Old 04-06-2009, 09:37 PM   #1
surfer5567
Member#: 61199
2002 wrx wagon
wrb, s2, blouch 2.5, 6spd
Default keep getting a p0103 code...need suggestions
so from what i have read, this is basically my maf is being maxed out, so i am looking for suggestions on which big maf to go with. can you go TOO big on a big maf? what brand would you go with?
my set up is a crawford built block, PnP heads w/ supertech valvetrain, gsc cams, avcs is NOT hooked up, bloch 2.5 turbo(will be a 3.0 or equal really soon)
thanks for all the help!!
surfer5567 is offline   Reply With Quote
Old 04-07-2009, 01:35 AM   #2
surfer5567
Member#: 61199
2002 wrx wagon
bummmmpppp....need to know soon as i am getting retuned for built heads and dont want to pay twice
Old 04-08-2009, 04:04 AM   #3
surfer5567
Member#: 61199
2002 wrx wagon
bump...looking for big maf help
Old 04-08-2009, 09:31 AM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
what ecu are you using?
there is no P0103 trouble code in my 2002 fsm
Old 04-08-2009, 09:35 AM   #5
jays05
Member#: 78165
05 STI 35r + e85
ECUflash says P0103 is "MAF Sensor High Input". A 70-80mm maf tube should work well.
jays05 is offline   Reply With Quote
Old 04-28-2009, 10:29 PM   #6
Aus-10
Member#: 184898
I got the same code today and it's definitly P0103. I'm running just stage 2 reflash though. A snap on scanner says the problem cause is:
1- A big vacuum leak
2- A damaged air duct hose
3- A mechanical Problem
and 4- Broken MAF
I can't find any vacuum leaks and I don't have a way to test my maf. Any ideas where to start instead of buying a new maf ??
Aus-10 is offline   Reply With Quote
Old 04-29-2009, 12:35 PM   #7
Fongers
Member#: 118239
2002 Built Wagon
Wife- 2004 Outback SE
Get a tatrix cable and log it. Then you can also reflash with open source if needed.
Fongers is offline   Reply With Quote
Old 04-29-2009, 10:42 PM   #8
Aus-10
Member#: 184898
It has been reflash with open source, but what is a tatrix cable?
Old 05-02-2009, 04:34 PM   #9
Aus-10
Member#: 184898
Tell me how strange this is. I changrd my oil because it was about time for one, and it took away the code! This just blew my mind that i fixed a maf code by changing my oil.
Why do I keep getting this code? kingstarlet AccessPort 11 01-11-2008 12:34 AM
Looking to get a new camera, need suggestions... Stime187 Off-Topic 8 05-02-2006 03:39 PM
Keep getting a missfire code on #1 jacksonww1 Legacy Forum 5 12-21-2004 02:23 PM
I keep getting the misfire codes BLACKUTECSTI04 Service & Maintenance 2 12-14-2004 05:07 AM
P0457 Code Keep getting it Works Engine Management & Tuning 16 07-04-2003 12:19 PM
