Go Back   NASIOC > NASIOC General > Motorsports > Autocross
Old 04-07-2009, 07:07 PM   #1
Zebe
Member#: 118698
07 WRX Ltd Wagon
94 Miata
Default Camber recommendations
I'll be running my first track day of the season in May, and am looking for recommendations for camber settings.
My last outing I ran -0.6 front and -1.5 rear (both stock). I had quite a bit of rollover in front. The car handled okay, but could do better. Since then, I have upgraded struts (Tokico D-specs), springs (STI), rear swaybar (22mm adj.), all endlinks (metal), and added camber bolts.
I can set camber at ~-1.8-0 and rear ~-1.5-0. I am thinking -1.5 front and -1.0 rear or maybe -1.0 front and -0.5 rear, but am looking for recommendations (with justification).
Zebe is offline   Reply With Quote
Old 04-08-2009, 01:56 AM   #2
jamal
Member#: 71875
98 Legacy GT
my wheels fit
As much front negative camber as you can get. At least -2.5 degrees. -3 would be better with the amount of roll you'll have with those springs, swaybars, and a reasonably sticky tire. Then run -1 to -1.5 in the rear.
jamal is offline   Reply With Quote
Old 04-08-2009, 03:14 AM   #3
misterwaterfallin
Member#: 101091
this. with a bit of toe in on the back and a bit of toe out on the front.
misterwaterfallin is offline   Reply With Quote
Old 04-08-2009, 07:26 AM   #4
KC
Member#: 442
13 Crosstrek XV
00 S2000
I wouldn't touch toe and leave it at/set it at 0. Only adjust toe on a track if you're having a problem with rotation after all your camber/caseter is set. Toe is the last thing to adjust.
You definitely need more camber in the front. -3 is a good target.
--kC
KC is offline   Reply With Quote
Old 04-08-2009, 12:08 PM   #5
misterwaterfallin
Member#: 101091
If he's going to the track I wouldn't suggest driving hard with straight up toe in the back anyway. A little toe in will keep the car planted in braking zones instead of dancing around. Im talking 1/16th to 1/8th
Old 04-09-2009, 01:35 AM   #6
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Dancing around in the rear can help with rotation
WRX 2002 is offline   Reply With Quote
Old 04-09-2009, 02:10 AM   #7
FunkRider
Member#: 195055
Good rotation won't do him any good if he keeps looping it in the braking zones.
FunkRider is offline   Reply With Quote
Old 04-09-2009, 02:21 AM   #8
WRX 2002
Member#: 11211
2004 STi
Rally Blue
I don't think 0 degrees is going to be the cause of looping in the braking zone.
I always run zero degrees and have braking zones down hill at 145 mph at Road America into turn 5 and have no issues. The back does dance around a little but nothing that might cause looping. But then again I have never tried anything but zero all round.
Old 04-09-2009, 02:25 AM   #9
misterwaterfallin
Member#: 101091
try a bit in and report your finds. from what I have found, and this is also 140+ braking zones, is that a bit of toe in will help the car track straight and become more settled in the corners. In my mind it has nothing to do with rotation. That is something autocross guys dwell over, not so much track guys
Old 04-09-2009, 02:47 AM   #10
FunkRider
Member#: 195055
I'm just bench racing here as I have yet to track my wrx (only got it in November). When I read the first post originally I thought it was his first track day ever, but now with a re-read its just his first of the season.
Old 04-09-2009, 03:10 AM   #11
sindy9001
Member#: 207937
Why good rotation won't do him any good if he keeps looping it in the braking zones?
sindy9001 is offline   Reply With Quote
Old 04-09-2009, 03:38 AM   #12
STi-MAN
Member#: 70252
05 STI
blue
i'm one for zero toe all around as well.. unless you are really seeking a specific dynamic that your car needs.
also with this being your first track event.. I just dont think you need to play with toe.
STi-MAN is offline   Reply With Quote
Old 04-09-2009, 07:04 AM   #13
KC
Member#: 442
13 Crosstrek XV
00 S2000
I am an autox guy. And I know that adjusting toe for autox is one thing. For track is another.
0 rear toe (0 is still an adjustment tho...) Toe in will make him stable, but in an ideal world, one would align based on the track he's going to (develop a log every track day to keep notes in regrding what the car is doing for each given corner, or its general composure).
The toe in can be beneficial at one track, and detrimental at another, slower tighter track.
Whereas I think everyone can agree, rear toe out is bad on track unless there's something else one's trying to accomplish.
--kC
Which camber kits does everyone recommend? SpeedWagon41 Brakes, Steering & Suspension 7 07-04-2006 10:55 AM
Recommended vendor? Noltec camber/caster (RACE) SgWRX Brakes, Steering & Suspension 6 05-07-2005 03:38 AM
Tom, Scooby South, Templar, Biggly, etc. - Recommend me rear camber setting. thrdeye South East Region Forum 18 01-09-2005 08:55 PM
Recommend front camber plates for my GC RS GQ Brakes, Steering & Suspension 3 07-15-2004 08:51 AM
Recommended camber? squeeks Brakes, Steering & Suspension 1 06-10-2003 01:00 PM
