Old 04-16-2002, 07:29 AM   #1
IncubusDude
Member#: 17608
2002 wrx sedan
Default So what is the best way to get rid of those damned Cats without triggering CEL?
What is the best way to get rid of as many Catylitic convers as possible without triggering the CEL? Is there anyway at all to get rid of all 3 of em without triggering the CEL? If so..which is the best and least pricey if possible, up-pipe and down pipe.
IncubusDude is offline   Reply With Quote
Old 04-16-2002, 01:22 PM   #2
Yebisu69
Member#: 11989
2006 LegacyGT LTD
Brilliant Metallic Silver
Default Re: So what is the best way to get rid of those damned Cats without triggering CEL?
You can't. The CEL is complaining about the missing cats.
Yebisu69 is offline   Reply With Quote
Old 04-16-2002, 02:34 PM   #3
GM02WRX
Member#: 16989
Cobb Stg.2 PSM
The only way your ECU will recognize a catalytic malfunction is by comparing O2 sensor voltage differences. There are two ways to bypass this (eliminate the cats and have no CEL): 1) Have separate O2 bungs w/ catalytic material in them welded to the new pipes for the O2's. This will not cause any friction losses internal to the pipe since the cat material and O2's sit 'outside' the flow area.; and 2) Simply extend the O2 wire leads and bring the O2's into the cabin and leave them there. This should not cause the CEL to illuminate since the ECU is primarily looking for a 'difference' in O2 sensor voltage (due to catalization--more O2 content after the cat) and not at the actual voltages which are basically inconsequential.
I would go with the first option since some pipes ae already available with this O2 bung. Good luck!!
GM02WRX is offline   Reply With Quote
Old 04-16-2002, 03:04 PM   #4
WagonMonster
Member#: 3781
2002 Legacy GT Wagon
2009 Forester X Limited
You looked at the color of the sky in SoCal lately?
Keep the cats.
WagonMonster is offline   Reply With Quote
Old 04-16-2002, 03:07 PM   #5
GM02WRX
Member#: 16989
Cobb Stg.2 PSM
Never been to SoCal, but FL could use some shade! J/K!
Old 04-16-2002, 05:08 PM   #6
kensington
Member#: 9113
2k4 WRB STi
RIP#92 Fred"G-Money"Zippy
godspeeds downpipe uses option #1 as stated above. godspeed.hack.net. Installed on Sunday, no CEL's. I bought it used and the guy who had it before me had it for a couple months with no CEL's.
kensington is offline   Reply With Quote
Old 04-17-2002, 06:49 AM   #7
IncubusDude
Member#: 17608
2002 wrx sedan
Default up-pipe & down-pipe
Which Up-pipes and down-pipes are the best? and can someone tell me the step to step way to install the option 1 way...picture of how it is if possible...sorry for these newbie questions..one last thing..anyone who used the option 1 method, please post and tell me how it went with the CEL... thanx
Old 04-18-2002, 03:14 AM   #8
WRXTACY
Member#: 15339
2015 WRX
CWP
yeah what other up-pipes do not throw CEL's? Im intrested in buying one after I buy my Blitz cat-back exhaust.
WRXTACY is offline   Reply With Quote
Old 04-18-2002, 10:39 AM   #9
kensington
Member#: 9113
2k4 WRB STi
uppipes don't throw the cat inefficency CEL, downpipes do. They have an o2 sensor near the rear end that you can see underneath the car. Uppipes have the stock EGT sensor bung, at leasst all of the ones I have seen do.
Old 04-18-2002, 03:11 PM   #10
2.5GT
Member#: 2697
2000 Celica GT-S
Spectra Blue
I remember reading about an MIL eliminator on this board a while ago. It basically wires into the second O2 sensor to mimick the proper readings for the ecu not to throw a code. With this device, you should be able to run no cats . . . no problem
I don't know much about this device, but I think Brullen may have used it to fix CE light problems with their headers/hi-flow cat combo.
Do a search under MIL eliminator or Brullen (although be prepared to sift through alot of posts with just Brullen).
Jason
2.5GT is offline   Reply With Quote
What is the CORRECT way to get rid of wastegate flutter? XWRATED Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-25-2006 10:03 AM
What is the best way to get rid of brake dust hilfiger4you Tire & Wheel 22 01-31-2006 12:44 PM
What is the best way to get rid of love handles? waitandbleed92 Off-Topic 34 10-15-2004 08:51 PM
What is the best thing to get rid of spyware and adware? HalfBaked Off-Topic 44 06-26-2004 12:45 AM
what's the best way to get rid of a car that isn't running? dingo dave Off-Topic 16 03-24-2004 02:33 PM
