#1 |
Member#: 179450
Vehicle:2004 WRX Silver |
Will hot tanking my block by the machinist get rid off all the particles in the oil galleries? I don't want to get another spun bearing after the build from a block oil passage or particles getting in the bearings. If not, is there a process that will?
Thanks guys!
#2 |
Member#: 203935
it should. Any descent machine shop will have a step by step process to properly clean out a short block. Make sure you also address any oil cooler, lines, cylinder heads and such. Anywhere oil gets. And always replace you're oil pump when handling something like this.
#3 |
Member#: 77470
Vehicle:04 sti 10.51@138.5 on e85@ 30psi--spinning |
do not re-use the oil cooler,if you had a lot of material floating around it is almost impossible to get it completely cleaned out.Also a good amchine shop should remove all galley plugs before hot tanking and then flushing all passages with clean water and then blowing out with compressed air. good luck
#4 |
Member#: 64673
NWIC
Vehicle:1990 Legacy wagon goes 12.387 @ 116.5 |
I TRY to always remove EVERY hex plug (the 8mm and 10mm) and bolt that the block has connected to it when have my blocks bored/honed and hot tanked.
#5 |
Member#: 192599
Vehicle:2004 STI 2007 Outback Wagon |
I always cleaned the block myself after coming from the shop, too. I good set of pipe brushes help.
#6 |
Member#: 32669
SCIC
Vehicle:2007 FR TS EFR 7670 LINK G4 hybrid STi |
That is a must. I wouldn't just assume the shop doing the hot tanking will do this either so make sure you ask them or remove the plugs yourself.
| Thread Tools | |
| Display Modes | |
| To get rid of ABS or to not get rid of ABS? | oldhat | Brakes, Steering & Suspension | 27 | 09-11-2008 12:01 AM |
| Finally getting rid of the Durango and will be getting... | gregor2001 | North West Impreza Club Forum -- NWIC | 11 | 02-28-2006 03:10 PM |
| will getting a new front sway and endlinks get rid of softness in steering? | wrxxtc | Brakes, Steering & Suspension | 6 | 10-17-2002 02:33 PM |
| Round 2- Anybody Willing to Get Rid Of Stock Legacy GT Struts | MY99 2.5GT | Legacy Forum | 3 | 03-27-2002 04:26 PM |
| Anyone willing to get rid of their stock GT Sedan Springs? | MY99 2.5GT | Legacy Forum | 10 | 03-25-2002 08:18 AM |
