Old 04-09-2009, 03:48 PM   #1
hustleshark206
Member#: 182227
2000 MPS Built RS
1991 Leggy Turbo EJ22t
Default In line fuel filter?
Anybody using one of these on their built motor? I was thinking about ordering one to tie into my stainless fuel lines.
Housing
Element
hustleshark206 is online now   Reply With Quote
Old 04-09-2009, 05:00 PM   #2
MartinSTi05
Member#: 145145
2006 wrx STi
http://forums.nasioc.com/forums/show....php?t=1676783
Browse around, I use a total of 2 filters in mine. Ideally you should run two. 1 coarse ~100 micron pre pump, and one fine after the pump.
MartinSTi05 is offline   Reply With Quote
Old 04-09-2009, 05:04 PM   #3
Drakar
Member#: 68402
intank setup will have the sock and then the filter in the engine bay, you can use an inline filter but you want to make sure it will work with higher PSI, I believe the one pictured is for a carb motor and not an EFI motor, you need to make sure it's NOT a carb filter as you will blow the filtering element apart.
if your intake but have braided lines then the fine filter after is good, if your running an external pump like an A1000, then the coarse --> pump ---> fine ---> motor is what you want.
Drakar is offline   Reply With Quote
Old 04-09-2009, 05:39 PM   #4
hustleshark206
Member#: 182227
2000 MPS Built RS
From Jegs
"Easy to disassemble for cleaning, this in-line fuel filter has a 35 micron, sintered bronze element. It's anodized blue and flows up to 5 gpm. Available in -6 or -8AN for use with Earl's high-performance fuel line. Replacement element sold separately"
So maybe it would not be good since it is only a 35 micron filter? I thought I saw HomemadeWRX use this on his build but I could be wrong. I have one walbro 255lph which of coarse has the pre-pump filter already attached.
Old 04-09-2009, 05:59 PM   #5
hustleshark206
Member#: 182227
2000 MPS Built RS
Found this from the link above.
Well, I suppose I will elaborate.
A1000 Pump
Aeromotive FPR
Aeromotive 100 micron ball valve pre pump filter/10 micron post pump filter.
Aeromotive fuel rails
1/2" stainless supply tubing/3/8" stainless return tubing.
Earl's -8/-6 teflon speedflex lines and fittings for supply,return and vent respectively. (Moonshine compatible)
Ealr's -10 performoflex hose/swivel seal for pump inlet line.
Custom PWM pump controller
Precision turbo 1000cc injectors.
Old 04-09-2009, 06:20 PM   #6
hustleshark206
Member#: 182227
2000 MPS Built RS
I think he may have made a typo in his post.
From Jegs:
Aeromotive In-Line Fuel Filter With Shut-Off Valve
Ever Take A Fuel Bath When Changing Your Filter? Aeromotive Has a Solution
Cleaning and replacing your filter element used to mean draining your gas tank. The new Aeromotive Shutoff Valve Fuel Filter allows you to shut off fuel flow and replace your filter element with little or no fuel loss. Featuring 100-micron stainless steel elements and are recommended for use between the fuel cell or sumped tank and the fuel pump inlet.
Edit: This is for a fuel cell which acts as a pre-pump filter for the aeromotive A1000 pump. I don't think this is applicable for my setup since my pump is in tank.
Old 04-09-2009, 06:36 PM   #7
Drakar
Member#: 68402
http://store.summitracing.com/partdetail.asp?autofilter=1∂=AEI-12301&N=700+4294925239+4294839051+4294852562+115&a utoview=sku
it's the same filter my buddies use after the A1000 pump that is on their Camaro's and Trans am's running S/C's or twin turbos' (500+ WHP)
Old 04-09-2009, 06:39 PM   #8
MartinSTi05
Member#: 145145
2006 wrx STi
Well, in that case treat your sock filter as the pre filer and get a nice small media filter for after the pump. Just make sure the element are is high enough that it doesn't cause restriction.
Old 04-09-2009, 07:07 PM   #9
hustleshark206
Member#: 182227
2000 MPS Built RS
The Earl's filter flows up to 5gpm which seems like plenty since my fuel pump can only deliver 255lph.
