Old 04-09-2009, 01:57 AM   #1
ElSpa
Member#: 196674
Default Upgrade from VF35 to TD06H-20G - what to do with the restrictor pill ? Other mods ?
Hello,
I'm upgrading my 207 STI from a stock VF35 to a TD06H-20G. I noticed a restrictor pill on the vacuum hose that comes out of the wastegate, just before the T piece.
What should I do with it ?
Should I keep it there, should i go with a larger restrictor (if so, how large) ? Should I eliminate it ?
Thanks,
Mihai
ElSpa is offline   Reply With Quote
Old 04-09-2009, 02:01 AM   #2
jcbluescooby
Member#: 113012
'04 XT red LIFTED
'15 XV CROSSTREK LIFTED
i hope your getting tuned and not just putting that turbo in
jcbluescooby is offline   Reply With Quote
Old 04-09-2009, 02:07 AM   #3
seanathanq83
Member#: 173241
2002 s256 twinscroll
now with one more gear
take it out, you will not need it, and get a new boost solenoid
seanathanq83 is offline   Reply With Quote
Old 04-09-2009, 02:11 AM   #4
ElSpa
Member#: 196674
I went with td06h-20g, fmic, ss headers + uppipe, 780cc, cai, 3" exhaust and downpipe and tune.
the problem is that I'm getting inconsistent boost delivery, going up and down from 17-22 psi in higher gears with this setup.
I'm just trying to get to the bottom of this.
Also it's a lot laggier then my VF35 (I now it should be laggier, but I think not so much), I'm only hitting full boost (20 psi) above 5000 rpm. Do you think the headers are the reason why ?
Overall, in 0-402m drag, my car work better with vf35 and mods + tune then it does now.....
Old 04-09-2009, 02:12 AM   #5
ElSpa
Member#: 196674
what kind of boost solenoid would do the trick ? I live in Romania, so I have to do all my shopping for parts in the US online, so a link would be nice .
Thanks
Old 04-09-2009, 02:17 AM   #6
goldshuscooby
Member#: 177641
2011 STi
SWP and Stage 1
Thanks
Something like this...
http://www.perrinperformance.com/pro...ry=37&model=29
or this...
http://www.grimmspeed.com/catalog/pr...roducts_id=145
goldshuscooby is offline   Reply With Quote
Old 04-09-2009, 02:18 AM   #7
jcbluescooby
Member#: 113012
'04 XT red LIFTED
prodrive or grimmspeed
Old 04-09-2009, 02:26 AM   #8
seanathanq83
Member#: 173241
i say go with grimmspeed, great company, and the boost solenoid, and a good tune can fix you fluctuation problems, and help boost come on faster, i say get the boost solenoid and get it installed and tuned for before you start chaging other things
Old 04-09-2009, 02:29 AM   #9
ElSpa
Member#: 196674
I'm waiting for my new hallman mbc to arrive and get tuned again by Cam, on camtuning.
In that case whould the solenoid be neccesary ?
Also what can I do about the lag ?
The SS equal lenght headers + upipe that I bought from ebay proved to be really strong, not a crack on them for 8 month (despite the talkings here on nasioc), but I feel that they are pulling me down from getting boost more quickly.
What do you think ? Should I go with my stock headers ? Would the loss in top end power will be that noticeble in relation to reduced lag ?
Old 04-09-2009, 02:49 AM   #10
seanathanq83
Member#: 173241
well with the 20g, top end will be nice so i dont think you will notice, but you should be getting the power about 1k sooner, but i dont know if its the headers, with the mbc you dont need a boost solenoid, personly i am not the biggest fan of MBC because you dont have the throttle response of being able to only make so much boost at so much throttle, but i still say get it tuned, and let the tuner see your logs and let him decide, he should be able to tell you whats causing the problem
Old 04-09-2009, 02:59 AM   #11
sindy9001
Member#: 207937
Agree with seanathaq83.
sindy9001 is offline   Reply With Quote
which side of the T connector does the restrictor pill go? sonic03rex Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 04-19-2008 11:55 PM
2006 STI Over boosting with the restrictor pill!!!! 06wrxsti_owner Newbies & FAQs 17 06-20-2007 08:51 PM
Tell me about the restrictor pill in the turbo lines shaneconaway Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 06-13-2006 07:58 PM
Experimenting with brass restrictor pill Woody643 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-19-2005 09:54 PM
Went from a double din radio to a single din Alpine….what to do with the other din Torch Car Audio, Video & Security 11 11-03-2004 04:39 PM
