Welcome to the North American Subaru Impreza Owners Club Saturday December 27, 2014
Old 04-16-2002, 03:12 AM   #1
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Default Ahh, forget it, I'm gonna build her up!
OK, I think I'm scraping the whole WRX swap thing. It's time to get serious...Pistons, rods, and PEMS. Who has forged pistons? Better yet, who has forged pistons and dosn't have to wait 6 weeks to get them?
Paul...
hayscoob is offline   Reply With Quote
Old 04-16-2002, 03:22 AM   #2
scootr
Member#: 2649
00 2.5RS-t cpe BRP
64 chevelle SS
"I'm too old for this S**t" . Ha ha the 2.5 has been speakin' to you in your sleep. More power to ya..... You don't neeed no stinkin' 2.0L.
Scott
scootr is offline   Reply With Quote
Old 04-16-2002, 08:15 AM   #3
HubbieScooby
Member#: 7088
Super Slow
ahhhh i knew you would come back to us goood luck and keep us updated....my car is in the shop now for the turbo kit install
hugh
HubbieScooby is offline   Reply With Quote
Old 04-16-2002, 11:08 AM   #4
8Complex
Member#: 922
04 FXT
Red
Don't forget valve springs if you're running high boost or high RPM's. Valve float is a killer.
Old 04-16-2002, 12:06 PM   #5
AaronB
Worst Mod Ever
Member#: 369
12 Vagon
Exclamation Re: Ahh, forget it, I'm gonna build her up!
Paul...
Good luck with finding anything in stock. I stand by my earlier comments that you should get a temporary block, to drive on while your other one is being built. Much less downtime.
Try Cobb, Rallispec, or ISR. I can't think of any other places I would trust ordering from. If all three have to order them, I would go with Cobb without a doubt, as I think his have the most R & D to them. You should do rods as well while you are in the motor, IMHO.
I took me several months to get the right parts, I was down for 8 months for a variety of issues (mostly due to the vendor, who wasn't mentioned above).
Hope it works out for you.
Regards,
Aaron
http://www.AzScooby.com
http://www.ScoobyMods.com
AaronB is offline   Reply With Quote
Old 04-16-2002, 12:57 PM   #6
homegrownxt
Member#: 17659
What happened with the WRX swap?
Ken
homegrownxt is offline   Reply With Quote
Old 04-16-2002, 03:50 PM   #7
Andrew
Member#: 1170
2005 STi
Default Hallelujah, I have seen the light!
i was contemplating the ej20 swap as well and i came to the same conclusion, SCREW IT. the cost alone to swap it in and everythign would be more than it would cost for us to build up the engine to take 400+hp. and i, personally, was going to swap in the EJ20's transmission and swpa to manual (im auotmatic) but then i figured that it would be cheaper for me to build up the transmission. i dont have to worry about broken gears etc. plus could you imagine someone learning to drive a stick on an unwaranteed transmission? $$$. For some people, its perfect to swap. if you dont have a turbo kit then its definitely a choice. but for those of us who have a turbo kit, you might as well stick in some pistons, rods, ecu and then turn up the boost.
Just thought id let you know. I ordered some JE pistons (from JE themselves) last week in 100mm and 9:1 settings and i forgot the exact cost. its like 680 or something like that. and i think im just gonna do rods as well and say forget injectors for now. id rather finish up the internals so that i never have to open it up again. then itll just be "bolt on" bottom end stuff like cams and heads.
any recommendations for rods? im also going to stick in the Link2. can you say "charge it?" and can you say "work all summer just to pay off most of it oh well.
Andrew is offline   Reply With Quote
Old 04-16-2002, 04:51 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
Paul, glad to see your sticking with the EJ25. There's just nothing like the torque of the EJ25 turbo. Good choice and keep us updated on your buildup progress.
Graham
Graham is offline   Reply With Quote
Old 04-17-2002, 12:59 AM   #9
hayscoob
Member#: 4544
Bone Stock for now
I will keep you all informed as to the progress of the build. I have decided to have 8.5:1 forged pistons, forged rods, knife edged lightend crank, O ring the block, all new stonger gaskets and some other goodies. If I am lucky, it should take 3 weeks to complete the block. As for the boost levels, I will run low boost during breakin and then TechII will be the order of the day. Then I will kick it up a notch. Say, around 12-14 psi. We will see. I am only shooting for 300 hp. After a few months of financial recovery, I am going to go for stronger gears. Then I will see what she can really do. Stay tuned...and stay
Paul...
Old 04-17-2002, 01:52 AM   #10
homegrownxt
Member#: 17659
Paul,
What happened with the deal on the motor in Sac? Was there more damage to that motor than expected, or just more involved in doing the swap?
Ken
Old 04-17-2002, 02:12 AM   #11
hayscoob
Member#: 4544
Bone Stock for now
Ken,
The WRX motor I was looking at over there was a mess. There was two gaping holes in the intake manifold for both left bank cylinders. They started the motor and it barely ran. It was making all sorts of gags and spurts and such. The car it was in looked like it fell from a 10 story building. I was a complete loss. The front to the car had been smashed and broke the landing bracket for the AC compressor and alternator. They impacted the throttle body and made the gaping holes. They duct taped the holes up and started the motor again. It ran much better without the huge vacuum leak. Then I noticed a big problem from the left bank. Tic Tic Tic. The motor had a bad valve. I was thinking to myself "this motor is a pile of crap". I just can't bring my self to install a motor that was not perfect into my car. You know me, it's gotta be perfect. On the way home I was going nuts. I just couldn't make up my mind as to what to do. I finaly decided to build up my motor and keep my turbo kit. What the hell....looks like I will be driving the ol' van for a little while longer. I hope you don't mind....
Paul...
Old 04-17-2002, 03:05 AM   #12
homegrownxt
Member#: 17659
Hey Paul,
No problem in using the van, at least you'll be driving a "forced induction" vehicle,. Use it as long as you need.
I'm kind of enjoying the extra space in the garage so that I can work on the bike.
Sorry to hear that the WRX motor was trashed, it would have been a neat swap, a WRSX-T?
Ken
She's thick...and I'm gonna bring her home and ride her all night long Hotrodguru Texas Impreza Club Forum -- TXIC 42 01-29-2008 11:03 PM
OOOOOooooohhhh **** it, i'm gonna have a party! Dolphin Overton Off-Topic 10 03-04-2006 05:05 AM
I'm gonna do it. I'm gonna ditch the spare. AcquaCow Car Audio, Video & Security 21 08-01-2005 01:38 PM
