Old 04-07-2009, 11:45 AM   #1
NORAB
Member#: 166375
2002 Impreza WRX
Default I need best injector size and opinions...
i got a '02 WRX and i want to go ahead and upgrade my injectors for a 16G turbo (its the ebay one).
I have DP/UP along with K&N Typhoon on the care right now along with the stock TD04. I am planning to get the fuel pump, GM solenoid and a bigger TMIC...im looking for something close to 290-300 whp...will i get that goal with a good tune or should i consider getting other parts/modifications? also...
...will Sti pinks be big enough?
...would headers be beneficial to the motor as well?
-sorry if all this was covered already in other threads, im busy these days and i dont have too much time to dig in this site like i used too.
NORAB is offline   Reply With Quote
Old 04-07-2009, 02:47 PM   #2
kellygnsd
Member#: 32669
2007 2.34LR, EFR7670
LINK G4 hybrid STi
Maybe, depending on you tune. 750's would be better and you'd be good when you decide to upgrade(you will )
Questions like this are retarded. Do you think people put headers on their cars because they want less Hp? No. There are drawbacks though, are you prepared for them to crack? You may loose some low end torque, you may not. The question you should have ask is do I need headers at this stage and the answer would be no.
Old 04-07-2009, 03:13 PM   #3
NORAB
Member#: 166375
2002 Impreza WRX
thanks...
Old 04-07-2009, 11:08 PM   #4
kcscoob
Member#: 31222
2005 Legacy GT wagon
6 speed, BNR 18G, E85
Default deatchworks
Deatchworks has an injector calculator on their website. It is really cool. You might check it out.
kcscoob is offline   Reply With Quote
Best injector size for a vf34 setup TheYonks Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-17-2010 03:24 AM
Built RS-T injector sizing and general questions. ZeroDrift Built Motor Discussion 5 03-20-2009 02:33 AM
Best rim size and how low to lower it??? Thursty dawg Interior & Exterior Modification 2 04-07-2008 01:25 PM
EJ22 SOHC Injector Size and Compresion ratio Mechkiller31st Normally Aspirated Powertrain 18 10-15-2007 02:11 AM
what is the best tire size and brand for stock rim? nav Brakes, Steering & Suspension 2 03-21-2001 08:33 PM