1L = 0.264 gal
Walbro Pump(255*0.264)= 67.32 gallons per hour
Earls filter (5gpm*60m/h)= 300 gallons per hour
Flow doesn't seem to be an issue here. The element for the Earl's filter is 35 microns. Is this fine enough for my application?
BTW, nice looking setup you have there Martins. Very impressive. Hows it comming along?
Old 04-09-2009, 07:18 PM   #10
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
I use the CM 1 micron and love it, its easy to service. The elements are cheap too, and its VERY easy to mount. I got it from www.pegasusautoracing.com
scby rex is offline   Reply With Quote
Old 04-09-2009, 07:30 PM   #11
MartinSTi05
Member#: 145145
2006 wrx STi
If I were you I would go with a finer filtration media. Particles of >35 microns can still clog an injector.
1L = 0.264 gal
Old 04-09-2009, 07:33 PM   #12
Drakar
Member#: 68402
1L = 0.264 gal
flow seems good but at what PSI, if thats rated at 15psi for a mech or elec carb pump, your still screwed, it's the PSI rating as well as flow that you need to worry about not just flow.
Old 04-09-2009, 07:49 PM   #13
hustleshark206
Member#: 182227
2000 MPS Built RS
Thanks again for the input guys! This is great info!
Scby rex: Is this the filter you have?
Element is good to one micron
From the website:
C/M 4 inch Machined Aluminum Fuel Filter Assembly
Canton/Mecca offer a fuel filter using their proven high-strength aluminum housing and synthetic filter media from their oil filters! The seals and the filter element are made using materials that are resistant to all common racing fuels. The super-fine 1 micron filter element will flow up to 90 G.P.M. with minimal pressure drop. In fact, the pressure drop is so low that this extra fine, high-capacity filter can even be used on the suction side of most pumps.
Includes one T-bolt mounting bracket, which is adequate for most installations. For extreme vibration environments or for maximum reliability, a second clamp (part #1285-Square) can be used to help support the filter. Bottom inlet and side outlet are both -12 O-ring ports and require an O-Ring Boss Adapter Kit (Part No. 1280-Size), sold separately. Includes one filter element
This seems like the one to get. It can flow 90 gpm with almost no pressure drop
Probably between this one and the Aeromotive one linked above by Drakar
Old 04-09-2009, 08:41 PM   #14
MartinSTi05
Member#: 145145
2006 wrx STi
That seems like a good choice. You are going to enjoy paying for -12 fittings thouhg;-)
Old 04-09-2009, 09:25 PM   #15
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
That red one is the one I run from CM Filters: http://www.cmfilters.com/fuel.cfm
mick_the_ginge is offline   Reply With Quote
Old 04-09-2009, 10:08 PM   #16
hustleshark206
Member#: 182227
2000 MPS Built RS
The fittings kit is another $25. The replacement elements are pretty cheap though.
Old 04-09-2009, 10:13 PM   #17
hustleshark206
Member#: 182227
2000 MPS Built RS
Mick do you use the 1 micron or the 8 micron high flow element?
Old 04-11-2009, 11:04 AM   #18
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
From my refresh rebuild thread - 8 micron
Just in case anyone wanted to order from them.
Here you can see the size of the high flow filter. The old one was very clean and I have not done the 10,000 miles that they say is needed before a change (just 6000 miles) but while I was doing fuel stuff I thought it was a worth while change
Changed the fittings on it at the same time, this will make it easier to get the fuel lines on and off
Old 04-11-2009, 02:43 PM   #19
scby rex
Member#: 104878
02 wrxbastardchild
Yup this is the one I have
Old 04-11-2009, 11:08 PM   #20
hustleshark206
Member#: 182227
2000 MPS Built RS
That thing looks clean as hell on both your cars. I just ordered it!
Thanks for the pics guys
Converting In-Tank Fuel Filter to In-Engine bdon22 Service & Maintenance 3 04-16-2010 08:16 PM
In tanke fuel filters? or boot fuel filters? HEKTIC Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 04-30-2007 04:37 PM
In-tank fuel filter? The Rusty Gear Service & Maintenance 1 01-10-2007 11:23 AM
Where can I find a small in-line air filter for vacuum line. Tim Prudence Normally Aspirated Powertrain 3 12-04-2000 03:38 PM
Need in-line fuel pump Greg Sharpe New England Impreza Club Forum -- NESIC 2 09-21-2000 10:19 PM
