Old 04-06-2009, 07:55 PM   #1
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
Default 06 WRX 300whp on a budget [evo3 16G on the 2.5]
300whp / 355tq on a mustang "heartbreaker" dyno running E85 (dynoed with E70)
Dyno Data
Quarter Mile Data
Track opens mid april. Will post up.
Should be good for 11's somewhere between 110-115mph, feel free to call bets.
Relevant Mod list
TurboXS Utec delta &
Romraider flash
FIC 850CC injectors
Walbro 255lph
LFR7AIX plugs
K&N Short Ram
Chinese TMIC (topmount, easily)
GM BCS (bad)
[Stock motor, stock headers]
UR upipe for 38mm EWG
Tial 38mm EWG
TD05H-16G6 ("evo III") from forced performance - ported - new
Helix catless DP 3"
Custom midpipe 3"
Blitz Nur Spec R axleback 3"
ACT Prolite (10lb) flywheel
ACT 6 puck clutch
Enkei RPF1's (I guess since we're talking about flywheel mass)
AEM wideband
maddad EGT (bad) with TRE thermocouple
Media
Videos will be up soon...
Tune Information and comments
Tuned by me, on Emery's loading chassis dyno without management that can steady state (don't laff LOL). I bought the Utec before the western NY area had a dyno so it wasn't a cost-effective priority at the time. As I said the car runs E85 from the pump, sometimes a challenge requiring black arts and magic in the winter but the benefits are enough that I'll never run gas again, although I keep my utec switch ready with a 93 map for on the fly switching). I've been running it since July with amsoil and I have the data to back up everything is running clean: http://forums.nasioc.com/forums/show...postcount=1969
Fuel:
The 850cc injectors run 85% at peak near redline, between 60-70% right after spoolup with fueling at .75 at torque peak (thats 7.3:1 AFR) to about .85 (8.3:1) [none of this corrected for the class 3 ethanol blend mind you] with a peak EGT of only 1425 degrees F!!!
Boost:
Boost with the ****ty square wave GM BCS peaks at 25 PSI at torque peak and woodpeckers nicely down to 19-20 near readline.
Timing:
Timing from ~10 degrees at prespool to 20 at peak torque to 34 at peak power.
AVCS
Fuel spec for the FIC's (derived from scratch :-/):
GM BCS info:
Est* MAF scale:
*Fuel trims are spot on in closed loop but I have no idea if its scaled right up top... :-/
Utec has some different requirements:
Fixed latency at 1500usec
Injector scale: 850
Stock Injector Scale: 550 (yes I retained the exact numbers without fudging) (Instead fudging came with the VE map for speed density)
+25% on the fuel map to achieve .75 +19% to achieve .85
Notes:
Ambient temp: 67 degrees. IAT's still 85-95 degrees, TMIC had a fan on it but theres no way it was cool, just alcohol ftw.
Jasonzemos is offline   Reply With Quote
Old 04-06-2009, 07:59 PM   #2
whitewagon8619
Member#: 174852
2005 wrx wagon
hybrid swap 68hta
what are ur other mods?
whitewagon8619 is offline   Reply With Quote
Old 04-06-2009, 08:06 PM   #3
topguneagle1
Member#: 115620
2000 Impreza coupe
FALCON 9
wish i had that torque with my 16G!! nice numbers, perfect for street driving and the occassional romp. are you using meth?
topguneagle1 is offline   Reply With Quote
Old 04-06-2009, 08:12 PM   #4
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
No meth, just E85 from the pump. Im not even using it to its full potential by keeping the turbo within its efficiency range up top, and the torque curve has a bit of a buzz cut because its still the winter blend of E70, so I'm running 25 psi peak, I could easily run 27 and more timing and pick up a bunch more torque (boost spiked to 26 on one of the pulls and yielded 367ft/lbs as an example) could still push more boost down low with this turbo easily.
Old 04-06-2009, 10:25 PM   #5
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
FNF LSX Swap,E85 and more
You could push 27 psi on your stock block, careful , how long have you been pushing 25psi? Holy torque E85 is so much fun....
TDagen is offline   Reply With Quote
Old 04-06-2009, 10:32 PM   #6
Jasonzemos
Member#: 109993
2006 TR E3-16G'ed
Running E85!
I don't think the valves float until about 30 or so . Been running 25 since last august which toasted my stock clutch in 4th gear pulls, I was still able to run it for two autox events though. Compression was fine last I checked, I've only had maybe ~3 occurrences of det in the past year and they were probably closer to the onset phase rather than serious. EGTs have passed 1600 not more than 2 or 3 times ever. I'm a bit more worried about the transmission at this point.
Old 04-06-2009, 11:17 PM   #7
blkscooby
Member#: 44422
2009 G8 GT
Cammed, sprayed, stalled
U
Man, get a WBO2 in that thing pronto! Also, your AVCS could be improved greatly for spool and to help with topend HP. Other than that, looks good.
blkscooby is offline   Reply With Quote
Old 04-06-2009, 11:26 PM   #8
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
subscribed to see this car run 11's ..............
godforbid67 is offline   Reply With Quote
Old 04-06-2009, 11:31 PM   #9
TDagen
Member#: 163648
2002 Wrx,5.3L,S476r
My 5mt bit the dust with my 18g and [email protected] so yeah that would be one of my concerns too...
Old 05-20-2009, 03:49 PM   #10
farBeyondDriven
Member#: 127018
2006 WRX
Off topic, but what coilovers are you running? If they are coilovers...
farBeyondDriven is offline   Reply With Quote
Old 05-20-2009, 04:01 PM   #11
The_ManCub
Member#: 197010
2006 WRX vf39/ewg
CGM **Drunkmann tuned**
Dont you have a few vids on youtube with your old 93oct setup??
and what size are the rpf1's, 17? b/c they look real good haha.
The_ManCub is offline   Reply With Quote
Old 05-20-2009, 05:35 PM   #12
DirtyBanana
Member#: 211802
2003 Wrx
Sonic Yellow
Really nice setup. Probably pulls great. I would guess 12.1 at 114. However I hope you prove me wrong
DirtyBanana is offline   Reply With Quote
Old 05-20-2009, 06:13 PM   #13
VladiWrX
Member#: 145658
On my 5th scoob
and lovin it
I doubt it will pull 11's but have no problem being proven wrong
VladiWrX is offline   Reply With Quote
Old 05-20-2009, 06:35 PM   #14
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
how did you come up with your AVCS numbers for 4800-redline below 1 load?
also, whats the reason for the drop n rise in teh avcs at 4400-5600 rpm?
and cars run 11's with 300whp on that dyno?
I would copy tomei's avcs numbers from here
http://www.tomei-p.co.jp/news/Report-EJ25-V1.html
35* at 3600 tapering to 0* at 6400 rpm.
Japanese views on the 2.5?? C-grunt General Community 37 02-15-2008 02:37 PM
For the record. TD05-16G on a 2.5, no boost creep Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 19 06-26-2007 04:57 PM
anyone ever tried a 16g on a 2.5? ted dibiase Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 62 01-05-2007 10:20 PM
Does anyone know the red line on the 2.5 US STI motor? alfriedesq STi Forum Archive 20 02-25-2003 02:14 AM
update on the 2.5 turbo.... andrewmva Tri-State Area Forum 0 09-27-2002 05:58 PM
