Old 04-07-2009, 10:04 PM   #1
ZOMBIEWAGON02
Member#: 206319
2002 Outback Sport
Green...mostly
Default Pre Gapped Plugs???
I got a set of autolite from shucks or oriellys and are they pre gapped. I never thought to ask. And if not what should they be gapped at??
ZOMBIEWAGON02 is offline   Reply With Quote
Old 04-07-2009, 11:49 PM   #2
Storm
Member#: 5218
96L Most Over-
Developed Beater
There should be a gap setting under the hood on the sticker, or in your manual.
Jay
Old 04-08-2009, 12:18 AM   #3
dcleal
Member#: 178135
2006 Impreza 2.5i
next time stick with the factory specific plug brand they tend to run better and last longer, in our case ngk's
dcleal is offline   Reply With Quote
Old 04-08-2009, 01:11 AM   #4
impreza_punk
Member#: 102900
2005 Impreza STi
Even if they are pre-gapped it is good routine to always double check. Changing spark plugs isn't something I would try and hasten any further.
impreza_punk is offline   Reply With Quote
Old 04-08-2009, 02:37 AM   #5
trueno16v
Member#: 175170
2005 WRX Wagon
owl + bungee cord= my a$$
Platinum and Iridium plugs should not be regapped, if they must be use exteme care. Do not use a slide type gapping tool. The center electrode is smaller and can be damaged more easily. If you buy the oem type of plug for your car it should come pregapped and will state the gap on the box.
trueno16v is offline   Reply With Quote
Old 04-08-2009, 09:32 AM   #6
SubyMass
Member#: 136493
2015 WRX
GBP
IIRC they are usually pregapped if they have the sleeve over the electrode end
SubyMass is offline   Reply With Quote
Old 04-08-2009, 09:46 AM   #7
GEE-OTTO
Member#: 201277
2009 Legacy GT
The last car I gapped plugs for was a 1984 Old Cutlass hahahah ever set of ever car after came pre gapped and helped greatly if you go to your dealer and get a set or order a set of NGK Iridium or Platinum they will be gapped for our motors
GEE-OTTO is offline   Reply With Quote
Old 04-08-2009, 03:56 PM   #8
Back Road Runner
Member#: 60082
2004 Forester STI
A lot if not all spark plugs these days seem to be pregapped. I haven't gapped a spark plug in a long, long time. The last time I did check gaps, they were spot on too.
Plug Gapping with copper plugs Amazake Engine Management & Tuning 54 01-31-2007 08:45 PM
What is the difference between gapping plugs @ .039 or .043? poison Normally Aspirated Powertrain 5 02-24-2005 07:34 PM
spark plug gap NGK Iridium plugs? SeaRex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 09-12-2004 10:49 PM
OEM sparkplug come pre-gapped from factory? txl146 Service & Maintenance 7 09-01-2004 12:44 AM
Do factory spark-plugs come pre-gapped? TimStevens Service & Maintenance 9 05-02-2003 08:41 AM
