Old 04-08-2009, 01:19 PM   #1
VitorBelfort041
Member#: 177568
2000 2.5 RS
BRP
Default Do I need Hub centric rings?
I hooked up some new wheels recently, and I was wondering 2 things:
1) How do I determine if they're hub or lug-centric?
2) If hub centric, how do I determine the wheel bore (in order to know what size hubcentric rings to get)? I already know my hub bore (on the car) is 56.1.
The wheels in question: SSR Professor SP1, 18x8", 5x100, 49mm offset.
Car in question: 04 STi.
Thanks for help!
VitorBelfort041 is offline   Reply With Quote
Old 04-08-2009, 07:08 PM   #2
benw
Member#: 103320
1998 swapped
Forester L
you can either measure the inside (mic) or search/ask around the internet. The SSR site might have hub bore size data.
our cars are hubcentric. it means we have a raised area on our hubs to accept matching hubcentric wheels. If the hub diameter on the wheel is larger, you must compensate with rings.
benw is offline   Reply With Quote
Old 04-10-2009, 12:04 PM   #3
VitorBelfort041
Member#: 177568
2000 2.5 RS
BRP
Gotcha, thanks!
hub centric rings needed? haberkorn Tire & Wheel 6 03-20-2009 07:34 AM
Hub centric Ring needed for Volks CE28N? SubyWRXSti Tire & Wheel 20 07-06-2008 04:33 PM
Hub centric ring, needed? aakrusen Tire & Wheel 2 11-18-2006 06:41 AM
Hub centric rings needed subywrx Tire & Wheel 9 09-01-2005 03:55 PM
need info on hub centric ring size NOTimprezed Tire & Wheel 8 02-10-2005 11:41 PM
