Old 04-18-2009, 11:21 PM   #1
impre25ive
Member#: 198933
Default '09 2.5i Rev's staying high?
Anyone else notice, that the revs pause for a little. When rev'ed the engine revs stay up for a little bit, then come back down.
Its not like most where the tack goes up, then right back down.
Anyone know why? or how to fix this "problem".
impre25ive is offline   Reply With Quote
Old 04-19-2009, 02:18 AM   #2
jeonster
Member#: 198854
2013 WRX
i'll try it out tomorrow.
jeonster is offline   Reply With Quote
Old 04-19-2009, 02:50 AM   #3
Tomato_88
Member#: 204277
Dark Gray Metallic
I have an 08 that does the same thing. I notice in everyday driving, shifting between gears mostly. I have no clue why it does it, or if it is supposed to.
Tomato_88 is offline   Reply With Quote
Old 04-19-2009, 10:15 AM   #4
rpthack
Member#: 207650
'09 2.5i
I'd guess what you're experiencing is our heavy flywheel; the greater mass makes momentum changes slow. Just like a light racing flywheel revs up quickly and slows down just as quickly, a heavy flywheel revs up slowly and slows down just as slowly. Someone who's cracked a science book in the last decade can probably give you the ins and outs of it.
rpthack is offline   Reply With Quote
Old 04-19-2009, 10:30 AM   #5
Un0RiGiNaL
Member#: 189748
is your car auto?
Un0RiGiNaL is offline   Reply With Quote
Old 04-19-2009, 02:39 PM   #6
impre25ive
Member#: 198933
Originally Posted by Un0RiGiNaL View Post
is your car auto?
no its a 5 speed.
anyone who has a '08/'09 2.5i, just try putting in the clutch and revving it. youll notice the revs stay up a little bit before coming back down.
perhaps what the poster a couple up said, about it being the flywheel.
Old 04-19-2009, 02:41 PM   #7
blernin41
Member#: 200321
2009 Forester 2.5XP
Armpit Green
.....get a lightweight flywheel or pulley.
blernin41 is offline   Reply With Quote
Old 04-19-2009, 02:45 PM   #8
scoobyviking
Member#: 192241
2013 STi
Plasma Blue Pearl
i am fairly sure that it happens with most if not all newer subarus. it is something with the way they are tuned. the ecu keeps the revs high for s short while and then they settle down to normal idle. i don't know exactly the reason and i have quite a few posts about it before and it also happens with mine. if you let the clutch out it should go back down immediately. sorry i don't have the technical reason for this, and it's totally normal. hope that helps.
kb
scoobyviking is offline   Reply With Quote
Old 04-19-2009, 02:47 PM   #9
Zac86
Member#: 136919
2005 Legacy GT Wagon
ABP
Ussualy has to do with the DBW.
Zac86 is offline   Reply With Quote
Old 04-19-2009, 03:45 PM   #10
SubiFTW
Member#: 138728
MY06 2.5i Impreza
Happens on my 06
SubiFTW is offline   Reply With Quote
Old 04-19-2009, 04:53 PM   #11
Nacron
Member#: 187115
Chapter/Region: HIIC
2010 Legacy 2.5i
Steel Silver Metalic
Noticed this once on my automatic. mashed the pedal to get around this guy and he sped up so I let off and it hung for a while before dropping.
Nacron is offline   Reply With Quote
Old 04-19-2009, 05:19 PM   #12
Jerry Xu
Member#: 36629
07 2.5i
Regularly Being Modified
It is in the program of their DBW system.
Basically everything is a delay (I hate it so much).
You step on gas, rpm stays low for a second; then you take you foot off, the rev stays hi for a second, etc. Drives me crazy for a few months.
Jerry Xu is offline   Reply With Quote
Old 04-19-2009, 06:22 PM   #13
aurtini
Member#: 205655
2006 Impreza 2.5i
I always attributed this to the rotational momentum from the engine components (flywheel, etc) on my 06. The annoying rev thing that I've noticed is when you roll up to a stop with the car still in gear with the clutch in the ECU will keep the engine speed above idle by a few hundred RPM until I either let the clutch out or put the shifter into neutral.
aurtini is offline   Reply With Quote
Old 04-19-2009, 07:55 PM   #14
Jerry Xu
Member#: 36629
07 2.5i
Reducing mass and SRI intake help but that is not the root cause of the problem. I was able to cut 50-70% of the delay with SRI and LWCP. Next planned is the flywheel. But the DBW I am unable to touch even with open source tuning. So we shall expect some residual lag.
Old 04-19-2009, 09:15 PM   #15
GEE-OTTO
Member#: 201277
2009 Legacy GT
Your problem has nothing to do with mass or momentum or any of the bs replied there is a flaw in the ECU btwn the DBW unit reference tables and the ECU itself. This issue is imply fixed with a SOA reflash to your car it corrects several issues associated with the way the car operates I had this issue with my 2008 LEgacy took it to the dealer they hooked it up to the diagnostic system and reflashed it took about 45 mins. This was the most annoying issue with my whenever I pushed in the clutch it would idle to 3k rpms then drop to 500. After the reflash it is a DREAM to drive it runs not as lean as it did from the factory it feels like a lil more pep in its step and the erratic idle is solved. Take it to the dealer ask to have the erratic idle issue looked at and they should fix it. If youre not under warranty it is only $94
GEE-OTTO is offline   Reply With Quote
Old 04-19-2009, 09:56 PM   #16
ohm
Member#: 178468
2007 UGM STI
IAG Built
The same thing actually happens on my 07 STI. No matter all the different ways I have tried to shift in order to combat this, the issue still exists. I wouldn't say I have gotten used to it, but it has become something I deal with.
ohm is offline   Reply With Quote
Old 04-19-2009, 09:56 PM   #17
Jerry Xu
Member#: 36629
07 2.5i
Gee-Otto,
you had a different problem looks like.
OP's problem is universal, staring from 05 on I think. Don't believe subaru has a solution yet.
Old 04-20-2009, 03:42 PM   #18
keyserblade
Member#: 209175
2008 Impreza 2.5 man
Does anyone know if the flash Gee-Otto is talking about works for 08 Imprezza's? I had my car in complaining about this issue shortly after getting the car and the dealer told me that everything was normal. If Subaru doesn't fix this issue there are going to be alot of blown syncros. The shift from 1st gear to 2nd gear is brutal! I'm sure there alot of drivers out there shifting like a normal car. I had a Contour SVT in the past that the RPM's would fall slowly after letting of the gas. They claimed it was for emissions. On that car you could put a restriction in a pipe that fed air into the throttle body and it would reduce the "throttle lag." With the Subaru running drive by wire I'm sure they are just holding the throttle plate open for a second after the drive releases the gas pedal. Are there any after market reprograms for the NA cars to fix this yet?
keyserblade is offline   Reply With Quote
Exhaust for '09 2.5i 5 door stackplates Normally Aspirated Powertrain 39 12-09-2013 04:21 PM
'09 2.5i asking: How's your aftermarket intake? epistax Normally Aspirated Powertrain 7 12-03-2009 04:15 PM
'09 Legacy 2.5i Suspension ms jdm Brakes, Steering & Suspension 1 11-17-2008 12:13 PM
'09 Impreza 2.5i w/NAV only with automatic rsholland News & Rumors 13 09-09-2008 02:54 PM
Looking at an '09 Legacy 2.5i Saleen501 Newbies & FAQs 1 06-29-2008 05:20 PM
