Old 04-16-2002, 03:59 AM   #1
racerwad
Member#: 2564
Question o-ringing: heads vs. block?
ok, i've heard a lot of talk about how "o-ringing" your motor will help create a better seal between the heads and block. when one uses the phrase "o-ringing" does that apply to the surface of the heads or the block, or both, or either? i mean, does it make a difference? thanks.
andy
racerwad is offline   Reply With Quote
Old 04-16-2002, 08:05 AM   #2
Fitz
Member#: 1426
'07 335xi, '07 ZX6R
SV650 Race Bike
9 times out of 10 peope o-ring the heads although I have seen it done to the block on big block dragsters.
Fitz
Fitz is offline   Reply With Quote
Old 04-16-2002, 01:12 PM   #3
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Fitz
well everywhere else in the world(here) it's done on the block, i have seen one set of o-ringed heads...i'd do the block personally....but talk to your local machine shop and see what they say.
jeremy
Old 04-16-2002, 02:11 PM   #4
racerwad
Member#: 2564
Default thanks
thank you everyone. i just didn't know if it was an either or proposition. i assumed that it would be. has anyone seen better results with either o-ringed heads or blocks? thanks.
andy
Old 04-16-2002, 05:30 PM   #5
XT6Wagon
Member#: 524
04 STi
Well some people running the Aluminum SBF blocks o-ring all the passages on the block, and run w/o a head gasket. This means they don't leak coolant when warming up, and pulling the heads is a FREE operation as the whole thing comes apart and goes back together w/o needing to replace anything.
XT6Wagon is offline   Reply With Quote
Old 04-17-2002, 02:02 AM   #6
ImprezaRS dot com
over boosted again
Member#: 1458
2015 Forester 2.0 XT
2005 2.5 RS, 2013 Tribeca
I o-ringed the block, and far it holds 14 psi boost on race gas...
ImprezaRS dot com is offline   Reply With Quote
Old 04-17-2002, 03:56 AM   #7
Happy
Member#: 12115
Mine was wire ringed by Trey Cobb. We ran it up to 40psi on the engine dyno......with no problems (apart from me nearly havng a coronary
The EJ ** head gasket design is better suited to ringing the block.
Happy.
Happy is offline   Reply With Quote
Old 04-17-2002, 01:36 PM   #8
Chuck
Member#: 791
1998 Impreza RS
Brilliant Red
Any harm / benefit from doing both?
And what does wire ringing entail?
Chuck is offline   Reply With Quote
Old 04-18-2002, 02:07 AM   #9
ImprezaRS dot com
over boosted again
Member#: 1458
How do you run 40 psi on a street motor and not detonate the cr*p out of it?
What size turbo and IC are you using!!!
Larry
PS: I know about the pectel and 8 injectors...
Old 04-18-2002, 03:37 AM   #10
Happy
Member#: 12115
Larry,
It's low compression, about 8.5:1, MRT FMIC (also used for mapping on the engine dyno) fuel is European standard 97RON, and the minimum dose of NF octane booster (worth 2~3 deg' of extra ignition advance). I'm running about 20deg' at 30psi @ 7000rpm.
I've run octane booster since day one, because the car is a Jap STi, and mapped for Jap 100RON fuel. So I decided to map the new engine with booster.
The turbo is a Garrett GT35/40.
We tend to run much leaner than most of you guys, 11~11.5:1 afr, or a lambda voltage of circa .86~.87volts.
We also run higher egt's. I happily run up to 900C taken just before the turbo. This equates to about 1000C taken at the collectors. It's also only a little hotter than what the engine was running as stock. The new '02's seem to run ludicrously rich to me.
On the road I will run water injection, so I should be able to advance the igniton even further.
Happy.
Old 04-18-2002, 05:15 AM   #11
ImprezaRS dot com
over boosted again
Member#: 1458
Ahhhh...
I run 9.4:1 compression, 24 degrees timing after using the ITC to pull back the stock ECU, run EGT's of 1450F, and am likely 12.5:1 AFR based on rear O2 sensor reading which read leaner than for real. So, I am stuck at 12 psi on a 70 degree day on 93 octane, 13 psi on 94 octane...
Still makes 350 crank at that...
Old 04-18-2002, 05:40 AM   #12
Happy
Member#: 12115
Larry,
I'm pretty certain that the US RON ratings are different to the Euro RON ratings, ie lower for the equivalent octane.
A stand alone will make a massive difference. The lowest we ran mine was 16psi @ 7000rpm, and that made 507bhp crank.
It would be worth you considering water injection.
Happy.
Old 04-18-2002, 05:55 PM   #13
ImprezaRS dot com
over boosted again
Member#: 1458
I have been in discussion with Cascade Motorsports to get the Aquamist water injection system, but I first need to get my ProECM Willwood brake kit with MRT rotors installed. Then I can save for their 3D mapable 2s water injection system instead of the most basic "dump water in under boost" system.
Was gonna build my own water injection, and already have a dawes devices boost switch that is adjustable to set what level the WI starts at...
Larry
wrx heads/sti block, current wrx heads ej20g 4banger4dr Built Motor Discussion 6 11-14-2009 03:55 PM
Hybrid setup build parts - EJ20 Block & Heads, EJ25 Block, 02 WRX Tranny parts... WRenXhaven Engine/Power/Exhaust 18 07-11-2009 10:46 AM
Sti Harness Wrx Heads Wrx Blocks Sti Heads Junior2JZ Engine/Power/Exhaust 6 01-17-2007 12:13 PM
O-ringing: Head or Block which is better? MY99 2.5GT Built Motor Discussion 4 06-11-2006 03:49 PM
ver 8 heads vs. USDM STi heads ebeck Subaru Conversions 10 04-17-2004 12:45 PM
