Welcome to the North American Subaru Impreza Owners Club Sunday April 26, 2015
Old 04-08-2009, 11:59 AM   #1
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
Default Dropping Engine and Trans?????
Hey guys after getting my sti parts car, i need to drop the engine and trans so i can sell the STI swap to help fund my V8 swap.
I was thinking i could drop the whole subframe in the front and have the motor come out with it. Am i right or does the subframe come out then unbolt mounts then drop out? I have a WRX/STI manual and i cant find any instructions for that.
Any help?
KillerRabbit is offline   Reply With Quote
Old 04-08-2009, 12:23 PM   #2
MasterKwan
Member#: 98961
2003 WRX
That's how I stripped my donor. Pulled the front suspension off and then the driveshaft. Stuck a floor jack under the transmission, engine hoist to the engine, unbolted the cross member and all the other parts needed to remove the motor and dropped it out the bottom. It's how these cars are assembled at the factory, engine and tranny come up from the bottom.
Old 04-08-2009, 12:43 PM   #3
KillerRabbit
Member#: 184772
2004 Crazy Slow WRX
World Rally Blue
As always Kwan you know your stuff. Ok when dropping it there is a subframe, and the crossmember? how is the crossmember set up, bolts to the frame? After you remove that do you have to remove anything off the trans or once the subframe is gone it drops?
Honestly this blows, i am straight up a Honda man before this and i have no clue how to do any swaps mechanical wise yet.
i know i have decided that AWD=FTW!!
Old 04-08-2009, 01:41 PM   #4
MasterKwan
Member#: 98961
2003 WRX
Honda's are SO much easier. I was just helping a buddy wire up the secondary 02 on his Civic yesterday. The Honda manuals just take a dump on the subaru manuals. I swapped the Type-R motor into the EK hatch (his civic used to be mine). Honda just engineers better than subaru does. Subaru seems to go out of their way to make swaps difficult. I had to switch the wiper motor even for my swap. The connectors were the same but, internally the wiper motor on the STI and WRX are wired differently.
The crossmember bolts to the frame rails. The transmission mounts bolt to the body, the dogbone has to come off, radiators needs to some out. AC and PS has to be disconnected or moved. If you're just stripping a car, it's the way to go. You ought to be able to just look at the car and see how it comes off. I'd probably pull the rack out from the crossmember so, it doesn't get damaged when you put the crossmember on the floor.
I'd build a plywood sled. I dropped them out onto the sled and then uses a come-along to hoist them out from under the car.
Old 04-08-2009, 07:53 PM   #5
mannac
Member#: 161038
2002 WRX swapped TS
'72 Datsun 240Z
I did my swap through the bottom like this. I think I used a wooden creeper to pull it out on. I dropped it with an engine hoist on the engine and a jack on the tranny. Okay, apparently I did exactly what Kwan did. I assume you took out the propeller shaft already.
mannac is offline   Reply With Quote
Old 08-18-2009, 12:49 PM   #6
team_imprezzed
Member#: 142847
2005 WRX w/ v8 EJ207
I had the engine and trans connected and was able to drop it in from the top...it wasn't too bad.
team_imprezzed is offline   Reply With Quote
ej20g parts, 2000 rs parts, exterior and engine and trans parts come look! GregBolby 1993 - 2001 Impreza Specific Parts 1 04-12-2010 07:30 AM
Need help with and engine and trans model code fragment Subaru Conversions 5 12-12-2004 03:34 AM
STi engine and trans mounts in stock NinosAutoAccesories Vendor 'For Sale' Classifieds 2 08-09-2003 09:10 AM
engine and trans id numbers boogerwrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-08-2002 03:39 AM
('93-'01) Anybody swapped a STI engine and trans N/A Impreza Forum 4 12-21-2001 04:14 PM
