Old 04-15-2002, 11:28 PM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Angry What the heck happend to my rev limiter?
Okay, I was driving down the street, when some idiot came into my lane w/out signaling and so I punched the engine and moved into the other lane. For a brief period my engine revs to like 6500, I noticed while glanced down after making my maneuver to avoid the idiot. This has happened before. I'm not even aggresively downshifting, but I don't see or feel my rev limiter kick in. The engine seems fine. This has happend a couple times before.
HomerJay is offline   Reply With Quote
Old 04-15-2002, 11:48 PM   #2
wistful
Member#: 745
2004 STi
Java Black Pearl
our tachs aren't super-accurate. idle says 500, S-AFC reads 700. my fuel cut-off is 6500ish... S-AFC reads 6250! dont worry.. everything is ooook.
Don
wistful is offline   Reply With Quote
Old 04-15-2002, 11:58 PM   #3
obyone
Member#: 16523
Don
I noticed that too....the Redline is supposed to be 6200 but the tach will go to 6500. I had to learn to ignore the redline on the tach when shifting.
Kinda annoying if you ask me.
obyone is offline   Reply With Quote
Old 04-16-2002, 03:10 AM   #4
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
very annoying.
jeremy
Old 04-16-2002, 04:21 AM   #5
outback2.5HO
Member#: 15135
95 GF WRX
Checked the rev limiter rpms with my scan tool the other day... Tach read 6500, scanner read 6450. Not too far off.
Need to kick it up to 7500, that damn rev limiter!
outback2.5HO is offline   Reply With Quote
Old 04-16-2002, 12:20 PM   #6
RaceCarRiot
Member#: 6542
1997 Ver IV
talk to the 'ganz (i guess that's like the fonz)...he can send your ECU out to be re-mapped and raise the rev limiter.
the EJ valvetrain is supposedly good for an 8000 rpm redline. our engines are VERY understressed from the factory.
RaceCarRiot is offline   Reply With Quote
Old 04-16-2002, 12:56 PM   #7
spiralsmurf
Member#: 16085
2005 STi
can the stock fuel system support those higher rpms? if so i'd like to find out how to raise the rev limiter and does the proecm do this?
spiralsmurf is offline   Reply With Quote
Old 04-16-2002, 01:13 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
you rev limiter is 6450 because you have hte DOHC 2.5...the SOHC 2.5 redlines @ 6250.
jeremy
Old 04-16-2002, 01:14 PM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
remap your ECU and no the proecm chip won't remove the rev limiter.
jeremy
Old 04-16-2002, 02:42 PM   #10
wistful
Member#: 745
2004 STi
Java Black Pearl
I'll tell you guys in 2 weeks.
Don
Old 04-17-2002, 11:19 AM   #11
RawCode
Member#: 3115
2002 Impreza 2.5RS
If you do any major raising of the rev limiter. May I suggest the Cobb lightened valvetrain package? With going above 7000 RPM I would be worried about valve float...
RawCode
RawCode is offline   Reply With Quote
Old 04-17-2002, 12:19 PM   #12
RaceCarRiot
Member#: 6542
1997 Ver IV
RawCode -- with the smaller bore EJ engines (1.8, 2.0, 2.2), i don't think it would be an issue, provided you didn't hold the engine at 8000 for long periods of time. on an EJ25, anything over a 7000rpm cutoff, i would probably upgrade just to be on the safe side. the occasional quick run to a higher redline wouldn't do any harm, but holding it at or near engine speeds that high for extended periods probably would weaken the stock valve springs post haste.
-adam-
Old 04-17-2002, 07:39 PM   #13
RawCode
Member#: 3115
2002 Impreza 2.5RS
True true... I was thinking more of my big block 2.5. Forgot to check what size engine you guys were chatting about.
RawCode
Old 04-17-2002, 10:55 PM   #14
BlackGT00
Member#: 4658
2000 Legacy GT
Black granite pearl
There's not much point in revving past the set rev limit as our stock cams are pretty much out of breathe at this point. So it doesn't much matter if the materials can handle it, unless of course you've changed the cams.
Kevin
BlackGT00 is offline   Reply With Quote
Old 04-18-2002, 02:39 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Kevin
exactly
Old 04-18-2002, 06:37 AM   #16
hobun2
Member#: 16831
2000 Legacy L
Dark blue
Maybe checking the peak HP and TQ for a given RPM would be good also.
I have a 1.8l and according the specs, I get:
110 HP at 5600rpm
110 TQ at 4400rpm
I guess that anything over 5600rpm in my case is jut a waste of gas and risking premature wear or engine components. Then again, I may be wrong...
hobun2 is offline   Reply With Quote
Old 04-18-2002, 12:43 PM   #17
RaceCarRiot
Member#: 6542
1997 Ver IV
yeah, i forgot the stock cams are about as aggressive as a bic pen.
i was just speaking in general terms...yes the valvetrain is up to the task, but there's really no point, in terms of making more power. HOWEVER, i would like another 1000rpm to work with so that when my revs drop on up-shifts, i'm still in my power peak.
-adam-
Old 04-18-2002, 10:53 PM   #18
BlackGT00
Member#: 4658
2000 Legacy GT
Black granite pearl
When you up-shift you want your revs to be at max torque not max horsepower. Shifting at or above redline is not always the fastest way to accelerate.
Kevin
What the heck happened to my headlamp?!!!! bObby Interior & Exterior Modification 13 10-23-2007 10:03 PM
what the hell happend to autotrader? U have to pay now! Keith Off-Topic 12 07-19-2005 10:33 AM
Columbus OH, Columbusracing.com What the heck happend? WRallyBlue02 Mid West Subaru Owners Club Forum -- MWSOC 3 04-05-2004 08:26 PM
woh put the brakes on, what the H happend to scoobymile.com? kenshiro Off-Topic 14 01-23-2004 02:11 AM
What the hell happend to my oil? 25psi Normally Aspirated Powertrain 12 01-31-2003 11:06 AM
