Old 04-09-2009, 12:47 PM   #1
methaddict
Member#: 159738
2004 WRB STi
Full Race TS, BW 8374 EFR
Default what are causes for excessive crank case pressure?
what conditions make this happen? higher breathing capacity in the heads? stuck pcv? cams?
methaddict is offline   Reply With Quote
Old 04-09-2009, 01:43 PM   #2
berdugo
Member#: 163108
07 EuroDM STi 2.5L
not sure, just guessing, some blow by, lots of blow by from worn out piston rings or broken ringlands?
berdugo is offline   Reply With Quote
Old 04-09-2009, 01:43 PM   #3
gto7419
Member#: 44256
05 outback xt
02 wrx wagon - crushed :(
blow by.... and a crappy pcv system...
gto7419 is offline   Reply With Quote
Old 04-09-2009, 04:29 PM   #4
drewdogg
Member#: 90003
2005 STi
blow by... bad rings/ringlands
drewdogg is offline   Reply With Quote
Old 04-09-2009, 04:58 PM   #5
MartinSTi05
Member#: 145145
2006 wrx STi
Don't forget higher cylinder pressure. Even if you have good ring seal blowby will get higher as cylinder pressure increases.
MartinSTi05 is offline   Reply With Quote
Old 04-09-2009, 08:52 PM   #6
methaddict
Member#: 159738
2004 WRB STi
Ok this sounds like this maybe the reason why I was getting blue smoke out my exhaust. Since this is directly related to my other thread, here's a link: "Blue white smoke out of exhaust on newly built motor" I have no play on the turbo shaft and was told by a turbo rebuilder that my symptoms sound like the turbo seal is still good and was getting excessive crank case pressure. We disassembled the motor and all rings and ring lands were intact. I just had some debris in the oil that caused the crank journals to get scored up. I'm getting the crank black nitrided and repolishing the journals. I will install a good air/oil separator and remove the pvc.
Old 04-09-2009, 08:58 PM   #7
moorebl
Member#: 59238
try the crawford AOSits pricy but a good piece. i even think peeople on here are selling 1 or 2 of them
moorebl is offline   Reply With Quote
Old 04-09-2009, 09:00 PM   #8
methaddict
Member#: 159738
2004 WRB STi
I'm going with one by Kelly of Covert Performance.
Old 04-09-2009, 09:24 PM   #9
gto7419
Member#: 44256
05 outback xt
link???
Id like to take a look at these!
Old 04-11-2009, 07:47 AM   #10
n2oiroc
Member#: 141952
15 legacy 16 wrx
a bad compressor side seal on the turbo will do all the things you described.
n2oiroc is online now   Reply With Quote
Old 04-11-2009, 06:10 PM   #11
methaddict
Member#: 159738
2004 WRB STi
I described these symptoms to a couple of turbo rebuilders and they all say the turbo is fine. If it was the turbo it would have been constantly been smoking. They all say it's blow by possibly from a bad pcv.
Old 04-11-2009, 07:37 PM   #12
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
If there is excissive crankcase pressure it can back the drain up and cause the turbo to smoke.This is usually a concern on decel. I don't know that oil sitting in the cylinder will burn during startup because of it's low flash point. Most times you get smoke on startup it's coming from someplace behind the valve, that way you get some fuel in the mix to help light the oil up.
Jay Meagher
RealStreet is offline   Reply With Quote
Old 04-12-2009, 07:41 AM   #13
n2oiroc
Member#: 141952
15 legacy 16 wrx
they can say what they want, but i have been there twice now. oil blew out of my catch can a week before any symptoms showed up. then it smoked like hell at startup once, didnt smoke for 200 miles and then smoked like mad again. started sucking a bit of oil before i saw any smoke. the smoke really only starts to show up when the turbine side takes a dump. not all bad seals do this.....
4 tabs in back of WRX wagon: What are they for? rory-wrx General Community 8 03-01-2003 05:50 AM
Little Black Things... what are they for? Fred C Interior & Exterior Modification 11 11-03-2002 10:31 AM
Who ... or What are you for Halloween?? RigdenZW Off-Topic 27 10-31-2002 04:11 PM
Extra parts with Cobb shifter..what are they for? SpeedKills Normally Aspirated Powertrain 7 10-25-2000 06:06 AM
What are they for? Geezer General Forum Archive 19 06-09-2000 10:13 AM
