Old 04-08-2009, 11:53 PM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default The RS and Injectors/Fuel Rails, Etc.
OK, so I'm outta gas
I know WRX injectors are a direct drop in for my 05 RS. My question is, if I drop in WRX injectors, are WRX fuel rails, FPRs, and parallel conversion setups direct fit as well?
Old 04-09-2009, 11:50 AM   #2
Whiteghost 2.5
Member#: 72994
2001 Racekor
Emerald Green
what are you doing that requires WRX injectors?
Whiteghost 2.5 is online now   Reply With Quote
Old 04-09-2009, 12:24 PM   #3
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
making WRX-level power. Duh
Old 04-09-2009, 04:55 PM   #4
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Yeah that seems obvious, at least to those of us who know you're not an idiot noob. (And I know you're not one of those, whiteghost)
I would not necessarily expect the rails to bolt neatly up, but it probably would be a simple fab to make them do so. On the other hand, I find it unlikely there's a significant difference between stock WRX rails and stock 2.5i/RS of the same year where they share injector shape. Unless you are wondering about aftermarket rails. But if you are, then why? WRX-level power doesn't need them, right?
BAN SUVS is offline   Reply With Quote
Old 04-09-2009, 05:02 PM   #5
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
I'm trying to decide if I actually think the serial configuration of the fueling system is a liability. It seems that the very slight difference in fuel delivered to each cylinder becomes a larger and larger issue the farther you push the engine. With wild cams, 11.2:1 pistons, and a 7,000RPM or higher redline, I'm going to be asking quite a bit out of the engine.
Going to WRX injectors and a set of aftermarket parallel-run rails sounds like something I at least need to think about.
Old 04-09-2009, 05:14 PM   #6
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
I think the more logical first step would be just re-arranging the rubber lines into a parallel setup. Minimal cost and effort and solves the issue you're concerned about.
Old 04-09-2009, 05:18 PM   #7
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Judging from pictures others have shown, the hardlines themselves are in a serial configuration.
Old 04-09-2009, 05:28 PM   #8
BAN SUVS
Member#: 28685
2004 FXT 4EAT
very STi'd
Ah, okay. I hadn't ever really looked at them. Still, just a quick chop and clamping a rubber line on here and there would do it.
Old 04-09-2009, 08:05 PM   #9
recnelis
Member#: 92778
2000 Impreza 2.5RS
#74 ST - RCE Tarmac 2
http://northursalia.com/modification.../fuelrail.html
A little more involved, but probably not that much more difficult building the rest of the engine.
recnelis is offline   Reply With Quote
Old 04-10-2009, 02:43 AM   #10
rougeben83
Member#: 115154
2003 Legacy L Turbo
yes if you convert to parallel, you have to replace the hardlines...
Still it's going to be much cheaper than getting aftermarket fuel rails. And even on WRX's, aftermarket fuel rails aren't really necessary until you're up into the 350+whp range...
rougeben83 is offline   Reply With Quote
Old 04-10-2009, 09:15 AM   #11
Skidd
Member#: 1853
GC6 Supercharged
STM
Not quite true.
I converted to a parallel setup, and didn't modify a single hardline
http://ludicrous-speed.com/wiki/inde..._fuel_rail_mod
Skidd is offline   Reply With Quote
FS Glen Burnie: Injectors, Fuel Rails, STI exhaust, etc. Jeromee MAIC Private Classifieds 5 09-19-2009 10:59 AM
FS: injectors, fuel rails, catch can, turbo inlet, etc maddhatteroo7 Engine/Power/Exhaust 7 01-03-2009 01:53 PM
FS: RS Vishnu Parallel Fuel Rails and 550cc injectors Revision MWSOC Private Classifieds 4 11-28-2006 02:26 PM
FS: 96lb Fuel Injectors, Fuel rails, EIP Cat back exhaust, etc. PSI87 Private 'For Sale' Classifieds 34 05-06-2006 09:24 PM
Need to go asap: 750cc injectors, fuel rails, turbo, etc. EVOs_Master MAIC Private Classifieds 10 03-09-2006 11:06 PM
Message Board Statistics All times are GMT -4. The time now is 01:00 PM.
