Old 04-07-2009, 02:32 AM   #1
Ioku
Member#: 164864
95 Impreza coupe
Default JDM ej22 any better than USDM
So I just picked up a JDM ej22, not a turbo block or anything just an N/A ej22 out of a JDM car, as far as I can tell its the same as any other ej22, but I remember seeing a list on here of all the different EJ engines and remember seeing that in Japan they go some variations of the ej22 that we didn't like some lean burning higher mpg one and I think one that made I little torque if anyone know what list I'm taking about and has a link that would be great.
And would there be any way too tell if my engine is any different than a normal usdm one.
Ioku is offline   Reply With Quote
Old 04-07-2009, 03:10 AM   #2
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Unless you tore it apart, which you might want to do anyway. Replace the timing belt, headgaskets, cam and crank seals, valve cover gaskets, thermostat, inspect the water pump and knock sensor, take a couple pics of the pistons....you know, the usual stuff.
~Josh~
Is this JDM intake manifold any better than the standard US one? EJ20911 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-06-2009 05:52 PM
Jdm Can't Get Any Better Than This ! Awd247 Member's Car Gallery 13 06-05-2009 10:59 PM
JDM 6 speed better than USDM ? IllNastyImpreza Transmission (AT/MT) & Driveline 0 02-01-2007 01:31 PM
Are Sylvania Silver Star any better than the PIAA SuperWhite? Leonardo Interior & Exterior Modification 64 11-09-2002 11:28 PM
