Old 04-16-2002, 12:33 PM   #1
RaceCarRiot
Member#: 6542
1997 Ver IV
Unhappy car idles like poop with the a/c on.
this has been going on for quite a while, but only recently since it started raining again and i have to keep the windows clear, has it become ANNOYING.
my problem is this: the a/c works fine, as long as i'm not sitting idling. if i'm at idle, and the compressor clicks on, i get this HORRIBLE booty shaking shuddering lumpy idle that jumps up to where the engine should run with the compressor on, and then suddenly drops to where the engine almost stalls...car shudders hard, engine vibrates enough to knock the intake against the hood, lights dim, etc., then it jumps back up again. up, down, up, down, up, down, shake shake shake, until the light turns green.
then once you start moving again, serene smoothness.
it started doing this after an ECU reset in november or december, and the only breathing mods were intake and exhaust. any ideas at all?
RaceCarRiot is offline   Reply With Quote
Old 04-16-2002, 01:43 PM   #2
live311
Member#: 10801
2008 Outback
How long have you been running the a/c since your reset? It's possible that the ECU just hasn't relearned the idle speed properly, thus can't adjust when the compressor kicks in. Take it to a dealer and have them plug in to reteach the idle. If that doesn't work, it could be something mechanical with your compressor, or possibly just a bad belt. I'm shooting in the dark but I think I at least sound like I think I know what I'm talking about.
live311 is offline   Reply With Quote
Old 04-16-2002, 01:45 PM   #3
SubaSonic
Member#: 11365
02 N/A, A/T Wagon
Sedona Red Pearl
Default Bad Idle
Try a higher grade of gas
SubaSonic is offline   Reply With Quote
Old 04-16-2002, 02:05 PM   #4
RaceCarRiot
Member#: 6542
1997 Ver IV
Default Re: Bad Idle
it's been run on 93 octane all the time since i put the chip in a few months ago, so i don't think that's it. it's been run with the a/c on during long highway trips, so it's not like it hasn't been used. but like i said, it works like it always has as long as there's motion involved...at idle, it just isn't happy.
i'll just let it sit and idle tonight when i get home from work, and see if it can't work it's demons out...
-adam-
Old 04-17-2002, 02:11 AM   #5
Kostamojen
Member#: 2272
2013 Subaru BRZ
Galaxy Blue
Its your pullies.
Old 04-17-2002, 03:09 AM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Originally posted by Kostamojen
Its your pullies.
he's right
jeremy
Old 04-17-2002, 09:17 AM   #7
RaceCarRiot
Member#: 6542
1997 Ver IV
the lightened crank/alternator ones, or the idler pulley that runs the compressor?
i replaced the idler pulley back in november or decemeber as well...the bearing in the old one burned up, and made the most hideous racket when the engine was running, so i just removed it back in september, and went sans a/c for a while...then after i replaced it and tried to use it again...shake shake shake at idle.
i thought it was my intake giving the ECU fits with the additional load of the a/c on the engine...it hisses like a den of cobras at idle when the compressor's on.
but if it's the lightened pulleys causing the problem...i guess i'll just live without a/c around town, or go back to OEM ones with a really light flywheel.
-adam-
Old 04-17-2002, 01:04 PM   #8
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
it's the lightweight pulleys, they are transmitting the compressor engagement and disengagement thru the car into your but. Get the flwyheel, the gains are mUHC better.
jeremy
Old 04-17-2002, 03:19 PM   #9
RaceCarRiot
Member#: 6542
1997 Ver IV
makes sense to me -- less dense material = less vibration damping. also as i recall, the stock pulley had a piece of rubber sandwiched into the middle, probably for that exact purpose. silly me.
i just don't get why there wasn't a problem until about 6 months after they were installed.
whatevarrr...i'll see if my friend still has the EJ18 he pulled out of his brighton laying around the shop, and just trade him for the OEM ones.
-adam-
Old 04-18-2002, 01:13 PM   #10
AudioFan
Member#: 1380
2005 SRT4
Orange Blast
So are you 100 % sure that it is because of the pulleys?
I have the 3 set pulley on my car (1.6 L), for like a month now, and since yesterday or two days ago, it is not a normal idle, it goes down for a second, but not as you describe yours, just a little. Im worried that could get worse over time? Do you really think the problem are the pulleys?
AudioFan is offline   Reply With Quote
Old 04-18-2002, 02:45 PM   #11
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
Your A/C compressor might be halfway seized like mine is. I have the same problem.
Dolphin Overton is offline   Reply With Quote
Old 04-18-2002, 03:23 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
yeah i was kinda thinking that...i need to get mine checked out, sounds like the compressor is ready to lock up...at least over the winter it did.
jeremy
Old 04-18-2002, 04:12 PM   #13
RaceCarRiot
Member#: 6542
1997 Ver IV
would having it sit there unused for several months cause it to seize? sounds logical.
-adam-
Old 04-18-2002, 10:32 PM   #14
HIHO
Member#: 7624
BD5; family sedan
that just wooped your ass
You should run your air for a little while EVERY month. Just for a few miles, just long enough to get the oils flowing. Not only does it keep the compressor in shape it also keeps the seals oiled.
HIHO is offline   Reply With Quote
Old 04-19-2002, 11:36 AM   #15
ImprezedRS
Member#: 2771
2003 BMW Z4
My car has been doing this for the last week or so since I started using the ac again. I don't have the lightened pulleys, hell only power mods are intake, TCII, exhaust and Hyper SFC.
Hell my car will buck and then stall.
ImprezedRS is offline   Reply With Quote
My battery dies if the car idles with the E-Brake on WRBLueGD2 Electrical & Lighting 66 04-16-2010 09:08 AM
do cars with the steering wheel on the right... sharky512345 Off-Topic 26 02-28-2004 01:39 AM
Why does my WRX drive like crap with the AC on? Schleppy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 22 07-01-2002 09:28 PM
My car is running BETTER with the CE light on..!!??(kinda long) Aaron'z 2.5RS Normally Aspirated Powertrain 10 01-23-2002 12:48 AM
can i leave my car for a week with the e-bake on?? Keith General Forum Archive 15 08-11-2000 10:33 PM
