Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-09-2009, 10:09 AM   #1
96soobaru
Member#: 207453
1996 subaru legacy
teal
Default Car won't run after fuel filter and plugs replaced
Hello Forum!
I'm driving a 96 Legacy (EJ22) 2.2L with 115,000 miles.
I just replaced the fuel filter, PCV valve, Spark plugs, and wires. I started my car and it ran for about 10 seconds, sputtered and died. I tried again to start it and the same thing happened...Engine started (but didnt sound quite right)
sputtered for about 10 seconds then died. The plugs I used were NGK and the wires were Duralast - One of the new wires in the box was longer than the others by 2 inches? And the overall length of the new wires were longer than the old ones I took off? I dont know if this has anything to do with it but thought I'd mention it. Thanks - Chris
96soobaru is offline   Reply With Quote
Old 04-09-2009, 10:17 AM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
fuel lines crossed??
Old 04-09-2009, 11:33 AM   #3
96soobaru
Member#: 207453
1996 subaru legacy
teal
So...I looked everything over and I noticed there was a hose not connected to the air intake tube! I attached it and started the car and it purrs like a kitten now.
I didnt see it last night because it's hidden kinda under the air intake tube and I was a little tired.
Problem Fixed!
Old 04-09-2009, 11:35 AM   #4
scoobynoobEMT
Member#: 199206
2002 WRX wagon EJ257
idle air control tube?
scoobynoobEMT is offline   Reply With Quote
Old 04-09-2009, 12:21 PM   #5
96soobaru
Member#: 207453
1996 subaru legacy
teal
Idle air control tube...could be. Not sure exactly but the big tube that connects to the air filter. There is a smaller tube that connects to the under side of the big tube when I took the air filter stuff off to get the plugs the hose disconnected.
Car won't start after flashing until power removed/replaced silentt Open Source Reflashes 9 04-17-2009 11:11 PM
Car won't run after turbo install... I'm going to flip out!! Donzo Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 21 06-25-2008 05:03 PM
car won't run after intake manifold removal sti_vr4 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 40 04-22-2007 12:41 PM
ticking emergency lights after fuel filter replacement pk.v1.0 Service & Maintenance 2 02-23-2005 10:36 PM
