Old 04-07-2009, 02:59 AM   #1
SILINC3R
Member#: 198052
1991 Legacy SS
Rio Red
Default 95 impreza swap to STi
so I know it has been done but what is the price of doing it yourself versus a shop. it would be awesome doing it myself and cheaper i assume and more badass to say that i did it. but at what price for the stress and the time. im going into the Coast Guard and will have access to garages and tools, i have some knowledge but most of it is simple stuff.
car would be a 2 door coupe basic L M/T, hopefully not sunroof and roll up windows. swaping in STi motor with drive train, disk all around. hoping to keep dash or maybe go STi which ever is better not sure yet. body kit or 2.5RS body. FMIC FTW just looking for 300+ HP in a car that would be light as a feather.
so as long as you get the same dash as the motor and trans it is fairly easy since the is no splicing?
what prices for a motor and trans.
car looking at $2000 easy
SILINC3R is offline   Reply With Quote
Old 04-07-2009, 12:49 PM   #2
davedaman77
Member#: 177385
08 2.5i
SSM
If you go JDM STI you can get an older version I-IV for ~$2000 with a transmission and maybe if your lucky the rear diff. But, you'll have to source the knuckles all the way around, driveshaft, halfshafts, and if you want the huge 4 pot calipers they're going to be expensive.
Any newer version than I-IV will be rediculous. Like I've seen them go for <$6000.
Unless you just have to have it, I would go with like a version IV or V JDM WRX, because they're rated at the same PS (which is Japan's rating system like our HP. 1PS = ~1HP) as the STI, because of restriction laws. So, they both came with 280PS, so alittle under 300HP. That's just my opinion, plus it has less wires making your wiring job easier, because the newer motors have AVCS and stuff.
It's all up to you though. STI would be bad ass. If only just for the novelty of it.
Oh, and that's assuming you did it all yourself. I did all mine.
davedaman77 is offline   Reply With Quote
Old 04-07-2009, 03:12 PM   #3
SILINC3R
Member#: 198052
1991 Legacy SS
Rio Red
so you did a USDM and what was the price. the only reason why i decided not to do JDM is i thought i read somewhere that it is harder to find parts or to tune it or something like that. i can live with high price if i do it myself. im hoping if i do it myself i can do it for 10k. i would rather have the STi USDM. you think you could disclose all the parts like did you swich out the brakes for WRX and whatever else. im guessing your car is a beast since they are so light which is the main reason why i want to do this
Thanks
Old 04-07-2009, 03:37 PM   #4
davedaman77
Member#: 177385
08 2.5i
SSM
I did it if a GF, because I love my wagon. So, a bit heavier, but NO ONE suspects it when I roll up. Brakes wise, I switched over to all the same parts that went with the car. Like, I bought a 1997 JDM WRX RA motor and switched everything over, it came with the entire wiring harness, trans, front and rear half shafts, rear cross member, rear diff, and all 4 knuckles, so I had everything I needed right there. It cost ~$2000 for everything. Oh, and I also got a full 3" exhaust and TEIN coilovers. JHOT hooked me up. Haha. So, if you do it yourself than you can save TONS. The only part that scared me was the wiring, but it wasn't that difficult when I started cutting and splicing.
Old 04-07-2009, 05:09 PM   #5
MasterKwan
Member#: 98961
2003 WRX
Cost me 8K and 2 months of effort. Bought a wrecked STI parked it next to my WRX and started swapping. I swapped everything but, the interior (which didn't come with the car).
Old 04-07-2009, 10:57 PM   #6
SILINC3R
Member#: 198052
1991 Legacy SS
Rio Red
so i guess it cost you so much since you bought the whole car
Old 04-07-2009, 11:00 PM   #7
SILINC3R
Member#: 198052
1991 Legacy SS
Rio Red
WOW that is a great price if i could get a car for 2000 and spend 2000 for the motor, tranny, knuckles and what ever else that would be one hell of a budget build. they still have all this stuff. so you havent had any problems using the JDM. also did you use the same dash or did you convert
Old 04-09-2009, 01:33 PM   #8
subie_chick
Member#: 198910
hey, im doing somewhat the samething, but im going to be buying an AWD 95 4 door impreza. i want to do the wrx swap but im not sure if it'll be easier and mostly cheaper to get a front clip or to order everything seperately...
subie_chick is offline   Reply With Quote
Old 04-15-2009, 01:57 PM   #9
davedaman77
Member#: 177385
08 2.5i
SSM
Front clip is a bit more expensive, but you wont have to try to find as many parts. So, it's a bit simpilar for the extra money.
And no, I didn't bother trying to swap any interior. That's just too much fab work.
Old 04-15-2009, 02:39 PM   #10
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
if you buy a jdm front clip you dont use the dash, unless you swap to RHD. i bought a V4 STi front clip to do my swap (EJ20K). it takes a bit of wiring if you want to use the JDM cluster and have everything work, same with the engine. if you're not afraid of wiring not to complicated to do, just time consuming.
just so you know, my front clip came with the following:
front cut, dash, front STi seats, rear STi seats, gold 5spoke rims w/tires, rear trunk/spoiler (but its a toyota spoiler??), gas tank w/fuel pump, rear hubs/suspension (sway bars and everything), rear diff with LSD, front hubs/suspension, 4pot sti front calipers, front V4 bumper, fenders, aluminum hood, head/corner lights and fog lights.
was missing the v.4 bov and rear calipers.
bought it for aprox 5k with shipping and import duty.
Rei_Akira is offline   Reply With Quote
Post your Impreza wagon swapped to STI chimchimm5 Member's Car Gallery 12 03-21-2013 05:34 PM
95 impreza sedan to 99rs conversion? turboterrorky Interior & Exterior Modification 4 03-12-2010 06:24 AM
95 Impreza L to WRX brakes - is there a "best" year? Type2 Brakes, Steering & Suspension 0 09-16-2009 10:22 AM
99 impreza swapped to a 96 rhd sti gregprecourt94 Newbies & FAQs 8 05-28-2007 12:57 PM
95 impreza swap Allgood2386 Subaru Conversions 2 04-19-2004 02:47 AM
Message Board Statistics All times are GMT -4. The time now is 05:34 PM.
