unsprung clutch and a huge laggy turbo it would definitely suck. On stock ECU cars the return to idle is somewhat shaky and you don't get the blip-able throttle response you expect at 800-1000 rpm. Its a whole different ball game 4K - 8K though.
Old 04-07-2009, 10:13 PM   #6
nuppy
Member#: 145656
2005 sti
black
I have BC 280's and my car idles fine at normal rpm. It doesnt have a lope to the idle either.
nuppy is offline   Reply With Quote
Old 04-07-2009, 10:34 PM   #7
CKxx
Member#: 33458
Your BOV sounds lame
93 RX7+09 Forester
That is rather unfortunate.
Slightly Off-Topic, but if you search youtube for "STi 280 cams" (or something like that) there is a sweet video of a Silver STi idling. It sounds absolutely amazing.
EDIT: http://www.youtube.com/watch?v=aNyIAmsX3QU
CKxx is offline   Reply With Quote
Old 04-07-2009, 11:43 PM   #8
ERICS02WRX
Member#: 53543
02 wrx wagon
red
I have the BC 272 with BC springs, built 2.5, cp pistons, Bc rods, GT30 .82, TGV deletes, 6mt, ACT HD 6 puck and lightweight flywheel, etc.... I have no problems at all with the cams, they idle like the stockers after the car is warm and have great off boost drive ability.
ERICS02WRX is offline   Reply With Quote
Old 04-08-2009, 01:45 AM   #9
kellygnsd
Member#: 32669
LINK G4 hybrid STi
Are you non-STi cam guys with 272 or greater cams idling at the stock 750 rpm or higher?
Old 04-08-2009, 11:44 AM   #10
godforbid67
Member#: 137168
06 Built SGM WRX
i dont think any aftermarket cams idle at 750 anymore.
Old 04-08-2009, 01:21 PM   #11
godforbid67
Member#: 137168
06 Built SGM WRX
are you sure?? i dont see how that can be possible. those are pretty big cams and its hard to get them to idle smooth have any videos? what else is done to your motor?
Old 04-08-2009, 01:34 PM   #12
jays05
Member#: 78165
05 STI 35r + e85
STI (avcs) cam gears = smooth idle
WRX (non-avcs) cam gears = lumpy idle
jays05 is offline   Reply With Quote
Old 04-08-2009, 01:44 PM   #13
godforbid67
Member#: 137168
06 Built SGM WRX
yeah but how smooth jay?? i just dont see any cams over 272 idling like stock or too close to stock
Old 04-08-2009, 02:26 PM   #14
jays05
Member#: 78165
05 STI 35r + e85
Well I have the cosworth 278/274 cams, and while my idle is not perfect it's nothing like a cammed motor with WRX cam gears.
Wanting big cams and good idle is like asking for a really big turbo with good spoolup.
Old 04-08-2009, 09:03 PM   #15
nuppy
Member#: 145656
2005 sti
black
stock pistons and rods, ap fuel rails, tgv deletes, 280 cams, 20g with 3in inlet and 8cm exhaust, 850 injectors, 12mm oil pump, header/up, catless tbe
Old 04-08-2009, 10:55 PM   #16
godforbid67
Member#: 137168
06 Built SGM WRX
true, but thats an odd set up. why no pistons or anything??
why a 12mm oil pump and big cams for a turbo thats not so big on the top end? i mean why even do headwork when you have a stock block?? sorry to be off topic just curious.
Old 04-09-2009, 12:18 AM   #17
sorrowfulkiller
Member#: 170439
I <3 Lamp
It's always a good idea to plan for the worst with stock internals, hence the oil pump
sorrowfulkiller is offline   Reply With Quote
Old 04-09-2009, 01:11 AM   #18
nuppy
Member#: 145656
2005 sti
black
This is my second 20g. The first one i had i beleive went out from oil starvation so i tapped into one of the blocks oil galleys and stepped the pump up since i had one laying around. stuck with stock interals mostly because of price, but then again people are running some power on stock internals so im not too worried about hurting it. people always complain about their 20g's falling way off but for some reason i havnt really had this problem too much.
Old 04-09-2009, 01:27 AM   #19
ERICS02WRX
Member#: 53543
02 wrx wagon
red
I am running a 2.5 sti built long block in a wrx with no avcs and BC 272, and it idles just like stock but 100 rpm higher.
Old 04-09-2009, 01:47 AM   #20
motoryder
Member#: 111268
.... MLTMFA2
I daily drove my wrx with the BC 280 cams. It was definately lopey and I idled around 1k rpm. If you weren't careful coming to a stop the car would stall every once in a while. That might have had something to do with the tune though.
motoryder is offline   Reply With Quote
Old 04-12-2009, 01:04 AM   #21
godforbid67
Member#: 137168
06 Built SGM WRX
why would it stall when coming to a stop???
Old 04-12-2009, 02:07 AM   #22
kellygnsd
Member#: 32669
LINK G4 hybrid STi
The return to idle control is a little flaky with bigasscams on the stock ECU. RPMs have to drop below the set point before idle control begins. Sometimes it picks up too late.
Old 04-12-2009, 02:33 AM   #23
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
not just on stock ECU's, but on standalones also.. Price of fame really..
jigga is offline   Reply With Quote
Old 04-12-2009, 01:06 PM   #24
godforbid67
Member#: 137168
06 Built SGM WRX
hmmm interesting i didnt know that, ill have to get used to it.
so basically make the drop to idle as short as possible huh?
Old 04-12-2009, 02:42 PM   #25
berdugo
Member#: 163108
07 EuroDM STi 2.5L
how big of a cam before it becomes a problem? I heard lots of good things with GSC S2
berdugo is offline   Reply With Quote
F/S: BC 280 Cams motoryder SCIC Private Classifieds 12 03-03-2010 12:33 PM
FS (pa) bnib bc 280 cams, Valvetrain kit, Arp Studs [email protected] Engine/Power/Exhaust 3 05-04-2009 07:09 PM
BC 280/280 AVCS setup sofiagonza Built Motor Discussion 8 04-27-2009 05:33 PM
built motor thinking of getting BC 280 cams moorebl Built Motor Discussion 1 03-29-2009 01:14 PM
