Welcome to the North American Subaru Impreza Owners Club Wednesday August 27, 2014
Old 04-16-2002, 12:58 PM   #1
wighti
Member#: 15345
2001 2.5RS GC6 sedan
S.T.M.
Default H6 swap Questions??
I was wondering how hard would it be to swap my MY01 sedan engine for a H6.
I was told that they only come with automatics. TRUE??
I know that Posches come with flat 6s' and manual trannis'.
Could I use that?
Or should I just build up my 01' SOHC?
wighti is offline   Reply With Quote
Old 04-16-2002, 01:03 PM   #2
DoctorNick
Member#: 7022
heh, Debbie Parker
is my ride
I don't know if the H6 would fit but your looking at a full ecu and motor swap. And with the H6 Being such a new motor to the scooby market...it would be cheaper to go with the svx 6 cyl...just forwarning. you looking at a big project ahead of you. Don't let the naysayers say it would be to expensive (it will NOT be cheap) or the naysayers say that it can't be done...because someone has to be the first. If your willing to spend that cash and then in the end have a h6 and a cut up car that won't run...then go ahead.
-Neal
DoctorNick is online now   Reply With Quote
Old 04-16-2002, 01:04 PM   #3
DoctorNick
Member#: 7022
heh, Debbie Parker
is my ride
I personally say the ej25 is a good motor. You get the right internals, correct turbo, good engine management and a gear set that can hold. You can end up with a beast that would be a very competive machine...
-Neal
Old 04-16-2002, 04:03 PM   #4
adamsrs
Member#: 3768
Well SVXs only came in auto. And the new H6s only come in auto. Just like I already told you SEAN! lol. I am sure that it will fit, BUT, you will neeed the ECU, Motor, Tranny, Crossmembers, and mayb e steerign rack, and other engine bay parts... Not worth it IMHO. And the Porsche tranny wont work BECAUSE like i already told you, a Porshce is a rear motor rear drive car. So if you used it your car would have to either be made FWD, or RWD, or if you shelled out like 10k for a Porsche AWD tranny then MAYBE after you swapped out the floorpan you could run it.
adamsrs
adamsrs is offline   Reply With Quote
Old 04-16-2002, 04:57 PM   #5
XT6Wagon
Member#: 524
04 STi
Adam, The SVX motor should bolt up to the tranny and work in the factory engine crossmember. Thats if both use the same engine mount style (round or square). I don't know about the H6 as the engine mount may have changed.
You will need the H6, engine harness, ECU + mic parts like maf.
I'd reccomend a switch to a B4 RSK/GTB 5spd tranny with a uprated organic clutch.
XT6Wagon is offline   Reply With Quote
Old 04-17-2002, 10:30 AM   #6
wighti
Member#: 15345
S.T.M.
ADAM!--I know we talked about this but, I just wanted some ideas and opinions from more than one person.
I pic everybodies brain until I figure out the best way to go.
Old 04-17-2002, 01:34 PM   #7
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
LOL yeah i would go with the svx motor as well, or just modify your ej25. Also you should consider swaping to a usdm ej20. A couple guys here down in CA can do it. I have heard that the exhaust runners for the new H6 are not designed that well. So it might be difficult to modify it. Also with the EJ series engines you would have a lot more room to work with. The engine plus all the extra parts needed for the H6 transplant could get you a ej20 swap and some. Just my $0.02
Andy
ac_gohan is offline   Reply With Quote
Old 04-17-2002, 06:34 PM   #8
adamsrs
Member#: 3768
Well the reason I said that the tranny would have to be swapped is because when Subaru developed the SVX they did not have a tranny made that would be strong enough to hold th power that the SVX puts out. Thus putting a stock RS tranny in there you will have to be very careful or you will break it.
adamsrs
Old 04-18-2002, 08:22 PM   #9
PeterJ
Member#: 14727
2002 impreza RS
Default go for it!
I've been researching this myself and I'm positive it will work...even though it's also an auto to manual swap. You need a crashed outback though..as others have already noted the random parts that will be needed (and the fuel pump?). Anyway, by my calculations, if you put the H-6 in a 2002 RS then, the 212 hp plus the extra weight (motor, Xmember, etc.) will make the car feel as it would with 200-205 hp before the swap. 18 lb/hp before, 14.5 lb/hp after. Just more info to consider...
PeterJ is offline   Reply With Quote
Old 04-19-2002, 01:18 AM   #10
wighti
Member#: 15345
S.T.M.
See....that's why I want to try this. I mean I could have the heads worked and add an exhaust,turbo, and FMIC. That would probably put me over 300hp running maybe 7psi.
BTW....I think it will be a few years before I attemp this. Right now I'm just going to work on my car and engine. Then when I have the money and a LOT more experience I'll buy a spare car
and go to town. (with some help...I hope).
Old 04-19-2002, 11:56 AM   #11
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
the H6 from an SVX will fit, Forced Air Tec has done it.
RageHardIntoTheBendies is offline   Reply With Quote
Old 04-19-2002, 09:54 PM   #12
Jack
Add Lightness
Member#: 13699
2007 Lotus Elise
(From General)
H6 in an RS. This sounds like a great project! Some things to consider are that indeed you'd have the engine mgmt out of a "donor" outback. I don't know enough about how the mating is with the H6 and the RS tranny, but it is always possible to make the mate. Worst case, you'd need to have a tranny intake shaft modified or made, depending on how the flex plate is mated on the H6, a flywheel would need to be chosen, modified and perhaps balanced to the engine (I know 5.0's, not subies). The mating of the tranny to the block, if not a direct bolt up may require some custom fabrication. The biggest stumbling block might be the fact that you'd be tying up an RS for a while.
Assumptions:
1) a stronger tranny already exists (since there are so many RS-T's)
2) stronger diffs would eventually be swapped in
3) supercharger would make this a real competitor for anything out there.
This is interesting. I'll have to do some engine compartment measurements on our outback and RS. Anyone else looking for a project?
jack
Old 04-19-2002, 11:19 PM   #13
XT6Wagon
Member#: 524
04 STi
Jack, it uses the normal EJ mounting pattern. No idea if the Crank has the same bolt pattern on it and the thickness of the bellhousing on the motor side, but its almost certain to be the same as the EJ series, since its FREE to do so, and is cheaper to build a car with such, as it bolts right up to the Auto tranny w/o any new parts needing to be designed and manufactured.
6spd swap question red06rex Transmission (AT/MT) & Driveline 5 06-02-2010 05:41 PM
h6 swap question dirtyperrinwrx Subaru Conversions 2 10-05-2008 06:15 PM
H6 swap questions bhall Legacy Forum 35 12-09-2005 01:26 PM
H6 Swap Kenny T. Subaru Conversions 22 08-04-2004 04:15 PM
H6 swap in an RS, opinions Stavros g Normally Aspirated Powertrain 16 01-27-2001 01:55 AM
