Old 04-09-2009, 12:37 AM   #1
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Default Oiling an EJ253 At Very High RPM
So the new cams are in my EJ253 (SOHC NA, yes, I realize I'm a loonie for working on it). They require 7,000RPM to make any gains at all and breathe well enough at 7k that I'd like to bump the redline to 8k and see just how high they'll keep breathing. Stock redline on this car is 6kRPM. So I'm already 1kRPM above stock redline and considering 2kRPM above stock.
The EJ253 comes with a small oil pump, I've seen 6mm and 7mm mentioned in posts, not sure which is right. To spin the engine to 7k, or even 8k, which oil pump should I swap to? 10mm? 11mm? 12mm?
Yes, I realize that this is only one of several issues I need to look at.
Old 04-09-2009, 05:21 PM   #2
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
Get a 10mm pump as too big can be bad. The issues I think you may run into lie in the bearings; both material (not sure if they are the same p/n as EJ255/7) and clearance.
Old 04-09-2009, 11:52 PM   #3
ballitch
Member#: 74907
98 cam'd EJ251
Wrx Tranny,slowr than ish
Some N/A motors come with 10mm pumps on them. Dont know which ones, but it's really easy to read a number on the front of the pump to find out. I got one on my Phase I EJ25 block I bought years ago.
I cant remember exactly, but do your heads have upgraded springs and retainers?
~Josh~
Old 04-09-2009, 11:57 PM   #4
williaty
Member#: 71092
2005 2.5RS Wagon
Regal Blue Pearl
Nope, that's one of the other issues I'm going to have to be dealing with.
Old 04-10-2009, 02:27 AM   #5
jamal
Member#: 71875
98 Legacy GT
my wheels fit
A 10mm pump should be okay. I think it's what comes on the 2.0s that go to 8250. I would be most concerned about the valvetrain.
jamal is offline   Reply With Quote
Old 04-10-2009, 11:52 PM   #6
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
stock RS's came with a 9mm (at least my 01 did) and I believe newer ones came with a 7mm (the 2005 I rebuilt did). I put a 10mm on and haven't looked back. Make sure you port match.
Old 04-11-2009, 12:29 AM   #7
Chi_San
Member#: 53558
2005 Baja Sport
Gray/Silver two tone
Regardless of the pump, it might be a good idea to hook up an oil pressure gauge after you get the car up and running, if you weren't planning on doing so already.
Chi_San is offline   Reply With Quote
shh noise at very high rpm....?? binx159 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 13 03-17-2009 03:36 PM
4 Pulls at very high EGTs - Do you think I will have an issue? dexterous Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 24 04-25-2006 11:05 PM
STI Oil Pressure Reading? Low and High RPMS diplo12 Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 02-21-2006 03:24 PM
STI Oil Pressure Reading? Low and High RPMS diplo12 Normally Aspirated with bolt-on Forced Induction Powertrain 3 02-17-2006 03:57 PM
Mechanical squeak at very low RPM. nofriends Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 26 01-20-2006 10:57 PM
