Old 04-06-2009, 10:34 PM   #1
oddwater99
Member#: 203561
1999 Impreza wagon
Custom painted semi-flat
Default 2.2 Supercharged
Just wondering if anyone has heard anything about Supercharged subys?. Another thing. would a dual stage intercooler work. Have the charger run to a cooler in the scoop then have piping running down to a front mounted intercooler. Give me feed back please.
oddwater99 is offline   Reply With Quote
Old 04-06-2009, 11:14 PM   #2
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
There is a kit now available for purchase. It is a procharger-style centrifigal kit, not sure if I can link to other forums since they aren't vendors here.
Doubling up the intercoolers is a waste of money. If you're running 5 PSI on a high compression motor (10:1) then you most probably don't need an intercooler anyway. If you're running 12 PSI of boost, you probably want one intercooler. If you're running 40 PSI and your air temp at the intake manifold is up into the 700 degree range without an intercooler, and with a single intercooler it's still in the 400 degree range, then yes, you would want to double it up. But that would be retarded, you would pop your motor due to massive amounts of knock and ping because the intake charge would be retarded hot even after interdcooling.
Chi_San is offline   Reply With Quote
Old 04-06-2009, 11:46 PM   #3
reddevil
Member#: 64673
1990 Legacy wagon
goes 12.387 @ 116.5
2.2 heads on a 2.0 block chong74 Subaru Conversions 24 06-06-2010 04:41 AM
Impreza 2.2 ecu needed jrzpdx NWIC Private Classifieds 1 06-04-2010 06:41 PM
Once again, the Supercharged 2.2 passes the test. reddevil Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-15-2004 07:59 PM
Ludespeed Stage 2 or Supercharger joefocker20 Normally Aspirated with bolt-on Forced Induction Powertrain 5 10-21-2002 01:40 PM
Is there a turbo/supercharger kit for the 2.2? KaZ General Forum Archive 7 02-23-2001 01:41 AM
