Old 04-08-2009, 09:15 PM   #1
Jhovany
Member#: 137317
2006 STI
Rally Blue
Default Maha dyno vs Dynojet results!
I just want to share my results with everyone here. Alright guys before I start, I just want to say...take this for what it is and that this is NOT a direct comparison between the two dynos, by ANY means! WAY TOO MANY different variables!!!! For starters, these runs were done at COMPLETELY different days, COMPLETELY different locations, different altitudes, different temps, etc....heck I dont even think they were done on the same gear!!! Anyways here is the DL.....I always got a lot of crap from a lot of members on here for the dyno results I ended up with for my setup (everyone was saying that they were too low). I never understood where people were getting all of these "higher" NUMBERS! I always heard that dynojets read the highest out of any other dyno. So for *****s and giggles I drove 2 and a half hours to get dynoed on the only AWD dyno in the State of New Mexico, which just happens to be a dynojet!
Several additional notes.........these dyno charts are for 91oct. at 19psi. The Maha dyno(which is the only one in North America, I believe) is that of GoodSpeeds located in Tempe, AZ roughly 1200ft elevation. At the time that I was dynoed (July 25, 2008), GoodSpeed had not yet received certain software in order for it to read WHEEL torque. The dynojet run was made this past weekend (April 4, 2009) roughly 5300ft elevation. I believe this run was done on 3rd gear. In the end....dyno numbers are just numbers. But very good tuning tools. Mods were exactly 100% the same on both runs. And finally a mod list that influenced these results......
APS SR56 turbo
APS 70mm CAI
APS turbo inlet
APS DR525 FMIC
APS 50/50 BPV
Perrin EL Header
Invidia DP
HKS Hi-Power exhaust
Accessport v2
Cosworth Shortblock
PE 850cc
Walbro 255
TGV deletes
Jhovany is offline   Reply With Quote
Old 04-08-2009, 10:43 PM   #2
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
waiting till 5k for 375 wheel ftl!
are you sure your car is running right??
godforbid67 is offline   Reply With Quote
Old 04-08-2009, 11:18 PM   #3
Jhovany
Member#: 137317
2006 STI
Rally Blue
very sure
Old 04-09-2009, 01:20 AM   #4
Deuce Cam
Member#: 130444
'85 AE86 GTS
Cool comparison. I still don't get why power curves are always shifted to the right on maha dyno plots when compared to a normal dyno plot, like a dynojet.
Deuce Cam is offline   Reply With Quote
Old 04-09-2009, 02:04 AM   #5
sorrowfulkiller
Member#: 170439
I <3 Lamp
... I don't like how the maha dyno chart is smooth
otherwise, cool comparison
sorrowfulkiller is offline   Reply With Quote
Old 04-09-2009, 02:35 AM   #6
k04sti
Member#: 171773
04 wrx sti
jbp dom 3 xtr w meth!
Originally Posted by Jhovany View Post
very sure
Might need to see logs. I don't really like dynos. That doesn't look right though.
k04sti is offline   Reply With Quote
Old 04-09-2009, 04:03 AM   #7
sindy9001
Member#: 207937
It's a cool comparison!
sindy9001 is offline   Reply With Quote
Old 04-09-2009, 08:50 AM   #8
SuperSTI
Member#: 67182
2004 Subaru STi
11.0 @ 128mph - 93/Meth
Peak power is at 6000rpm on the maha and 5000rpm on the dyno jet?
Are you sure that tune is right? Lag is the same as a GT35R 1.06.
SuperSTI is offline   Reply With Quote
Old 04-09-2009, 09:01 AM   #9
Phatron
Member#: 36033
CEO PhatBottiTuning
2006 STi GTX3582 + Meth
different gears, different dynos, different loadings......
you guys need to remember its a 56 lb/min turbo......so its gonna be laggier than greens, 3076's, etc......and most likely be laggier than most rotated gt35's.
a 62 lb/min turbo with a 4" inlet is flowing more in the intake than a 56 lb/min turbo through the 3" APS twisty system
Phatron is online now   Reply With Quote
Old 04-09-2009, 11:34 AM   #10
Clark Turner
Member#: 178047
02 WRX STI Spec C
Thats about right.
One thing to be clear though. The Maha is reading accurate Crank hp. Its the machine many car manufacturers use. Most stock cars of various makes and models are within 3 to 5 hp of the rating of the car to the mahas Crank hp reading.
Reality hits home pretty hard sometimes.
Clark
Clark Turner is offline   Reply With Quote
Old 04-09-2009, 05:27 PM   #11
Deuce Cam
Member#: 130444
'85 AE86 GTS
^^Have you run a stock sti on the maha, any graphs? I'm curious if it would show peak hp @ 6000rpm and peak tq @ 4000rpm like Subaru claims, or if the plots would be shifted to the right a little.
Old 04-09-2009, 05:55 PM   #12
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Originally Posted by Clark Turner View Post
Thats about right.
Clark
I was actually watching a video on the ABT tuning (of Audi fame), and noticed that they also were using the MAHA dyno for testing and calibration purposes..
jigga is offline   Reply With Quote
Old 04-09-2009, 06:06 PM   #13
Clark Turner
Member#: 178047
02 WRX STI Spec C
Stock plots show HP and TRq peaks at about the same as the manufacturers claim. They use this machine to get the numbers.
Clark
Old 04-09-2009, 06:29 PM   #14
orion421
Member#: 92933
gsxr 600, BMW 540i
not stock but heres my stg 2 04 sti turbo back exhaust and ecutek tune were the only performance mods. mustang vs maha
mustang graph is hard to read sorry. max hp was 266 tq was279
orion421 is offline   Reply With Quote
Old 04-10-2009, 10:01 AM   #15
kellygnsd
Member#: 32669
2007 FR TS EFR 7670
LINK G4 hybrid STi
Clark
No SAE numbers are done on an engine dyno not a chassis dyno
kellygnsd is online now   Reply With Quote
Old 04-10-2009, 10:44 AM   #16
Clark_Kent
Member#: 114299
Thats about right.
Clark
+1. Arguably one of the best dynomometers on the market. BTW, you tuned a good friend of mine's car a few weeks back. He can't stop talking about how smooth it feels.
Clark_Kent is offline   Reply With Quote
Maha Dyno Vs. others comparison. Soon2Bgreat Proven Power Bragging 16 05-20-2011 12:31 PM
Maha Dyno vs. DynoJet Filthy_Sense General Community 1 09-16-2005 01:32 AM
mustang dyno power #s vs. dynojet power #s bigworm Proven Power Bragging 15 08-07-2005 09:52 PM
Completely stock dyno VS turboback + uppipe dyno RESULTS! billmidd08 Factory 2.0L Turbo Powertrain 25 12-10-2003 12:01 AM
DynoJet AWD dyno vs. others dazz1 Factory 2.0L Turbo Powertrain 13 06-07-2002 11:31 AM
Message Board Statistics All times are GMT -4. The time now is 09:43 PM.
