Old 04-07-2009, 03:46 PM   #1
truckco5
Member#: 146406
2007 WRX
Pearl white
Default built proof engine
Iam planing on building my motor from my 07 wrx for a blouch dom 3.0, or the 4.0. This is my plans for my motor built.
My motor rebuilt
-wesco pistions
-manley turbo tuff rods
-cosworth bearings
-stock crank
-manley valves and springs
-GSC cams
-subaru gasket kit, oem head gaskets
-ARP head studs
-kevlar timing belt
-arp case blots
-Does anyone have any of these parts. If so how were they and power runed with them.
-Power this could handle?
-Also would it be cost effective to order a pre-built from raw or cosworth.
truckco5 is offline   Reply With Quote
Old 04-07-2009, 04:08 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
it depends who you have building your motor, personally i like that MY motor was built specifically for me by my specs. but by no means is a raw motor or cosworth motor not worth it. they very muh so are.
plenty of people are running those parts. for a dom 3 that would be fine, even a stock engine could almost handle a dom 3. but for a 4 idk, im not too familiar with those rods or pistons. maybe a different set for a om 4.
godforbid67 is offline   Reply With Quote
Old 04-07-2009, 04:30 PM   #3
mxpunk
Member#: 132130
2002 Ford F-150
Graphite Gray
keep it below 300 whp and it'll be "bullet proof"
mxpunk is offline   Reply With Quote
Old 04-07-2009, 04:39 PM   #4
godforbid67
Member#: 137168
06 Built SGM WRX
yeah was he trying to say bullet proof?? if so get the dom 3 on 20 pounds with that motor and you should b fine.
Old 04-08-2009, 03:33 PM   #5
ScorpionT
Member#: 195677
Ive used Manley, Cosworth, ARP, Wiseco, and GSC. All good brands!
ScorpionT is offline   Reply With Quote
Old 04-08-2009, 06:45 PM   #6
truckco5
Member#: 146406
2007 WRX
Pearl white
thanks for the info
Old 04-08-2009, 06:59 PM   #7
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
All those parts are going to be fine for the turbo you plan on running. The most important part is going to be machining and assembly. Then after that remember while the motor might be "bulletproof" it is not tuner proof so make sure it is tuned.
You also might considering doing a oil pump upgrade.
RealStreet is offline   Reply With Quote
Old 04-09-2009, 01:53 AM   #8
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
If you use the arp case bolts you should have your machinist do an align hone with those bolts torqued down with the halves together.
methaddict is offline   Reply With Quote
Old 04-09-2009, 04:22 AM   #9
Spec C Wannabe
Member#: 69170
For me, afterall, the clearance/tolerance checking, torque spec, torque sequence, cleanliness and assembly technics are equally important as those parts you listed.
Spec C Wannabe is offline   Reply With Quote
Old 04-09-2009, 07:30 AM   #10
THE-95-STi
Member#: 113734
2oo3 Vdub 1.8T
Subaruless(MAIC4LIFE)
I'm here to learn how to make my motor "Built Proof"
THE-95-STi is offline   Reply With Quote
NY Full PTS Built Proof 4EAT Trans VB and TC 5 Speed OEM Clucth Flywheel IceColdRex Drivetrain 90 10-04-2007 03:46 AM
Smart to buy an STi with 50-70k miles on it for built bulletproof engine project? Red Rexx General Community 27 02-04-2007 02:40 PM
How reliable is a well built STI engine? BBBsti LTD General Community 5 11-04-2006 08:06 AM
Any knowledgable people want to help me figure out why my built NA engine won't start SOLUTION New England Impreza Club Forum -- NESIC 40 05-20-2006 10:31 PM
