Old 04-08-2009, 07:38 AM   #1
Ekeenan86
Member#: 155493
1999 Legacy Outback
Default Suspension on its way out?
I would like to know what are the signs for a failing suspension. I've had the same suspension on my '99 Outback for 200k miles now. I live in NJ so im constantly smashing over pot hole filled roads and the car really sounds like it takes a pounding over every bump.
Ekeenan86 is offline   Reply With Quote
Old 04-08-2009, 07:42 AM   #2
emsmap
Member#: 159334
02 WRX, 99RS, 96L
AP3,PPG, BW S256
Sounds like you are needing new struts. 200k miles on factory struts?
emsmap is offline   Reply With Quote
Old 04-08-2009, 07:53 AM   #3
bugeyerex02
Member#: 195967
2002 VF39'd WRX
WR Blue
look at the overall ride height, if its skewed to one corner, or to one end, that will be the failing strut. with 200k on the stock suspension, it is time to replace all 4 corners.
bugeyerex02 is offline   Reply With Quote
Old 04-08-2009, 08:29 AM   #4
Jack
Add Lightness
Member#: 13699
2004 Outback, 13 XV
(From General)
It's usually difficult to notice on a car that you're constantly driving because the wear happens constantly but very slowly. Drive a car that is like yours with OEM-like replaced struts to feel the difference.
At 200k, I think it's pretty safe to say that the struts need replacement. If you have any thoughts of going to a different spring, now's the time since the labor would not be any different than just changing struts. You might even find a used setup where someone went complete aftermarket....where you get a spring/strut/top all together....then it's a piece of cake to do the replacement. While you're at it, check out the ball joints, tie rod ends and bushings. Chances are that they're all at least worn if not shot at this mileage. Even the steering rack bushings can be worn at this point. If you just go ahead and replace everything, you're going to think the car is brand new when you're done.
jack
Old 04-08-2009, 08:33 AM   #5
RP31
Member#: 123574
2005 2.6L 9:1 425WHP
CGM STi
+1. I just replaced my springs and struts on my car. Even my wife noticed the difference the first time she rode in it! And I only had 80K miles. Wife also noticed the car was a bit lower.
RP31 is offline   Reply With Quote
Old 04-09-2009, 07:54 AM   #6
Ekeenan86
Member#: 155493
1999 Legacy Outback
Yeah i really should replace the whole setup; however I'm hesitant to put that much money into a car with 200k miles.
stock 07 sti - rear 02 sensor on its way out? Turbo9000 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 1 09-02-2009 05:45 PM
Tranny on its way out? Noise in first 04 WRX (NJ) Transmission (AT/MT) & Driveline 0 05-22-2009 01:21 AM
Bad Detonation Still- Is my engine on its way out? JeffrWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 30 03-04-2006 01:29 PM
power steering on its way out? AJ711 Service & Maintenance 3 03-03-2005 05:23 PM
Turbo on its way out? DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 04-05-2002 03:10 PM
