Old 04-09-2009, 02:44 AM   #1
got0azn0rice
Member#: 151097
Default STI Genome Axelback on a 2.5i?
Does anyone know if the STI Genome Axelback(SPT Performance Muffler for WRX) will fit 06-07 2.5i? Or will this require a muffler shop to do a custom install?
got0azn0rice is offline   Reply With Quote
Old 04-09-2009, 03:27 AM   #2
Vizzionz
Member#: 139109
2007 Impreza 2.5i
Crystal Gray Metallic
should be a direct bolt on....
Vizzionz is offline   Reply With Quote
Old 04-09-2009, 10:26 AM   #3
wag07
Member#: 191442
2007 2.5i Wagon
UGM
I bought a used SPT axleback previously installed on a 06 WRX and tried installing it on my 07 2.5i Wagon. There's 2 inch gap between the axleback and rear exhaust pipe flange.
wag07 is offline   Reply With Quote
Old 04-09-2009, 12:11 PM   #4
cmiovino
Member#: 134005
2004 WRX Premium
You will need to get it extended and welded by a shop. Even the flange needs rotated I believe.
It cost me $75 at a shop.
Old 04-09-2009, 07:43 PM   #5
iyzmi
Member#: 150004
2002 18g WRX
WRB 310hp/285tq
The axleback needs no modification, it should bolt right onto any 02-07 Impreza. The midpipe would need to be extended 2" though.
iyzmi is offline   Reply With Quote
Old 04-09-2009, 10:17 PM   #6
Un0RiGiNaL
Member#: 189748
Axleback doesnt require any fabbing. All axlebacks are usually the same size. its the midpipe that is shorter. The WRX/sti midpipes are shorter by 3". they connect to the downpipe. Ive installed 3 exhausts , WRX axleback, STi axleback, and a turboXS axleback (currently on txs) and havent had to fab any of them.
I dont know why some ppl on here say they needed their axleback extended, maybe they ****ed up and were installing a catback system and instead of extending their midpipe they extended their axleback.
Un0RiGiNaL is offline   Reply With Quote
Old 04-10-2009, 04:51 PM   #7
ralli-tart
Member#: 106125
06 OZ aw wagon
on my 06 wagon, i started a thread on this a while ago, i needed to lower the axleback or extend the exhaust to get it to fit onto my wagon.
ralli-tart is offline   Reply With Quote
STi 20mm RSB on MY06 2.5i Sedan? Eluder Brakes, Steering & Suspension 6 08-12-2014 06:12 AM
06 STI headlights install on 07 2.5i/WRX Shiz36 Electrical & Lighting 12 05-19-2010 09:29 PM
Fitting 08 sti sway bars on a 2.5i? Gate4jg Brakes, Steering & Suspension 3 12-06-2008 09:26 AM
06 wrx axelback on 06 2.5i LandoCommando Normally Aspirated Powertrain 11 10-12-2008 08:57 AM
Update to 07 STi cat-back on 07 2.5i Wagon nuggetWRX Normally Aspirated Powertrain 8 05-15-2008 12:45 PM
