Old 04-08-2009, 10:53 PM   #1
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
Default another exhaust question...
this isnt as simple as saying, "get a WRX exhaust"..
i already have an EBAY 3inch TBE
i want to keep the catless DP i have, and put on the sti cat back... i have the adapter to make it from 3inch to stock sti.
i want to make my car quieter (due to a ticket). so i bought a stock 05/06 Sti exhaust...today i looked and compared them (the DP to CB flange). it looks like the stock CB flange is tilted a little....
my aftermarket DP is tilted the the opposite way of the STi CB... *to me it doesnt look like itll bolt*
i dont know if i explained it right....but if u know if it does work let me know.. i just looked at it *without lifting up the car*...i didnt try to bolt it up yet... ill try tomorrow... ill also take pics if it doesnt fit...
azn0boi04 is offline   Reply With Quote
Old 04-08-2009, 11:05 PM   #2
Rei_Akira
Scooby Scammer- Do Not Buy From User
Member#: 194555
1997 GC8 coup
green
pix are always good. i think i understand what you're saying. its possible that you may have to take it to a muffler shop and have it modified. or maybe a WRX exhaust is different from the STi exhaust.
im no guru, just throwing out ideas. if you have a friend with a wrx might wanna check and see if there's a difference...
Rei_Akira is offline   Reply With Quote
Old 04-08-2009, 11:08 PM   #3
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
yeah... i didnt lift my car... i just laid on the ground... ill TRY to install it tomorrow, and if it needs modifying... i have a welder. ill take pics...
Old 04-08-2009, 11:42 PM   #4
beaviscih
Member#: 123362
'93 Crapcan, '98L
Sold, '04 STi - Sold
If I understand your delima correctly, I had the same issue mating a Skunk 2 axle back to my TXS turbo back and mid-pipe. With another set of helping hands we cut the Skunk 2 flange (that mates to the mid-pipe) turned the bolt holes so everything lined up with the mid-pipe flange, then installed the axle back. With the axle back installed we marked both the flange and axle back and labled the marks 1 and 2. I took the axle back to a weld shop and he rewelded the flange aligned with the two marks. Sorry for the long winded post, but I didn't know how to describe the process w/o pictures.
beaviscih is offline   Reply With Quote
Old 04-08-2009, 11:45 PM   #5
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
no... i know what u mean...i think im gonna have to do the same thing... how much do u think its going to cost..
Old 04-09-2009, 02:29 AM   #6
Rei_Akira
Member#: 194555
1997 GC8 coup
green
shouldnt cost much for them to lay some welds, specially since its only one flange, no bending or anything
Old 04-09-2009, 10:21 AM   #7
suberdave
Member#: 101865
88 GL-10 STi
take it out to Maple Valley Muffler. shouldnt cost more than $20-$25.
-=Suberdave=-
suberdave is offline   Reply With Quote
Old 04-09-2009, 01:40 PM   #8
beaviscih
Member#: 123362
'93 Crapcan, '98L
If you do the cutting yourself the welding takes about 15 minutes. Mine cost $20. He opted to stick weld it vs using a mig welder and used a 316 rod which worked well on the 304 SS exhaust. The key is making a clean cut and aligning the desired pipe orientation correctly.when making your marks.
Old 04-10-2009, 12:21 AM   #9
azn0boi04
Member#: 164172
97 OBS EJ20G ZILLA
87 GL
well i got it done... i cut and welded everything myself.... i just need a new DP.... something that is NOT ebay and not stock ..... anyone got one for sale? haa
Old 04-11-2009, 05:25 AM   #10
cb350f73
Member#: 208155
87 gl-10
grey
Unhappy exhaust...
hi, i am new to this forum, not new to subaru, but just bought my first subaru turbo car...1987 gl-10, 68k 4x4 5spd wagon. i need to redo the exhaust, as it is just a glasspack from the trans-back...is there any way that i can get the "rumble" out of this car, w/out spending high$ on bling pipes?
cb350f73 is offline   Reply With Quote
Old 04-11-2009, 10:30 AM   #11
suberdave
Member#: 101865
88 GL-10 STi
you wont get the rumble that you want out of an EA82t. you can open up the exhaust and make it sound better, but it wont be the same...
now if you drop an EJ20G into that thing, then you can get that rumble you are looking for. hoever that cost more than some bling bling pipes...
-=Suberdave=-
www.suberdave.com
Old 04-11-2009, 12:01 PM   #12
cb350f73
Member#: 208155
87 gl-10
grey
Default moe stuff...
thanks, also, this car was an original auto. now is 5 spd. the idle will not go down from 1200-1300. why is that and how to fix? it runs perfectly and no engine lights come on...
Old 04-12-2009, 02:24 PM   #13
cb350f73
Member#: 208155
87 gl-10
grey
Unhappy exhaust...
hey guys/gals...i have an 87 gl-10 w/ ea82t. the p.o. installed a dumbass cherry bomb on a pipe that doesn't reach the rear axle. looking for some good sound (and trying to keep exhaust out of the car), any problem with installing a straight pipe (2 1/2") or do i ned some type of (turbo) muffler? what can i do (low-buck) to my stock head pipes/down pipe to improve performance? all is bone stock...this is my first turbo soob...thank you
Old 04-12-2009, 04:15 PM   #14
suberdave
Member#: 101865
88 GL-10 STi
yeah you can do a 2.5" turbo back stright pipe. it will be loud. you may want to use a resanator or muffler somewhere in it though...
Old 04-12-2009, 11:31 PM   #15
cb350f73
Member#: 208155
87 gl-10
grey
Default 'nother exhaust question...
thanks man, i am looking for all the low-buck options that can be done to this thing...i also have a set of jackman rally's that will be on it shortly w/new rubbers...should look even better. any idea on why it would be idling 1100-1300?
Old 04-19-2009, 01:36 AM   #16
cb350f73
Member#: 208155
87 gl-10
grey
Talking exhaust...
nice! i got my exhaust done today and it sounds pretty good;-] 2.5 from the dp back no muffler. not 2 loud, but just enough tone and rumble to keep me happy...
yet another exhaust question I_say Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 05-05-2004 12:28 AM
Just another exhaust question..... wrxtreme227 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 04-27-2004 07:33 AM
Another Exhaust Question K Rock Impreza Normally Aspirated Powertrain 11 03-04-2003 07:13 AM
Another exhaust question wrxmontao!! Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-09-2003 11:14 PM
Another Exhaust Question BIGMANDAN New England Impreza Club Forum -- NESIC 6 12-25-2001 10:21 PM
