Old 04-16-2002, 09:40 AM   #1
artulo
Member#: 13243
2015 WRX STi
Question Performance Issues
Hey folks --
I'm just looking for a little insight into what may be going on. I'm pretty sure I know but want some advice first. Some of the descriptions may be a little vague but bear with me.
My '01 RS has been acting a little "off" the past week or so, in that it takes 5-10 secs of cranking to get it started sometimes (though not often).
Second, the idle seems rougher. Not a lot but it's noticeable. When I turn it off it doesn't stop idling right away, goes for maybe 0.5-1 sec kinda like a diesel but not quite the same.
Also, my "butt-dyno" says that the pull to redline really isn't what it should be. I rarely even get to 5000-5500 so it's not like I'm bouncing off the red constantly, mostly staying 2500-4000 RPM.
My gas mileage for the last 3 tankfuls has been a pitiful 17 MPG! I realize that these aren't the most fuel economizing vehicles, and my car IS used as a daily driver for city driving a lot, but 17??
The car just went over 24k miles, so I'm guessing it's time for a little tune up maybe? Get rid of those champion plugs, get new wires, etc?
Oh and the car is completely stock. Mo mods whatsoever.
Any insight?? Or am I just crazy? It is under arranty, so take it to the dealer?
artulo is offline   Reply With Quote
Old 04-16-2002, 11:55 AM   #2
Yebisu69
Member#: 11989
2006 LegacyGT LTD
Brilliant Metallic Silver
Default Re: Performance Issues
Originally posted by artulo
Hey folks --
I think you due for a tune up. I have read that the Champion plugs weren't so good when they were new.
BTW I get about 18 mpg in the city with just a ganzflow intake.
I don't think wearable items are covered under warranty, (belts, hoses, etc)
Yebisu69 is offline   Reply With Quote
Old 04-16-2002, 12:00 PM   #3
Midwayman
Member#: 1997
2006 Acura TL 6spd
STMGM6 alumni
Might be the o2.....
Midwayman is offline   Reply With Quote
Old 04-16-2002, 12:10 PM   #4
Jademonkey
Member#: 9213
2000 RS
Red
I'd go for a tune up. 17 mpg seems low. What octane gas do you run? You should be using 87. Before I started modding my car, i got 22 mpg for city driving, now I get around 23 or 24. I have a ganz, borla header & catback, and magnecor wires.
Check the oil, tranny fluid, and take out those champion plugs. Most would agree NGK's are the way to go. Don't go for platniums like Bosch. Platinum is for longevity, not performance.
Jademonkey is offline   Reply With Quote
Old 04-16-2002, 12:43 PM   #5
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Sounds like reactions to a bad tank of gas...
Has this been happening within one tank, or have you re-filled?
NC
Reciprocity is offline   Reply With Quote
Old 04-16-2002, 03:40 PM   #6
artulo
Member#: 13243
2015 WRX STi
Most of the idling and starting problems have cropped up with this last tank of gas I put in last week. I usually put in the 89 or 93 octane stuff, but I guess I really don't need to.
So, it may be a bad tank of gas for those problems. However, I'm guessing it really is time for a tune-up and I'd really like to get rid of those champion plugs and put some NGK's and good wires on.
The oil was just changed 1k miles ago.
I'll probably do everything at the same time, since I'm doing the Ganzflo CAI mod soon.
Thanks everyone for your help!
Old 04-16-2002, 04:15 PM   #7
Kevin Thomas
Street Racing Instructor
Member#: 110
1989 1989 XT6
Thumbs up Testing
Just run your current tank empty and see what happens with the next 1-2 tank fulls. If the problem persists, change your spark plugs (NGK's recommended by me ). Don't be concerned with your spark plug wires. They should be excellent for a long time to come.
If the problem persists.....let us know. It could get nasty. I doubt it will though.
Kevin Thomas is offline   Reply With Quote
Old 04-16-2002, 04:29 PM   #8
phucvtec
Member#: 16261
2000 Impreza 2.5RS
Blue Ridge Pearl
Just an FYI... I have experienced the same exact problem with my 2000 RS. I replaced the plugs with NGK irridium and replaced the wires with another stock set. The sort of symptoms you describe come and go for me. As hard as I have tried, and trust me, I have tried , I cannot corilate these symptoms with anything. The only thing I have noticed on a consistant basis is that my vehicle has a lot less power (curtacy of said butt dyno ) when it is very humid outside, like after a warm rain. Fortunately, we raraely have more than a warm snow here in buffalo...
phucvtec is offline   Reply With Quote
Old 04-16-2002, 07:01 PM   #9
goobie
Member#: 8273
2006 WRX Wagon
Default same problem
I had my car at the dealer yesterday about an ongoing clutch issue. My car was also bogging of the start and seemed to lack power. My tech tested the coil pack and it was weak. He ordered a new coil pack which will be installed on the 24th of april. I'll let you know how it turns out.
Chad
goobie is offline   Reply With Quote
Old 04-16-2002, 07:36 PM   #10
Jademonkey
Member#: 9213
2000 RS
Red
!!! 93 octane? That's way to high my friend. Go back down to 87. Unless you have a highly modded engine, then go to 89....but otherwise, I'd switch to 87.
Good luck!
Old 04-16-2002, 07:43 PM   #11
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
is it possible to use gas that is too good?
KillerTHC is offline   Reply With Quote
Old 04-16-2002, 08:41 PM   #12
Blindeye_03
Member#: 4418
2016 Focus ST
Good luck!
Dunno about you, but when it gets hot outside (like summer weather), my car pings with 87...thats why I switched to 89...but the only mods (performance wise) are an intake, catback exhaust and an UDP.
But thats just me...
-justin
Blindeye_03 is offline   Reply With Quote
Old 04-17-2002, 01:21 AM   #13
Jademonkey
Member#: 9213
2000 RS
Red
It is possible to use gas with an ocane rating too high. High octane doesn't necessarily mean better gas. If the octane is too high, not all of it burns, and hence you lose some power, and your mileage goes down. Our EJ25's are designed to run off of 87 octane. 89 would be OK if you're getting some pinging, but if you have to use 91+, something's wrong with your engine. Well, that's what I was told when i was having a chat with one of the grease monkeys where I bought my RS.
I live pretty much at sea level...i rarely get pinging with my mods. Once in a while though, but not often. So it also depends on your weather and altitude.
Old 04-17-2002, 08:51 AM   #14
artulo
Member#: 13243
2015 WRX STi
Good luck!
Sounds like a good Idea! I'll run the tank dry this weekend and fill up with the regular 87 and see how that goes.
I'm still gonna do the plugs and CAI though...
Old 04-17-2002, 10:35 AM   #15
Jademonkey
Member#: 9213
2000 RS
Red
Good luck Let us know what happens. You'll have to go through a tank or two until you notice a difference. Get those plugs out of there too. I wouldn't put champions in my lawn mower!
performance issues carguy_25 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-19-2007 02:22 PM
Any performance issue with swapping a STi scoop for WRX? jsavage Interior & Exterior Modification 27 08-15-2005 07:38 AM
3.0 performance issue Raoul Outback Forum 0 10-23-2004 01:33 PM
Performance issue wik an '04 WRX Vipre Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 12-11-2003 09:35 PM
ECU Reset & Performance Issues chuglobal Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 34 04-08-2002 07:15 PM
